Question about Timex Ironman Watches
My Timex Ironman Triathalon Model T5H581 beeps loudly for about ten seconds at very random intervals. This is embarassing in meetings. How do I get it to stop that.
The watch beeps randomly and loudly for ten seconds or so and I would like it to quit this but nothing seems to work.
  • Timex Master
  • 18,394 Answers
  • 39 Answers
SOURCE: TIMEX IRONMAN TRIATHALON DIGITAL WRISTWATCH
ANALOG TIME
Pull CROWN and turn to set HOUR and MINUTE hands. TIME AND DATE A. Press and hold SET. SECONDS digits will flash. B. Press SPLIT/RESET to set SECONDS to zero. C. Press MODE to select HOURS. D. Press SPLIT/RESET to advance hours digits. Go through 12 hours for AM or PM. E. Press MODE to select MINUTES, press SPLIT/RESET to advance. F. Repeat to set MONTH, DATE, DAY, 12- or 24-hour time display. G. Press SET when done. BASIC OPERATIONS Press MODE to cycle through CHRONO, TIMER, and ALARM modes. Press INDIGLO to illuminate watch face. In any mode, press MODE to view time display. Press any button to stop alarm or timer beeps. INDIGLO INDIGLO CHRONOGRAPH A. Press MODE until CHRONO appears. B. Press START/STOP to start. C. Press SPLIT/RESET to record lap time. Display pauses. D. Press MODE to resume display of lap and split time (automatic after 10 seconds). E. Press START/STOP to pause chrono. F. Press START/STOP to resume. G. Press START/STOP to stop. H. When timing is stopped, press SPLIT/RESET repeatedly to recall last eight lap and split times. I. Press and hold SPLIT/RESET to reset chrono. MODE MODE START/ STOP START/ STOP SPLIT/ RESET SPLIT/ RESET SET SET CROWN COUNTDOWN TIMER A. Press MODE until TIMER appears. B. Press SPLIT/RESET to select timer operation (Countdown and Stop; Countdown and Repeat; Countdown and Start chrono). C. Press SET. HOURS digits will flash. Press SPLIT/RESET to advance digits. D. Press MODE to select TENS of MINUTES. Press SPLIT/RESET to advance. E. Repeat to set MINUTES, TENS of SECONDS, and SECONDS. F. Press SET when done. G. Press START/STOP to start timer. H. Press START/STOP to pause, press again to resume. I. When timer is stopped, press SPLIT/RESET to reset timer. Watch will beep when countdown reaches zero. ALARM AND CHIME A. Press MODE until ALARM appears. B. Press SET to select HOURS. Digits will flash. C. Press SPLIT/RESET to advance digits. Go through 12 hours for AM or PM. D. Press MODE to select TENS of MINUTES. E. Press SPLIT/RESET to advance. Repeat for MINUTES. F. Press SET when done. G. Press START/STOP to turn alarm on or off. H. Press SPLIT/RESET to turn chime on or off. When alarm time is reached, watch will beep for 20 seconds, or until any button is pushed. Alarm will repeat every 24 hours until deactivated. INDIGLO® NIGHT-LIGHT WITH NIGHT-MODE® FEATURE A. Press INDIGLO to activate light. Patented (U.S. Patent Numbers 4,527,096 and 4,775,964) electroluminescent technology used in the INDIGLO® night-light illuminates watch face at night and in low light conditions. B. Press and hold INDIGLO for three seconds (beep will sound) to activate or de-activate NIGHT-MODE® feature. C. While in NIGHT-MODE® feature, press any button to illuminate watch face for 3 seconds. Chime on Alarm on If your watch is water-resistant, meter marking or ( ) is indicated. Water-Resistance Depth p.s.i.a.* Water Pressure Below Surface 30m/98ft 60 50m/164ft 86 100m/328ft 160 *pounds per square inch absolute WATER AND SHOCK RESISTANCE WARNING: TO MAINTAIN WATER-RESISTANCE, DO NOT PRESS ANY BUTTONS UNDER WATER. 1. Watch is water-resistant only as long as lens, push buttons and case remain intact. 2. Watch is not a diver watch and should not be used for diving. 3. Rinse watch with fresh water after exposure to salt water. 4. Shock resistance will be indicated on the watch face or caseback. Watches are designed to pass ISO test for shock resistance. However, care whould be taken to avoid damaging crystal.
