Delete file hiberfil sys - Computers & Internet
  • 7,627 Answers
Error PXc000009 when win 7 pc on
Looks like a pagefile error.
Try this
Delete pagefile from "Performance Options window at Advanced tab" ( go to Control Panel->view advanced system settings) and reboot.
Note if you are not able to open Control Panel: Try this one of these:
  1. Press WindowsKey+R to open "Run" windows and type: control sysdm.cpl
    • Then go to the Advanced Tab and click "Settings" at the Performance Section
  2. From the File menu at Task Manager (Ctrl+Alt+Supr) then "New Task (Run)" and Then go to the Advanced Tab and click "Settings" at the Performance Section
After that:
Also run this command to delete the hiberfil.sys
powercfg -h off And turn it on again:
powercfg -h on
Jun 04, 2016 | Computers & Internet
My emachine isn't starting up after hybernation, unless i press the power button and reboot. Why is this?
When your system goes to hybernation it creates a file on the root drive called hyberfil.sys in most instances this file gets corrupted and is causing the computer not to wake up from hybernation.
You would have to try and delete this file so that it will re enable the normal hybernation wake of your computer, here's how to do it:
http://helpdeskgeek.com/windows-7/windows-7-delete-hibernation-file-hiberfil-sys/
Just have to reverse the process to re-enable hybernation.
My recommendation would be to just disable Hybernation and just let the computer go to sleep if you're going to leave it idle.
Hope this helps!
Aug 03, 2011 | E-Machines eMachines Desktop PC
I have a computer running os window 7 ultimate when it on sleep mode it wont turn on any button can somebody please help me thank's
hi there,
please try to go to safe mode and then click start and open computer, hold the Alt key on your keyboard and press T, the tools box should appear then choose folder options.
Go to View, Click show hidden files and untick the three boxes that has the word hidden on it.
Click apply and Ok
Open the C: drive and look for the file called hiberfil.sys delete it and it should work.
To prevent this problem from happening again I would suggest you turn off the hibernate option for your computer.
Hope this helps!
Jul 02, 2011 | Computers & Internet
My asus notebook seems stuck in hibernation.....any help would be apprecited....thanks
you need to delete the "hiberfil.sys" file, prolly in the windows or windows/system32 directory.
you could try to boot form usb using a trimmed-down linux distro, or you oucld take the hard drive out of the netboo, and hook it up as a secondary drive to a working computer.
Jun 27, 2011 | ASUS Eee PC 1005HAG Notebook
What would make an hp laptop w/windows vista not turn on ,even tho its fully charged
So many things. Does it turn on at all or it just won't boot into Windows? If it doesn't turn on at all, remove the battery and run straight from the power cord. Make sure you are getting power to the computer.If you are getting power and the system turns on, but won't boot into Windows, trying booting into safe mode or using a recovery disk to start at a command shell. Remove the hiberfil.sys file and try to restart. The hiberfil.sys is a hidden system file so you'll need to use the following commands;
attrib -r -s -a -h hiberfil.sys
del hiberfil.sys
Try that. I just fixed a laptop last week and I had to delete the hibernation file in order to get the laptop to boot.
Nov 21, 2010 | HP Computers & Internet
My pc is locked in hibernation mode, I think. Powers up, but mouse and keyboard won't respond. What should I be doind? Frustrated.
The best solution I have found for this problem is to remove the hard drive and attach it as either an external drive or internal secondary drive on another PC.
Once your PC has booted up click on the drive in my computer, making sure that it is the secondary drive and not the primary which is usually called drive C.
Make sure your files and folders setting is unchecked in the area called hide extensions for known file types, and hide protected operating system files. This is found by clicking the tools tab on my computer, then folders, then view.
Now find the file called hiberfil.sys in the root directory of the hard drive from your malfunctioning computer and delete it. Turn off the PC, remove the drive and reinstall it in the original PC. You should now be able to start windows properly.
