Question about Trust SoundForce 5.1 Surround Speaker Set SP-6400M
Http://www.altasbilgisayar.com/ I am having a problem that I got on this site does not sound from both speakers
2 Suggested Answers
SOURCE: TRUST SP-3100 2.1 Computer SPEAKER set they are powered up (how to actavate)
install the audio drivers...
the audio codecs are missing as u didnt install that drivers.........
Posted on Feb 11, 2008
Why is it intermittently losing channels...front speakers and or rear surround?
How to troubleshoot low sound or no audio from the rear ...
https://us.en.kb.sony.com/.../how-to-troubleshoot-low-sound-or-no-audi...
Aug 15, 2015 - Verify that the rear surround speakers are properly connected to the ...For Dolby® ProLogic surround sound, the center-channel mode must be set to ... the center or rear surround speakers for the Home Theatre (HT) system.
Why Are My Speakers Producing Static? - Electronic House ...
www.electronichouse.com/.../home-audio/why-are-my-speakers-produci...
Here are 3 reasons that speakers produce static and solutions you can try. ... If they are your dedicated front L/R channels speakers in a 5.1 or 7.1 system, you more ...Since you have no problem with your existing rear speakers, if they begin to distort on... Home Theater Subwoofer Puts Boom in This Room · Soundbase vs ...
How to Check if your Speakers are Wired Correctly ' Richard ...
www.richardfarrar.com > Podcasting
Mar 25, 2009 - Attaching speakers to your Hi-Fi system usually only requires a few cables. ..... Is this test applicable for a home theater setup with 5 speakers? ... frontstereo speakers, but to do a similar test on your rear surround speakers would ... Yes, switching polarity on one channel of the amp output to your speakers ...
Pioneer VSX-816 speaker drop out - AVS Forum ' Home Theater ...
www.avsforum.com/.../1068233-pioneer-vsx-816-speaker-drop-out.htm...
Sep 20, 2008 - 30 posts - ‎24 authors
The right front speaker sound drops out intermittently as of about 6 months ago. ...mode and back to Auto Surround would bring the center channel back. ... the push pin that holds several grey wires in place, and pull the wires loose. 9. ..... Is it possible that the cold joints are elsewhere in the system, but that ... Yamaha RX-V663: Intermittent/No Audio in Front ...
Jan 23, 2014
Sony Receiver going in to Protect Mode
Jan 12, 2012
The Official Sony STR-DH820 Thread
Aug 29, 2011
Denon AVR-1910 - No more sound.
Feb 15, 2011
More results from www.avsforum.com
Dec 12, 2015 | Audio Players & Recorders
Tip
How to set up a six speaker home theater surround sound system
This walk through is for a six speaker setup but can be used for any type. First you will have a sub., a center speaker, a surround L and R, and a front L and R. Most likely your speaker wire (silvery wire) will have a colored tip at end. This tip will show where the wire fits into the bluray or DVD player and what speaker it goes to. I am going to use the Surround Right or S.R. as an example because most the speakers are very similar to set up. The S.R. is (at least for me) a smaller black speaker with a gray sticker on the back indicating what wire should be use for it. The S.R. should be hung behind the main seat (Sofa, Chair, Etc.) and to your right side. and the wire should be ran around the ceiling to the DVD or Bluray player (its good to hide it behind wall edging or pictures) and then fit the colored piece at the end of the cord into the correct colored slot at the back of the player. If necessary use a staple gun to attach the wire to the the back of the wall edging (make sure the staples are not visible because I guarantee you won't want it there forever. Also, make sure to not tear or puncture the wire with the staple. Repeat this step for all the other speakers. Your setup should look some thing like this
Left Front Sp.////////// Center Sp. /////////// Right Front Sp.
//////////////////////sub. (directly below)////////////////
...................................Sofa.........................................
Left Surround ////////////////////////////////////// Right Surround
on Dec 04, 2009 | Audio Players & Recorders
No surround sound on rear speakers and cant access speaker set up functions. left front channel not working when rears set up without surround
from the problem description, it sounds like a wiring/setup problem with the speakers. check to make sure you are only using the main 'a' front r & l speaker connectors. if you select speaker set a + b on the front, you will not have the rear channels. please see the speaker connection guidelines in the manual on page 13-15. make sure the audessey mike and/or headphones are not plugged in when trying to use the speaker set up function.
manual: http://www.uk.onkyo.com/downloads/1/1/9/7/8/21637363_df4adc7f5e.pdf
Jan 21, 2015 | Onkyo TX-SR307 A/V Receiver
I need help trying to set up the surround sound for my vr-390 receiver. i have two two large side speakers. a large middle. and a subwoofer i cant get to work. (all kenwood) i also have 2 bose surround...
Manuals help. Read them. Nothing in your receiver is actually a multichannel source so you'll be needing to understand the external sources that originate that kind of programming. Manuals.
Here's one...
http://www.retrevo.com/support/Kenwood-VR-309-Receivers-manual/id/480dj195/t/2/
Try the other manufacturers' support sites for your unidentified gear, by using a common search engine or these guys...
retrevo.com
audio.manualsonline.com
hifiengine.com
usermanualguide.com
vinylengine.com
Search Engine of your choice: "(product) manual"
'Large' is not literal in the context of Bass Management. It refers to the ability of a given speaker to handle REAL bass. Yes = Large, No = Small. 'Small' redirects bass from that speaker channel to the sub.
Web search concepts like bass management, speaker placement, multichannel sound, digital audio, etc.
Sep 05, 2011 | Kenwood VR-309
SURROND SOUND
i would suggest alpines new 5 channel suround amplifier that has dolby 5.1 decoding and you will also have to have a head unit that supports 5.1 surround sound which as far as i could tell are only indash dvd players you will also need to purchase a center channel speaker as well
you can follow this link to the alpine amp
http://www.crutchfield.com/p_500MRAF350/Alpine-MRA-F350.html?tp=115
hope this helps
sincerely
justin
May 17, 2009 | Car Audio & Video
My Yamaha HTR-6050 shuts off at random times and says "Check SP Cable"
i think it means speaker cable?
http://www.fixya.com/search/p514076-yamaha_rx_v2700_7_1_channels_receiver/check_sp_cable
Apr 23, 2009 | Yamaha RX-V757 Receiver
Primary speaker output jacks don't work
here in your manual http://www.fixya.com/support/p235198-kenwood_vr_409_receiver/manual-19163/page-14 on step 8 you need to make sure this is set to normal or large speakers for the surround speakers
here shows how the surround speakers are to be connected http://www.fixya.com/support/p235198-kenwood_vr_409_receiver/manual-19163/page-12
and dolby digital will not work unless the device connected has the coax or optical digital audio connection connected
Jan 03, 2009 | Kenwood VR-409 Receiver
How do you set up surround sound for DVD playback in windows xp?
Do you have 5.1 speakers? Becouse you need to plug in all the 5.1 speakers to the differnt ports on your soundcard. If you only have 2 speakers you wont be able to get the 5.1 surrond sound your after and it will default to 2 speakers. If you do have 5.1 speakers then you will need to check the option in the control panel in the M-Audio window. It has an option for 5.1 surround. If your software cannot play 5.1 surround them get some other software that can.
Sep 20, 2006 | M-Audio Delta 1010LT Sound Sound Card
Trust SoundForce 5.1 Surround Speaker Set SP-6400M Logo
18 people viewed this question
Top Trust Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Trust Audio Player and Recorder Expert? Answer questions, earn points and help others
