Question about Troy-Bilt Troybilt Mtd Mini Tiller Cultivator Carburetor W/primer 21ba144r966 Tb144
Mtd cultivator how to replace pull cord
    Problem Solver:
  • 14 Answers
Take your cover off then you take off your spinny thing out and take the old rope off the spinny thing and tie your new rope in it then twist it tight if its old or if its new dont worry its auto set then put it all back the way you took it off
Posted on May 07, 2013
How do i replace pull cord on mtd 31cc tiller
Remove your recoil housing. Turn the inside to see if spring is broken. If spring is good wind it up as tight as it will go without forcing it. Once you have it wound all the way then back it off one turn or until the eyelet meets where the rope comes out. tie a knot in one end and feed through both holes. Pull the rope through till the knot is tight then attatch your handle. Once the handle is in place slowly let the rope wind itself in. pull a few times to make sure your knot is holding and reinstall on engine
Jul 16, 2014 | Yard Machines Mtd Yard & Garden Cultivator...
How to replace pull cord on mtd yard machine cultivator 31cc
-Remove the cord or rope assembly. then rewind the unit and then attach the new rope to. After install the new rope. Try to pulls out to see it will rewind back or not. If not rewind more.
Good luck
Mai
Jun 19, 2014 | Garden
Mtd pro bc263rs
If it has rivets holding it . You'll be better off ordering a new pull starter assembly three bolts hold it on simply remove 3 bolts put new one on reboot it on and done . those housings have a tightly wound coil spring. I've yet to see one get put back on tight enough.
Sep 29, 2013 | Mtd Products Yard Machines 158CC Tiller
Handle on pull cord came off and cord went inside,
pull spark plug then pull cord see if fluid comrs out.if so check oil level,if over full see if it smells like gas if so you have a bad float in carb or dirt stuck in needle and seat in carb if all is good could have sheered flywheel key or if over head valve engine(has valve cover) valves may need to be adj or compression release mechanism in side engine broke. todays engines have very high compression and will not turn over without release. hupe this helpl
Aug 01, 2010 | Mtd Products Yard Machines 158CC Tiller
My rear tine MTD rototiller quit working while tilling this last weekend. When I pull the cord to start it, there is a metal clanking noise, but it will not start.
everyone is having trouble with all the small motors now-a-days.
they blow up to easy .
the noise you hear is the rod that came off the crankshaft.
time for a new motor.
Jun 08, 2010 | Mtd Garden
I waz starting the awn mower and had resistince from the pull cored so i pulled and now the pull cored is dangolling and want trigger a start
Soundas like the rewind spring is broken. Remove the top housing and see if you can reset the spring by removing the cord, hook up the broken end, rewind the spring with a screw driver...lock it in the tension position and then reinstall the cord.
Jun 15, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
Starter rope too hard to pull on Yard Machine By MTD
Not sure if this will help. Don't want to sound like a **** but....Have you made sure nothing is caught or jammed inside it. This could make it hard to start with the cord..
May 19, 2009 | Troy-Bilt Pony Garden Tiller
I just purchased a troy bilt bronco crt tiller. Put oil and gasoline in. Pulled the cord. It started. Ran maybe 15 or 20 seconds and stopped. When I tried to start it again, the cord would not...
remove the spark plug.  And pull the cord again.  if the carb float is stuck down or you overfilled the oil you could be hydro-locking the engine.  Check.
Mar 29, 2009 | Mtd Troy-Bilt Bronco OHV Tiller
Troy-Bilt Troybilt Mtd Mini Tiller Cultivator Carburetor W/primer 21ba144r966 Tb144 Logo
78 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
