Question about HP Officejet J6410 All-in-one InkJet Printer
VERY slow printing printing problems - HP Officejet J6410 All-in-one InkJet Printer
    New Friend:
    Problem Solver:
  • 14 Answers
Clen it up at mycleanpc.com
Posted on May 07, 2013
My epson office tx600fw printer is very slow since I start using Windows 8.1 how can I restore its original speed
Steps to Troubleshoot Epson Printer Slow-to-Print Problem?
Learn to troubleshoot Epson Printer Slow-to-Print Problem as not all printers are created equal. Print speed may vary depending on system configuration, print mode and document complexity. Processing time on the computer system is not included in the print speed. The several factors where printing is slow are mentioned below:
    ·Printer driver settings
    ·Size of the data being sent to printer
    ·Windows spooling error You can also get in touch with Epson Printer Technical Support for further query or simply follow the steps to troubleshoot the slow-print issue.
    Steps to fix Epson Printer Slow-to-print issue:
    Step1: Observe the data cable
    Check whether the data cable is less than 1.8 meters in length and is connected directly to computer system. Use of long cable and connecting through third party such as USB hub can cause communication and print delays.
    Step2: Paper type
    Check that paper type you have selected in the printer driver matches the paper loaded in the printer and selected paper print is also appropriate
    Step3: Some general tips
    Click on icon shown for general information on how to remedy slow printing
    Step4: High Speed enabled
    Check for high speed if it is enabled in the printer driver. Depending on the driver the setting may only be available on certain quality and paper selections.
    Step5: Enable High Speed
    Open the printer driver from printers, printer and faxes or Devices and Printers folder and check whether the high speed is enabled in speed and progress
    Step6: Other Settings
    Check for other settings as well in speed & progress for better printing speed
    Step7: Spool folder
    Create new folder of spool on the hard drive and point the driver to it
    Step8: Carry a test
    Print a test page form general tab of your Epson driver
    Step9: Perform
    If printing is still slow try reducing the size of the data sent to printer
    You still have doubts to execute the above mentioned steps you can contact via Epson Printer Customer Support Phone Number USA Toll-Free 1-800-213-8289 UK @+44-800-046-5291(toll-free) to receive immediate and instant solution. The trained technicians are present 24*7 to deliver you high speed printing printer machine.
Epson Printer Customer Support Phone Number 18002138289 Help
Feb 11, 2015 | Epson Stylus Office Equipment & Supplies
Kyocera slow printing
First you have to determine if the problem is mechanical of electrical. Are the letter bunching up. If so the print shaft may need oil. Is the data from the computer being held up some way. Bad interface maybe? Are you using the proper print driver. The wrong or damaged driver can cause print problems of various types. Check for computer viruses you would be shocked at what a virus can do to your printing. Start with those suggestions. Then come back.
May 11, 2014 | Kyocera Office Equipment & Supplies
It is printing very very slow
Try this....when you go to print click on properties and then
color....then print in greyscale. It should then print much, much more
quickly. I had the same problem and it appears that when you print in
color on a network, it uses the graphics mode rather than a text.
Mar 02, 2011 | HP OfficeJet 7310 All-In-One InkJet...
I have an HP LaserJet 3600 dn printer and I'm experiencing a problem with slow printing. I thought it was just when I tried to print PDF documents, so I tried to print a regular MS Word document, and...
When you print the config page, does it print slow?
If it prints at a reasonable speed, it's not the printer.
Are you using the USB port, the network port or a jet direct card?
One of those could be bad.
Jan 11, 2011 | HP Office Equipment & Supplies
10 % Memory problem showing my printer and slow
In the printing process, there a stage called spooling. This is where the data to be printed is cached into your system, so that you can print it even without having to leave the source application open. However, when you are low on RAM (or computer memory), the spooling and printing process slows down since the system is finding it hard to transport the data due to the bottleneck. Closing running applications (such as your web browser, music player, media player, games, and such) would definitely help ease out this one.
Jul 02, 2009 | HP LaserJet 5200 Printer
Slow Printing
You need to change the pickup roller. The rubber dries out and it is not able to pick up the paper quickly. I had this problem with our printer at work. We changed the rollers and its printing like new again.
Apr 24, 2009 | HP LaserJet P3005n Printer
HP Laserjet 1200 prints pdf documents slow
I had the same problem for printing pdf documents too slow with HP Laserjet 1200 :
Here's the fix: Open a pdf document go to File > Print> Advanced> check the box Print as image, use 300 DPI...that should do it.
CHEERS AND VISIT //dentaltourism.rs
Feb 18, 2009 | HP LaserJet 1220 Printer
Epson R200 print job suddenly slows down
Your printer memory is full and it needs to wait to take on more data files for printing.
Jul 13, 2017 | Epson Stylus Photo R200 InkJet Printer
Oki Microline 520 printing slow
Your printhead alignment is out thats why it prints slow
Jul 17, 2008 | OKI MICROLINE 520 Matrix Printer
Extremely slow copying
Cartridges may give a very slow printing if internally damaged, or :
When using colored paper in the all-in-one, printing or copying is slow.This issue is a result of the automatic paper type sensor misreading the colored paper as photo paper. The print out takes longer because the unit is printing in Best mode instead of Normal mode.
  1. Click Start , point to Settings , and then click Control Panel .
  2. Double-click Printers and Faxes .
  3. Right-click the appropriate all-in-one, and then click Printing Preferences .
  4. Click the Paper/Quality tab and under Type is: select Plain Paper . This sets the default paper type setting to Plain Paper.
Hope this helps.
Jan 05, 2008 | HP Photosmart 2610 All-In-One InkJet...
HP Officejet J6410 All-in-one InkJet Printer Logo
27 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
