Question about Dell Printers:Dell MFP Color Laser 3115cn
My Dell 3115cn MFP prints 3 blank pages between prints or copies if I print more than 1 copy how do I fix this? What is causing it?
Every time I hit print it prints what I printed followed by 3 blank sheets of paper. I haven't made any changes to it and I don't know why it started doing this. Does anyone know what is causing it or how I can fix it??
  • Dell Master
  • 7,733 Answers
I will do first a full printer cleaning, that mean take off all dust and anything can that can be inside the printer (ex.bugs and dirt accumulation).
Second try to locate the printer rollers and check if they are in good condition.Printer rollers need to be in good condition because those are the parts that move the paper inside the printer.
Also when you feed the papers into the feeder make sure you air the paper so they don,t stick together.
Posted on May 07, 2013
SOURCE: Prints Blank Pages
i was having these same exact problems then i looked at my old ink cartridge and saw that the blue tape was off and that i hadnt taken it off my new one i was trying to print with.!!!
Posted on Apr 18, 2008
  • 41 Answers
SOURCE: My printer is printing a blank page(DELL 1720)
hey
might be possible the cartigies of the printer has gone bad ,,take the cartiges out and then try to reset the computer and check that wether the things are working or not .
or else try to get in touch with me on fixya
Posted on Jul 22, 2009
  • 159 Answers
SOURCE: Dell 1815dn prints a blank page. The toner is
Almost sounds like the imaging unit. What functions can you use where it works ok?
Posted on Oct 25, 2009
SOURCE: Dell A940 won't print black. New cartridge,
printer won't print black with new cartridges installed
Posted on Jan 14, 2010
  • 525 Answers
SOURCE: my dell 3115cn prints blank
Inspect the laser module. Can be in dirt. Must be clean inside.
Posted on Jan 21, 2011
My m4345 mfp sends a blank page after print job. How to fix this?
Does it do this on all jobs? If yes, look for a function either in the general setup of the device or the driver for job separation. Having this function on causes the printer to print a blank page between print jobs to help separate them. This not to be confused with the job separation function of the 3 bin sorter where print, fax and copy jobs come out in different bins.
Jan 26, 2015 | Office Equipment & Supplies
What would make a printer only when making a copy or scanning put blue on paper? When printing its not there why?
The Dell 3115 (and Xerox 6180 multifunction, and Lexmark X560) all have a common problem with the INSIDE surface of the scanner platen attracting a deposit. This makes it a little 'cloudy' to look at, and produces a bluish tint to colour photocopies.
Print a test page from the printer that includes colours from all four cartridges. Then make 2 photocopies - one using the document feeder, and one using the flatbed. One may be better than the other - as a work-around.
The REAL solution is to clean the inside of the scanner platen (glass), but you must be very careful, otherwise you'll trash the printer. It is a very complex procedure to remove the scanner platen completely. It can (with great care) be lifted from the front, being very careful not to strain the cables. It can be cleaned successfully.
Apr 30, 2014 | Dell Printers:Dell MFP Color Laser 3115cn
Magenta toner spots pages
Step 1:
Print out about 10 blank (all white) sheets and see if the spots clean off.
Step 2:
Check to see if the toner is Dell type brand, if not try installing Dell brand and run 10 blank copies then run color test print using menu key.
Press menu, press arrow down key till 'print reports' is displayed, Press 'check key' then press down key till 'color test print' Press check key to print color copy.
Apr 10, 2013 | Dell 3010cn Laser Printer
Hp 5035 mfp printing black pages only
The DC Controller board is going back and causing the laser beam to run continuously causing the photosensative drum to be in a neutral state which causes the black pages.
May 08, 2012 | HP LaserJet M5035 MFP Printer
HP CM2320 MFP blank pages come out with printout
Hi my hp cm2320 nf prints normally and prints when you press the color copy button. But it will printout only blank page swhen you copy black&white. You press the black&white copy button only blank pages come out. Any help
Lang Dibba, Gambia
Jan 30, 2012 | HP Laserjet CM2320nf All-In-One Color...
I have a dell mfp 3115cn copier, fax, scanner. Th...
the fault is a mark on the glass over which the paper passes when being copied. it is the rectangular glass that is probably only 1cm wide but the full A4 length across the screen. Clean the mark off this thoroughly and voila, fixed.
Bristolprinters Ltd - with compliments!
May 21, 2010 | Office Equipment & Supplies
99 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