If this method is too difficult or impossible for you to do you can also obtain a copy of Ubuntu and run your PC from the Live CD version. Then you can simply find the drive in the drives directory on Ubuntu and remove hiberfil.sys that way. Restart the PC, after removing the CD and all should be fine.
Oct 29, 2010 | HP Pavilion a320n PC Desktop
My laptop was on hibernation. now it is not booting. please help
Hibernation is enabled by default in Windows Vista, and is one of the seven options (i.e. Hibernate) that appears on the Vista shutdown menu. Hibernate your Vista system will enable you to quickly restore to existing system state and intact workspace instead of start afresh, run programs and open your documents one by one again. If you do not use the hibernate feature in Vista, and want to delete hiberfil.sys and then recover the space occupied by the big hibernation storage file, the hibernation function can be turned off and disabled.
Unlike Windows XP, users cannot turn the hibernation on or off via Vista GUI interface anymore. Previously users can enable or disable hibernation via Power Options applet in Control Panel. This option no longer available in Windows Vista, which also enables Hibernate ability and creates hiberfil.sys by default. Instead, users have to rely on command line utility Powercf and Disk Cleanup Wizard to disable hibernation in Vista. Microsoft KB920730 provides details on how to disable and turn off hibernation on computer running Vista system. You must log on to Vista with user account in Administrators group to perform these action.
Click Start, and then type cmd in the Start Search box.
In the search results list, right-click Command Prompt or Cmd, and then click Run as Administrator on the pop up contextual menu.
If you are prompted by User Account Control for permission, click Continue.
At the command prompt, type the following command, and then press ENTER:
powercfg.exe -h off
Type exit, and then press ENTER.
Another easier workaround for those who’re not comfortable to work with command line is to disable hibernation and hybrid sleep feature in Windows Vista is by using Disk Cleanup wizard tool, the built-in Windows disk cleaner to delete hiberfil.sys file. The hibernation file must be enabled to access the hybrid sleep feature and the hibernation feature in Windows Vista.
Click Start button, then go to All Programs -> Accessories -> System Tools, and run Disk Cleanup.
Choose which files to clean up, either My files only or Files from all users on this computer is fine.
On “Drive Selection”, select the Windows Vista boot drive to clean up. Note that you must select the drive where Vista is installed, which normally is also the boot drive (C:) as hiberfil.sys file will be located on the root folder of it.
Once Disk Cleanup finishes scanning the system, Disk Cleanup for Vista window will open.
Select and tick the check box next to the Hibernation File Cleaner.
You can select or deselect other type files to clean or preserve from the available items or options in the list provided.
Click OK button when done.
Hibernation will now be removed and disabled.
It will solve your problem.
Dec 28, 2009 | HP Compaq Presario V3000T Notebook
How to delete the file ''hiberfil.sys''
http://www.emco.is/download/moveonboot/moveonbootsetup.zip
try this program ...it moves and delete files that are protected at boot...so ...probably after the install a feature will appear on right click pop up ...kinda like the one that allow you to scan a file by right clicking and selecting anti virus run ...I had an earlier version on my pc ...and always worked just fine ...Im not sure about this file cause it appears to be a system file ...but from what I read about this program seams that it doesnt has any problem with any kinda files... so :
install
reboot
select the file / right clic select delete on boot ..
after the ok ...it will be deleted on next boot ...
Jun 16, 2009 | Lenovo ThinkPad T61 Notebook
RE: Phoenix BIOS problem
It may be this file (hiberfil.sys) corrupting the boot .
This link may help you....
http://support.microsoft.com/kb/831691
Nov 23, 2008 | Computers & Internet
Laptop cannot 'hibernate"
Delete the file hiberfil.sys at C:
The file is likely corrupted.
http://www.mydigitallife.info/2007/10/25/how-to-delete-and-remove-hiberfilsys-hibernation-file-in-windows-xp-and-vista/
Sep 16, 2008 | Acer Aspire 4520-5582 Notebook
Computers & Internet Logo
David Payne
David Payne
