Question about Ovens
Wiring diagram fridgemaster fm 15 - Ovens
Samet model 611 stove wiring diagram
Request the diagram directly from Samet.
Aug 08, 2016 | Stoves Ovens
Hi, Looking for a wiring/electrical diagram for Neff D39F56S0GB Extractor hood. Or could you Kindly point me in the right direction. Thank you
You can find the manual here:
D39F56S0GB/01
and here:
D39F56S0GB/02
It should come with a cable attached which should conform to standard wiring colour codes.
Red/Brown = Live/Feed
Black/Blue = Neutral/Return
Green/Green & Yellow = Earth
If the standard cable has been cut off there is a good chance it was for a reason and you shouldn't try to connect it without knowing how to determine which contact is for which (an electrician/electronics tech will know within seconds what should be connected where.)
Mar 07, 2015 | Neff Ovens
Wiring diagram for a Kelvinator DeVille eye level oven Model B305, Serial no 3674
Request the wiring diagram directly from Kelvinator.
Jun 25, 2014 | Ovens
Wiring diagram stove
That is an older model, so the wiring diagram will be harder to find. Have you already checked the manual? I would also suggest checking online at the manufacturer's website. Other than that, you can try online.
Elisa Jed ' http://www.atlasappliances.com
Jun 22, 2014 | Ovens
Wiring diagram of a Satchwell type70th thermostat switch
need wiring diagram for defy gemini petit chef oven switch
Dec 07, 2010 | Ovens
Need a diagram of wiring for a gas wall oven to
As far as I know almost all kitchen appliances have a wiring diagram of all electrical connections. usually found on either of the side panels(if they are removable) or inside the control panel where the temperature and the rest of the knobs are located, but if yours does not have one you will need your oven make and model number and refer to the following websites for the diagram : www.partselect.com or www.repairclinic.com.
Jan 29, 2010 | Ovens
I need to convert from 220 to 110
Look at the diagram on the name plate. It will say 'high' and 'low' and show some numbers. The numbers are the wire numbers on the motor leads that need to be joined together for the low (120) volts.
Nov 05, 2009 | Ovens
What is blue wire on ge built in oven for
The blue wire goes to a seperate 15 Amp circuit breaker or fuse.
This breaker should be powered by the L1 (black) supply feed in the breaker box. The circuit supplies power to the display and control buttons. The red and black wires go to a double ganged 20 Amp breaker. Check inside the oven back cover for a wiring diagram.
Sep 07, 2009 | GE Profile 30" Built-In Single Electric...
Wiring diagram for jtp18
Call GE at 1-800-626-2005 to get a wiring diagram
Regards,
Powerman
Oct 26, 2008 | GE Profile JTP18 Electric Single Oven
HOBART AM14F wiring diagram
I can tell you where the wires need to go.What are you trying to hook up on the dishwasher?
Feb 23, 2008 | Ovens
Ovens Logo
55 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
