How do I factory reset my xenta hdmi media player DMA238
When plugged in shows no signal need to reset settings
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window. It will make search easy. More than Nine Lakh viewers cannot be wrong.
Posted on May 08, 2013
Roku stick dosent do anything. ...? Plugged into hdmi slot on tv and also plugged in power cord to roku and nothing pops up on my tv...? Iv tryed to reset but dose nothing. ... help???
Did you change the TV input setting on your TV to the correct HDMI input? Most Televisions will take a few seconds to scan the input before displaying any image. Most newer televisions have multiple HDMI inputs, and you might need to select each one, wait several seconds to see if there's a signal, and then move on to the next input, until you find which HDMI input has the Roku start screen signal.
Dec 09, 2014 | Televison & Video
How to factory reset the device
There is a setup mode you can use to set the player back to factory default settings. From the main menu, just hit SETUP. In there, there should be an option called Load Default. This puts all the settings back to factory defaults.
From there, it's just a matter of deleting everything out of your Media and Data folders. Just plug it in to any computer and delete the contents of those two folders.
Oct 23, 2012 | Coby MP815 Digital Media Player
Need to reset my mp3 player to factory settings
The LCD screen "might" be loose. It might need servicing. But first, try removing the battery and then replace it back and see if that will fix it.
Jan 31, 2012 | RCA M4304 Digital Media Player
Plugged in hdmi from console to tv .went back to original cables [no signal] only works hdmi
try to reset it ..or ..open it 's settings ..using the hdmi cable ..and select the other one and restart ..after that plug the one you want to use and will work ...resetting it to the original factory settings will work too ..but will make you loose user data ..and such ..
http://www.tech-recipes.com/rx/2265/ps3_how_to_factory_hard_reset/
here is the video resetting and it will work too ..this way you will avoid the hard reset and loosing data ..
http://www.portfolioofpb.com/blog/ps3-blank-screen-switch-inputs-hdmi-to-composite-to-hdmi
You basically shut it down ..than when you power it up ..keep the power button pressed until you hear the second beep ..This was the signal telling you the video settings are reset . and it will work with the AV cables..
Aug 03, 2011 | Sony Playstation 3 (PS3) Console
The hdmi wont work the av works I have tried all three hdmi plugs on the the tv and it says no signal could you please help everything I have is setup for hdmi
Tries tv and those cables or satalites boxes unplug,replug it back like about an hour later for those pay boxes to reboot and upgraded it softwares.Tv to do a whole resetting itself back to the factory setting.Than go into the tv Menu.Go into Video Setting,go down and do a resetting back to factory setting.By doing this steps for every components devices that hook to the tv HDMI hubs ports on the tv Tuner signal board to reboot and resetting too.Have very good chances all the HDMI hubs ports on the tv to work again.
Jun 26, 2011 | LG 42LC2D 42 in. LCD HDTV
Player turns on ok,display shows menu that disc is playing but tv says there is no signal, not seeing home screen with net flixs or the other apps.player has been working great we used it 2 day earlier...
The "handshake" between the television and the blu ray player has been lost. This happens a lot when connecting with hdmi. Sometimes a hot swap will work to remedy this. That is turning off and unplugging both your television and bluray player while removing the hdmi cable from both for 30 seconds to one minute. Reconnect the bluray player to the hdmi cable and then to the television. Plug them both back in and turn the television on first then the bluray player. Your television may need a factory reset going into the service menu or the board the hdmi ports are located on might need to be replaced if all of the hdmi ports are not responding. You can connect with component if possible in the meantime.
Apr 14, 2011 | LG BD390 Blu-Ray Player
I have my DirecTV box and DVD player hooked up to my 32" TV and our sound is awful. I went in and did a custom sound but we have to turn it up into the 60 and 70 volume range just to hear a show. ...
Tries tv and direct tv box unlpug,replug it back like an hour later.The tv now,will reset itself back to the factory setting and the box now,will resetting itself and upgrading it softwares.The DVD player is it hook up by a HDMI cable?If not,yes hook up the DVD player by the HDMI cable.These steps u tries,should have a great chances for the audio out,will resolved itself and work fine and normal again.If all these steps are taken,still have the same results.Than the tv Tuner signal board is the causes and the problems.That the board,where the incomming broadcasting signal wire plug in and external devices plug in it.If u require the replacement of the Tv Tuner signal board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tv Tuner signal board for the replacement.If u require buying a HDMI cable?Yes,tries websites like Amazon.com,Ebay.com or ur local Walmart,Target,Radio Shack stores.
Dec 02, 2010 | Samsung LN32A330 32 in. LCD TV
My Philips 42PFL5332D has quit playing my Sony Blu Ray player (model BDV-T10) it was working fine, I finished watching one movie went to put in another and it wouldn't work. Thought it was the Sony,...
Tv still working,with the incomming broadcating tv signal cable plug in,working is fine wright?Tries tv unplug,replug the tv back like an hour later.Let the tv resetting itself back to the factory setting.Go into the tv Menu goto PICTURE,go down to reset the tv Tuner signal board,that to reset the whole entire Tuner signal board back to factory setting,now all the incomming plug&play like the HDMI ports on tv,should work now.Not,than i can't tell what happen to the tv exept the tv Tuner signal board have problems,that it.
Oct 26, 2010 | Philips 42PFL5332D 42 in. LCD Television
Televison & Video Logo
95 people viewed this question
Top Televison & Video Experts
Electro Med Services...
