Question about IBM Computers & Internet
Bypass power switch - IBM Computers & Internet
  • IBM Master
  • 7,627 Answers
I don't understand the question?
Posted on May 08, 2013
Testimonial: "Hi, just saw that you responded, thanks. My IBM powers on fine, but won't boot up past the initial startup page, and eventually just goes back into power saving mode and stays there unless I turn the power on and off again. I am trying to find a way to bypass that startup page and get it to boot up hopefully. "
How to bypass on off switch. the wire is still there but is there a way i can bypass the switch
Switcht probably provides continuity to a ground in the coil when set to off. So to stop grounding the wires do not connect at the switch. Bypass would be be simply snipping wires to switch. Now it will run always. Check it with a continuity before you do anything permanent.
Sep 14, 2015 | Electrical Supplies
Liebert gxt2-10000t230 low batt,bypass light flashing,no output,shutdown after a minute
Test outlet power by switching the unit to manual bypass and breakers off.
If power is supplied OK and the filter board repaired OK then restart the unit starting with the breakers supply to unit,battery confirm the display is on and static bypass led also on then switch back the bypass knob to normal and press the on button to switch the unit to normal.
Give the batteries time to charge 12hours then you can test the unit on backup mode.
Nov 25, 2014 | Liebert (GXT2-10000T230) (GXT2-10000T230)...
Bypass power switch
You should simply purchase and install a new switch. It's not safe to bypass the switch as when you do, the entire electrical load is placed on the wall prongs when you plug in or unplug the vacuum. Depending on the brand of vacuum, you can easily order parts and replace the switch at a nominal cost.
Nov 08, 2013 | Shop Vac Vacuums
I'm working on a 97 geo prizm and need to find the ignition relay,I rplaced the ignition switch and have no power getting to the switch,there is power at the harness and I can bypass the switch an
If you can jump it at the switch and get it to start, then the ignition relay must be working. It is hard to tell from your post but I think you are using power from another source to do this? I am thinking you have a blown fuse on the wire the furnishes power to you ignition switch.
Feb 12, 2012 | 1997 Geo Prizm
How do you wire the ecm 175 bypass timer
http://www.icmcontrols.com/Prodimages/ig_LII271-1.pdf
The power to the equipment that will be running goes onto terminals 2 & 3.
Come off terminal 1 to bypass the switch (such as a pressure switch).
Use the time setting from the old timer.
When equipment is turned on, the Icm allows power to go around the (pressure) switch for the set period of time. After the timer times out, power goes back to the pressure switch and by now the the pressure switch controls.
Gary
Sep 02, 2011 | Icm 175 Bypass Timer
Emachines pc will not power up. Outlet that it's plugged into is powered.
Suggestion is to bypass the Soft Power On of the Power Supply, and see if the problem is the Power On switch, or the Power Supply.
(The Power On switch is located inside the plastic Power On button.
This is an example of a generic Power On switch, that I have found fits many computers,
http://www.directron.com/atxswitch.html )
If bypassing the Soft Power On turns the Power Supply on, the problem is a bad Power On switch.
If bypassing the Soft Power On does Not turn the Power Supply on, the problem is a bad Power Supply.
Should you wish to know how to perform this procedure, just state so in a Comment.
(Believe upper right of your page)
Jun 16, 2010 | E-Machines eMachines Desktop PC
Emachines T2893 , will not power on, there is a small green light on inside on a board.
Suggestion is to bypass the Power On switch, to see if the problem is the Power On switch, or a bad Power Supply.
If upon bypassing the Power On switch, results in the Power Supply coming on, the problem is a bad Power On switch.
If bypassing the Power on switch results in the Power Supply does Not come on, the problem is a bad Power Supply.
I would like to refer you to a previous problem, that I just gave a solution to concerning this,
http://www.fixya.com/support/t4915632-compaq_presario_sr1620nx_desktop_turn
May 31, 2010 | E-Machines eMachines Desktop PC
How to take ups in manual bypass mode.
You definitely want to follow the manual procedure to avoid a possible load loss:
http://powerquality.eaton.com/Products-services/Backup-Power-UPS/9390.aspx?cx=3
9.1.4 Transfer from Normal to Bypass Mode
To transfer the critical load to Bypass mode:
C A U T I O N
In Bypass mode, the critical load is not protected from commercial power interruptions and abnormalities.
1. Press the CONTROLS pushbutton on the main menu bar. The System Controls
screen appears.
2. Press the BYPASS pushbutton on the System Controls menu bar.
The UPS transfers to Bypass mode and the critical load is immediately supplied
by the bypass source. If the bypass source is not available, the power processor
remains on and an alarm sounds.
3. The UPS is now operating in Bypass mode and the BYPASS status indicator is
illuminated.
The power module (PM) status indicates READY. The system is now on bypass
and the UPS power processor remains on.
At this point, you can operate an external bypass switch to get to maintenance bypass if needed.
Oct 14, 2009 | Eaton PW9390 UPS System
Attaching a generator to Powerware 9120 UPS
Power ware has a powerpass bypass switch for $200.00.
There is two inputs on this bypass switch. One for power, and one for the generator.
One ouput for your UPS. There you have it... There is your soluiton. I might add one other thing called a Power Guard, PMM117, to monitor the power of the backup generator. The time delay of this device will prevent over current from cooking your UPS power supply.
They also have a Hardwired version that is more expensive for you 5, 6 ,10KVA UPS. So a automatic bypass switch is what you need.
Jul 15, 2009 | Powerware Invensys 9120 Model 1000i...
How do i bypass the brake safety switch on a pionner avh-p4000
CONNECT A SWITHC TO THE PARKING BRAKE WIRE ONE OF THE PINS FROM THE SWITCH TO GROUND AND THE OTHER SIDE TO THE PARKING BRAKE WIRE.
Mar 14, 2009 | Pioneer AVH-P4000DVD Monitor
Computers & Internet Logo
26 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
