Question about Garden
LX118 JD Lawn Tractor Moving Slower and Slower
Hello, My LX188 lawn tractor moves slower and slower as the engine warms up to the point where it cannot even go up a slight hill. I pumped the transmission fluid out and replaced but did not solve the problem. I made adjustments to the linkage with no results. Any suggestions?
    Problem Solver:
  • 14 Answers
You need a new belt cause the old one is stretched out
Posted on May 07, 2013
Testimonial: "I replaced the belt but did not solve the problem."
wadembly
  • 462 Answers
SOURCE: Sears lawn tractor. While mowing, ran over a
the branch probably got cought in the belt that runs the rearend it may have caused it to come off check the drive belt
Posted on Jun 06, 2009
  • 32 Answers
SOURCE: Craftsman lawn tractor mower,
The belt is probably slipping because it is not tight enough. look by the belt, inside there is a little spring, you may half to tighten it.
Posted on Jun 13, 2009
  • 61 Answers
SOURCE: No spark in JD lawn tractor engine
it could just stuck, loosen see if moves reset points.
Posted on Sep 07, 2009
bbreton
  • 437 Answers
SOURCE: Hello, I have a MTD 13am67g088 lawn tractor, the reverse slips
You may have a pulley loose, but it may be time for some new belts.
The model number you gave was incomplete. But I was able to look at an IPL for that series of mowers and there is not fluid to add, it has gease in the transmission.
HTH
Good Day.
Posted on Oct 30, 2009
  • 66 Answers
SOURCE: have a 19.5 HP Craftsman lawn tractor
Personally my best advice is to take it back to the tech. Why? Because they should stand behind it if they just installed it and two...it may void the warranty if you touch it
Posted on May 31, 2010
Lawn tractor will only run in high gear
If it is a geared, belt driven lawn tractor it more than likely may be a worn or stretched belt. When you use it in high gear, does it go the same speed as it did originally or is it slower?
Dec 27, 2016 | Garden
Wiring harness
look underneath did drive belt snap in two , rear has white plastic fan on top of it that should be rotating with engine running if not yep you broke a belt , don't know about wire could it be from front PTO they are electric so it will need a wire ,one possibility is that drive belt broke slapped front PTO and broke off wire , that musta been some snow your pushin ooh and a reminder never push a hydrostatic drive tractor without pump turning it will dammage it
Feb 08, 2014 | John Deere Starter Tractor Lx188 Kawasaki...
Drive belt getting hot and slowing down
check bearings of all spindles the belt drives Find the one that has seized and replace the bearings. They all suffer from water and dirt getting in
May 30, 2013 | Craftsman 20 Hp 42" Deck Lawn Tractor
My tractor won't go up any grade or incline.... it just gets slower and slower until it stiops.
HI
Im sure you have a hydrostatic or an automatic forward and reverse right well your ****** is on its way out when it warms up it likes to crawl in this case even if you attempt to check oil or even try draining and putting in different oil its a tough one ****** is expensive
Joe
Joe
Sep 09, 2012 | Husqvarna YTH2454 54in 25 HP Lawn Tractor
Lawn mower blades won't budge, even w/ 1/2' drive impact wrench
Hi, warm the nuts up with a heat gun or oxy torch then try the impact gun while they are hot, regards Phil.
May 31, 2012 | John Deere Starter Tractor Lx188 Kawasaki...
Toro lawn tractor
check for worn bushings on the linkage
May 06, 2012 | Garden
Husqvarna YTH 2042 lawn tractor It starts OK, but as soon as I take my foot off the clutch, it lugs and quits. Same thing happens if I start to engage the clutch lever, even with my foot still on the...
If it really 'lugs', meaning the engine gradually chugs slower and slower as if it's struggling, then it could be a belt problem, but I'm going to guess it just quits, which suggests a problem with the seat safety switch. Look under the seat, take out the safety switch, and tape it in the pushed-in position. See if the tractor runs now. If so, the switch is the culprit - either it failed, or the mounting is wonky so it doesn't activate when you're in the seat.
Jun 05, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Mower getting slower and slower
If the dealer doesn't have a clue, I suggest finding a different dealer or reputable repair shop
Sep 17, 2009 | Cub Cadet Street Sign- tractor lawn riding...
I have a Stanley 17.5 hp 42"cut riding mower, purchased in 2002. Lately it has started to move slower, especially on grades, and really slow in reverse. It has a hydrostatic transmission. Are there...
Sounds like its slipping..
Have you checked the hydro fluid ?
Are there any leaks ?
Could be an adjustment in the pedal..
Look at all the pedal linkage and you might find some adjustment there..
Or - maybe a moving part is waring out in the linkage..
Hope this helps !!
rate me good ;o)
Jul 14, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Apr 28, 2009 | Garden
Garden Logo
57 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
