Question about Saeco Odea Giro Plus Coffee Maker
Flashing light How do I prime the water circuit.
    New Friend:
    Problem Solver:
  • 14 Answers
Pump it
Posted on May 07, 2013
2 Suggested Answers
  • 81 Answers
SOURCE: Re Odea Giro Plus - Cannot stop the red alarm
The problem is with the flow meter which is a turbine unit that is installed before the pump.Either there is a blockage or the unit is bad.Have to open the machine to get into it.
Posted on Jan 21, 2010
Why is the prime light on?
You lost the suction and prime necessary to transport water to the tank.
May 02, 2012 | Keurig Platinum B70 Coffee Maker
Tip
Saeco, Gaggia, Spidem VENTILATE, Prime what is mean, how to perfrom
Ventilate or priming or else loading all means the filling the machine system full with water, like pump, piping and boiler. This must perform first time of starting up the machine.
It will also appear if the water system in not full of water especially after the steam preparation some steam can be blocked in the system and the machine recognized it by luck in the pressure.
Another reason that ventilate it appears on screen is because air have been insert and blocked in the water system usually from water filter or water softener located in water tank.
So here how you Ventilate or Priming or loading:
Place a container beneath the steam tube.
Turn the knob counter clockwise to start loading the circuit.
Wait until a steady stream of water flows out from the nozzle.
Turn the knob clockwise
to terminate the circuit loading process.
Remove the container. The machine is warming
up; lights are flashing.
Note: You must load the circuit before starting up
the machine for the first time, if it has been inoperative
for a lengthy period or if the water tank has
been completely emptied. The circuit must also be
loaded each time the light flashes
on Aug 28, 2010 | Coffee Makers & Espresso Machines
There is a red light flashing thru all the icons underneath the controls
Run the hot water tap until the lights stop blinking. It is asking for the water circuit to be primed IIRC.
Sep 30, 2011 | DeLonghi Magnifica 3300 Espresso Machine
Hello The lights on the front of the machine wont stop flashing so I can't press the cup symbols to make coffee. The hot water is coming out though through the steamer spout. Thanks!
Circuit Priming
When the machine operates for the first time and when
all the water has been dispensed, the machine circuit
needs priming. In this case, the 4 buttons of the control
panel will flash at the same time.
• Press the ON/OFF button . The 4 buttons will
flash.
• Place a container under the cappuccinatore.
• Open the "hot water/steam" knob by turning
it anticlockwise.
• Press the hot water button.
• Wait for water dispensing to stop.
• Close the "hot water/steam" knob by turning it
clockwise. Remove the container.
When the first priming ends, the warming up
starts. Before brewing coffee, water and steam,
please wait for lights 15 and 16 to be permanently on.
The machine is now ready to brew coffee and dispense
steam. Please see related sections for operating details.
Note: if priming is not completed, the 4 buttons
will keep on fl ashing. The machine cannot be
used.
Jan 14, 2011 | Saeco Nina Bar Espresso Machine
Load the circuit
Hi
It means you need to prime the lines. Push the button for water, then open the knob on the right. When water starts to flow the red light should disappear, and start to warm up. If the red light doesn't disappear, you may have a restriction in the flow meter, or intake line.
Nov 08, 2009 | Saeco Incanto Classic Espresso Machine
My sirena does not work
anytime the water runs out and you need to refill the tank, you need to bleed the line so to speak. Take an empty cup and put it under the wand and open the knob of the steam wand until the blue light stops flashing
Feb 13, 2009 | Saeco Starbucks Sirena Espresso Machine
Saeco Odea GO How do I
This is a common problem that is not explained in the manual. Turn the left silver knob on the top deck of the machine past the steam icon to the water drop icon. Let about eight ounces of water out into a cup and the circuit is primed.
Apr 13, 2008 | Kitchen Ranges
Saeco Odea Giro Plus Coffee Maker Logo
64 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