Posted on Oct 27, 2008
VOTIT
  • 2071 Answers
SOURCE: how do you set Timex Triathlon Ironman watch?
First look for the set button then press it ,a long press and If it is blinking that's the time you to select the hour ,the minutes,the day/date,the alarms and the special features of your watch.The right button the up and down or for scrolling.Try all of this so your time will set.
Hope it may help you;
Regards;
VOTIT
Posted on Jun 08, 2009
SOURCE: Random display resets of TIMEX Ironman Triathalon(100 lap memory)
Hello RLOWE803,
While I was looking for pictures specific to resetting this watch, I came across your post and thought to reply. I recently replaced the batteries on my watch, which I have owned for nearly 7 years. It is an Ironman Triathlon 100 Lap watch. When I replaced the batteries this time, I forgot to reset, in essence reboot the system, by using a metal needle point tweezers to briefly connect the positive side of the battery to the "AC" pad on the small circuit board for at least 2 seconds. I remembered to do this with at all the other times I had replaced the battery and did not have any troubles after it. This time I forgot and now have the same issue you described. I am not sure where the "AC" pad is on the back of the module. But, it should be apparent if I did it correctly in the past.
Give that a try before sending it off to be repair and wasting time, money and trouble.
Good luck,
CAZ
Posted on Aug 30, 2009
disap1
  • 98 Answers
SOURCE: The hour/minute/second hands on my Timex Ironman not moving
It could have 2 batteries! 1.5 volt for analog and lithium for digital! Take it to a reputable watch repair business and let them check! :-)
Posted on Jan 09, 2010
  • 2501 Answers
SOURCE: Timex Expedition Compass watch stops randomly.
Some watches have crowns that screw in after being pushed home, is this the case with yours? If it is then that could cause the problem described. (Turn crown clockwise).
I looked at one or two of the Expedition instructions (the are a lot) but couldn't find any mention of a screw in crown.
I suggest that you go to Timex.com and at the bottom of the page is "manuals/downloads" select this and the "product manuals". Put your watch type in the search box to obtain your manual.
If you are still not able to solve the problem, the I suggest you take it back to a Timex dealer to sort it out.
Posted on Jan 28, 2010
Do you have a manual for a timex indiglo ironman triathalon digital watch?
Try Googling (timex)(model)(manual) without parens.
May 19, 2017 | Timex Watches
I have a Timex Ironman Triathalon Watch that has both digital and analog readout. the digital can be turned on and off. how do I do that?
on the upper right button, the start/stop button, you had to press and hold it to off. i hope i had help you.
Aug 01, 2011 | Watches
Timex ironman triathalon 100 lap 5F011- need user manual and way to purchase lost gps
You can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
Mar 10, 2011 | Timex Ironman 100 Lap Triathlon...
Looking for Timex Ironman triathalon shock (analog face) manual
manual download"
Nov 25, 2010 | Watches
The alarm doesn't ring on my ironman triathalon watch.
you can find an exper in the local shop where you buy the product and they will give you specific service
for your questions about your product.
In addition, i like to play world of warcraft. there is a reliable website for
all players to get wow gold sale with the lowest price wihit in
10 minutes' fast delivery and you also can enjoy first class service
for your login.
Jan 08, 2010 | Timex Ironman 53151 Wrist Watch
Hello RLOWE803,
Good luck,
CAZ
Jul 22, 2009 | Timex Sports Ironman Triathlon 100-Lap...
Timex Sleek stopped beeping when I replaced the battery
This is a common problem when non watch educated people are changing battries themselves.
The answer is simple: While changing battery and handling the watch you did lost the coil spring. It is so small, you will never notice that the something was dropped.
Coilspring is the connector to the sound membrane of the watch, transfering microprocessor signals to audible membrane.
If it's lost, there is no connection between watch movement and audio membrane.
I suggest that you did change batteries yourself previously and had the same outcome (no sound). Next time you gonna change the battery - make sure you do not turn the watch upside down and if you do - check the movement with eyeglass and make sure all the loose fitted bits are in place.
To get your both watches fixed visit your nearest watch repair shop and ask for coilspring to be fitted.
Rate me, please.
Mar 26, 2009 | Timex Ironman 30-lap, Blue And Silver From...
Watches Logo
158 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Mark Schmit
Mark Schmit
Carol
Level 1 Expert
Are you a Timex Watch Expert? Answer questions, earn points and help others
