Question about Cub Cadet Op's Manual Model Lt1042 Lt1045 Lt1046 Lt1050
Tractor is dead.
My battery died. I went to Home Depot and they recommended the battery for 20HP and above. I installed it and it worked.
Then I let the tractor run for 4 minutes and it just died. No lights, nothing. What do I do?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 107 Answers
Charge the battery start tractor and check the voltage at battery terminals should min 12volts and rise to about 13.8volts if not charger is RS
Posted on Nov 22, 2013
  • 640 Answers
SOURCE: I have a series model 1018 cub cadet with electric
If you have access to an electric voltmeter, with it running check voltage at the battery. The engine should charge the battery and maintain system voltage so that the electic PTO will function. The electic PTO will not pull in if system voltage is too low.
Posted on Jul 08, 2011
  • 6468 Answers
SOURCE: Does a Cub Cadet Model 1170 lawn tractor charge it's battery ?
when a engine has factory electric start it will have a charging system but it is only a couple amps keep in mind a small mower battery is only good for a couple years
Posted on May 14, 2012
philwalker78
  • 608 Answers
SOURCE: cub cadet series 2000 stops running after 20 minutes cutting
Hi, check that you have spark. they are renouned for doing ignition modules in. Regards Phil.
Posted on Jun 01, 2012
  • 6468 Answers
SOURCE: i have a 1541 cub cadet, when I switch on the pto nothing happens
check for power going to the clutch i have seen the wires break going into the clutch under the engine
Posted on Jun 30, 2012
  • 6468 Answers
SOURCE: 2010 Cub Cadet LT1050 suddenly dies when blades engaged
check the safety switch on the seat
Posted on Sep 03, 2012
2001 Dodge intrepid. Battery light came on while driving. Got home turned car off, tried it and it was completely dead. put new battery and fuse in . still just clicking. what else could this be?
Pretty sure your alternator died.
Battery voltage with the car not running should be close to 12.5 volts on a fully charged battery. New batteries need to be charged before they are installed to keep a good alternator from melting down and dying.
With engine running the battery should read about 14.5 volts indicating your alternator is charging. At lower rpms battery voltage will still be above 12.5 volts with the engine running.
If you get it cranked and the battery does not read above 12.5 volts, you have a bad alternator.
Sep 14, 2017 | Dodge Cars & Trucks
What is causing the battery to drain?
Most likely a bad alternator..batt isnt gittn chargd. The diode is bad causing the alt to suck juice from batt. Also the main wire from battery to back of alternator I wud test first for wear. A bad one impedes chargn
Dec 04, 2015 | 1989 Eagle Summit
Cub cadet lt1045
Did you check voltage on the battery, and did you leave it running at a high idle? (low idle can consume battery voltage instead of charging it.
On many tractors the lights do not run unless the motor is running so don't let that throw you off.
Things to check
Make sure no fuses popped.
Makes sure you have gas
Try jumping it to see if it starts If not, it sounds like you may have a short, or may have a safety switch that is acting up. look for loose, broken, damaged wires.
Check to see if any wires are hot when the battery is fully charged. Try that and repost what you do or don't find.
May 07, 2013 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Just bought a John Deere d140 had it delivered by home depot. Went to turn key, tractor completely dead. Lights won't even turn on. Looked in manual says to charge battery. What do I use to charge this...
are you pressing down the clutch/brake pedal? is the pto switch turned on?are you sitting on the seat?the lights only come on while its running not with the key turned on
Apr 30, 2012 | John Deere Garden
My lawn tractor died and now is readind dead but the battery is new
Sounds like your charging system is burnt out or your battery cables wheren't tight enough when you reinstalled your new battery and as soon as you started it the first time and you ran the battery down it didn't charge, take the cables back off and clean them greese them up and put them back on and tight them up and charge the battery up and you should be good to go
Jul 27, 2011 | Toro LX423 20HP Lawn Tractor 13AX90RS848
I have two different cordless 21.6 volt drills that have died within a week of one another. The first went from doing fine with a hole-saw blade to completely dead, and the second, i think the bearings...
Take back and get rigid tools from home depot,gauranteed for life,if you have money buy hilti tools,offerd by home depot,been using hilti tools forever,there the best but spendieee
Jan 26, 2011 | RTO 21.6v Kawasaki 4 Piece Cordless Power...
Lt1000 20hp. briggs electrics on carb it will run when you pour i
Check fuel lines for clogging.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 13, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
I have a Husqvarna 21 HP Lawn Tractor and I went out to start it and the battery was totally dead, so I jump started it. It started but died out a couple times. So I got it going again and drove it up the...
The electric clutch needs full power in the battery to stay engaged. I would recommend you check your charging system before replacing the battery. Put a digital volt meter across the + and - terminals of the battery and while running at about 1/2 throttle you should be over 13 volts DC. Probably around 13.5 or so. If not you have a charging problem. Lawn mower batteries I have seen seem to last only 2-3 years. I would also recommend a trickle charger for extended periods of non use. Don't forget the Stabil also.
Hope this helps.
Jun 27, 2010 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Cub Cadet Op's Manual Model Lt1042 Lt1045 Lt1046 Lt1050 Logo
139 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
