Question about Cub Cadet Op's Manual Model Lt1042 Lt1045 Lt1046 Lt1050
Cub cadet lt1045
MY BATTERY WAS DEAD, I WENT TO HOME DEPOT AND THEY RECOMMENDED THE BATT FOR 20HP AND ABOVE.I INSTALLED IT AND IT WORKED!THEN I LET THE TRACTOR RUN FOR ABOUT 4 MINUTES AND IT JUST DIED, NO LIGHTS NOTHING, DEAD.WHAT DO I DO?
    Novelist:
    Scholar:
  • 80 Answers
Did you check voltage on the battery, and did you leave it running at a high idle? (low idle can consume battery voltage instead of charging it.
On many tractors the lights do not run unless the motor is running so don't let that throw you off.
Things to check
Make sure no fuses popped.
Makes sure you have gas
Try jumping it to see if it starts If not, it sounds like you may have a short, or may have a safety switch that is acting up. look for loose, broken, damaged wires.
Check to see if any wires are hot when the battery is fully charged. Try that and repost what you do or don't find.
Posted on Nov 15, 2013
  • 514 Answers
SOURCE: i need the drive belt diagram of the cub cadet
go to this address for the manuals http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10051&langId=-1 you will need the model number and the serial number as well. good luck!!
Posted on Nov 21, 2010
ToolBoxHero
  • 171 Answers
SOURCE: i don't want to talk to an expret , I lost my
OK, I won't talk :)
Here is the direct link: http://www.hammerwall.com/Download_Manual/13295/ if the link gives you problems do the following.
Go to www.hammerwall.com and put in Cub Cadet lt1045
Posted on Jan 14, 2011
woobie dog
  • 1273 Answers
SOURCE: I own a Cub Cadet Hydrostatic Lawn Tractor, not
Hello, W/D here.
Without a particular model number, I'll have to be somewhat generic, so forgive me in advance.
The fact that the mower will run and the blades will engage is good news; it eliminates about half of the things that would need to be checked.
Look for a lever at the (usually) back of the tractor, on the back plate, down low. Sometimes called a range selector or a disengagement lever. Normally, the position of this rod is "IN". If it has pulled towards the "OUT" position, the transmission is disengaged. Usually this rod is pulled out when you want to push the mower, and I expect you're tired of that by now! Chech and see if this is the issue, and post back if not.
Regards, --W/D--
Posted on Mar 07, 2011
  • 252 Answers
SOURCE: I have a 2007 Cub
hi there pauly46 here your model 2007 and before lt1045
take a look at this web site
http://www.partstree.com/parts/?lc=cub_cadet&mn=LT1045+Tractor+%282007+%26+before%29
this takes you stright to transmssion / belt drive system
http://www.partstree.com/parts/?lc=cub_cadet&mn=LT1045+Tractor+%282007+%26+before%29&dn=0125500003
this diagrams shows belts etc in the drive system , fan, trans etc
your answer is it does have a trans belt it is part number 954-0461
was pt number 754-0461
take a look at this site
cheers hope it helps
pauly 46
Diagram: LT1045+Tractor+%282007+%26+before%29 Drive System 1I136H & before CUB Cub Cadet 954-0461 (replaces 754-0461)
Posted on Apr 30, 2011
Testimonial: "This was very helpful thanks pauly 46 "
SOURCE: My drive belt broke on
My cubcadet is a LT1042. A 2004 i think. I need a daigramof the drive, so I can take it off and put a new one back on. Thank You.
Posted on Jul 01, 2011
Troubleshooting
maybe bad sending unit most likely or bad oil pump
Jul 31, 2014 | Cub Cadet Garden
Solenoid clicks cub cadet lt1045 mower won't start. Has new solenoid, starter battery and spark plug
It is possible the starter safety circuit is triggering. This is an interlock to prevent injury when starting and checks for things like driver not on seat, park brake engaged, etc.
Refer page 12 of the manual available on this site if you do not have one.
http://data.manualslib.com/pdf/4/341/34016-cub_cadet/lt1045.pdf?6c17c6482511338711d5965e5bb6681c&take=binary
Apr 23, 2014 | Cub Cadet Garden
Tractor is dead.
charge the battery start tractor and check the voltage at battery terminals should min 12volts and rise to about 13.8volts if not charger is RS
May 07, 2013 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Left rear tire has rust color leak
Sounds like a seal has went bad allowing water to enter trans case. I would suggest taking to a cub cadet shop and letting them check it out.
Sep 22, 2012 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
I have a 2007 Cub Cadet Series 1000 Model LT1045 Does this model have a drive belt or is that belt just to run the fan on the tranismission.
pauly 46
Apr 29, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
Mower has fully charged batt while trying too start it just clicks at the solenoid and then a humming sound but nothing from the starter it self ltx 1042 cub cadet any help would be great thankyou
Sounds like your going to need a new starter. They're not to much you should be able to buy one at your local lawn and garden store, and they're very easy to replace.
Feb 07, 2011 | Cub Cadet Op's Manual Model Lt1042 Lt1045...
I don't want to talk to an expret , I lost my manual and I need one to repair my Tractor Cub Cadet lt1045
OK, I won't talk :)
Jan 14, 2011 | Cub Cadet Garden
Cub Cadet Op's Manual Model Lt1042 Lt1045 Lt1046 Lt1050 Logo
126 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
dannydoesita
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
