Question about Boating
Outboard motor My 40hp outboard motor will start but wont run more than half speed
  • 636 Answers
Check that there are no cracks in the fuel lines, check the wiring harnesses under the hood for wear caused from rubbing against the hood or components hope this helps you out.
Posted on May 11, 2013
mcgyver468
  • 710 Answers
SOURCE: 40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
Posted on Apr 27, 2009
finish line
  • 207 Answers
SOURCE: replace impellor in yamaha 2 cylinder 40hp
take all bolts out on foot were the two mate drop lower unit down pull impellar cover will be plastic some what roun with a short molded inlet on top when u remove impellar be sure not to lose the key way and when u put the cap on the impellar be sure to rotate it so blades will ben\d in place make sure u dont pintch them when u bolt the cover down MAKE SURE WHEN YOU PUT THE FOOT BACK ON TAT YOU LINE UP THE IMPELLAR INLET WITH THE ONE COMMING DOWN FROM THE ENGINE LINE UP YOUR SHIFTER LINKAGE (TOWARD THE TRANSOM IS WERE IT IS LOCATED bolt it up test with a hose should be good
Posted on Jun 27, 2009
  • 53 Answers
SOURCE: I have a 2009 40hp 4 stroke outboard. It sounds
not enough info. what Manufacturers and model? is it out of warranty? here are some troubleshooting tools and procedures since labor rates at your local dealer could be up to $100.00 per hour. before you start I have two Goals for you. (1) If you learn everything you can about your engine you will become more confortable and enjoy it more. (2)confirm that your engine is ok now. is the noise your hearing piston related, or is it ignition missfire. the compression check and the ignition output test will help answer that. Tools(1) A compression gauge (2) a spark gap tester.(3) A Clymer service manual for your engine. (you can purchase from your local dealer). I know all these are expensive but if your going to be a outboard owner you will always need them. Troubleshooting (1) check compression. without the Manufacturer I'm giving you a average numbers. Look at your Clymer manual for specifics. all cylinders need to be over 100 lbs and equal each other within 5 lbs.(2) check spark output. use a spark gap tester. all cylinders should jump a half inch gap. If all these test prove that the basic operation of the engine are within specification, then we can turn to fuel delivery. unfortunately you didn't give the Manufacturer so I can't give you the troubleshoot procedures for the fuel delivery system. you will need to refer to the manuel. please get Clymer manuel you will apreciate it
Posted on Nov 04, 2009
  • 43020 Answers
SOURCE: 1985 40hp evinrude only runs at half speed
it might be as simple as a dirty carb , but also might be in the ignition ,like a bad power supply module . check for spark on but plugs .
Posted on Apr 25, 2010
dcurryn601
  • 60 Answers
SOURCE: I need to see a
Go to Boats.net and you should be able to look up your parts
Posted on Jul 25, 2011
85 40hp evinrude stuck in forward?
Evinrude used a shift mechanism located in the lower unit that is actuated by a rod up to the linkage in the motor housing. It could be stuck anywhere along the way or the gear that shifts on the shaft could be immobile due to rust and corrosion.
You may want to find a blowup of your exact model via a Google search. Then starting from the top look for your problem. be sure to mark the position of anything adjustable so you can at least get it back to the original position when you reassemble it.
Find 1985 40hp Johnson Evinrude Outboard Motor Parts by Model Number
Feb 06, 2015 | Light Outboard Motor Boat Bass Fishing...
Boat motor
hi my 40hp selectric outboard motor won't shut off by key and no speed once engage throttle full,also high reve on off position.
Jun 22, 2013 | Boating
I have no spark on 1989 7.5 evinrude outboard motor
Hi have you tried it with the stop switchl/button disconnected, if so you have only got the stator under the flywheel left to replace, regards Phil.
Jun 04, 2012 | Boating
40hp mariner sluggish
compressions more than 100psi ? carb clean and fuel not older than 5mths ? timing correct ? running on all cylinders ?
Mar 06, 2012 | Light Outboard Motor Boat Bass Fishing...
Free download for repair manual for an Evinrude 1987 40HP outboard motor
My outboard motor is old and used.When I went to run it for the first time everything worked except when I went to put it in forward gear the boat went slowly but when I gave it more gas the engine just reved up but the boat wasn't going any faster.The motor is 40hp gale model.I think because it is bought used the prop is not the right one and it seems like it's slipping as I go faster.
I would appreciate any feedback on this problem.
Thax, Don
Apr 27, 2011 | Clymer Marine Maintenance and Repair...
Apr 25, 2010 | Light Outboard Motor Boat Bass Fishing...
Apr 27, 2009 | Boating
Boating Logo
54 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Boating Expert? Answer questions, earn points and help others
