Question about eMachines ER1402-05 (884483174195) PC Desktop
Why would my emachines er1402-05 not power up
Everything is connected and the power is not coming on
  • eMachines Master
  • 27,725 Answers
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty
http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
Testing & replacing the PC's power supply
http://www.youtube.com/watch?v=hbNxhvm0czs
One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL.
http://www.kitchentablecomputers.com/static.php - rules
Only work inside the computer case when the power has been switched off and disconnected. Never open the power source.
Some of the below steps recommend removing physical parts within the computer.
While in the computer it is highly recommend that you be aware of ESD and its potential hazards
Remove the memory modules from their slots.
Take the opportunity to clean the slots on the motherboards and the memory module connectors.
Use compressed air to blow dust away and clean contacts with a soft cloth.
Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components.
Do not use solvent that may attract dust and never poke things like cotton buds in to slots. lightly rub an alcohol (Methylated Spirits) on a cloth not to hard let the alcohol do the work on the copper gold or silver tabs and r
Allow the pins to dry.
They will air dry in a matter of minutes.
If reseating the memory did not resolve the issue try swapping the location of the memory.
If you have only one stick of memory in the computer try moving it to another slot and then boot the computer.
Check the memory module and memory slot contacts.
They are either copper tin or gold.
The colour will tell you which they are.
Mixing tin and gold can result in corrosion that prevents proper contact.
Look for any sign of physical damage to the memory module, memory slots or the motherboard.
Reseat the memory modules.
You should hear an audible click when they are in place.
Do not use too much force to reseat the memory module in to the slot this can cause damage to the module, slot or motherboard.
The hardware that you are trying to access is damaged or failing.
The device drivers for the hardware are faulty or incompatible.
Could be a problem with the Hard Drive or the Hard drives PCB
http://www.onepcbsolution.com/
http://www.youtube.com/watch?v=du0Qd_3wFWM
There is a connection problem such as a bad cable
for internal hard drives
Test all power and data leads that attach to your hard drive IDE,SATA
the leads from your MOTHERBOARD TO THE HARD DRIVE make sure they have a
secure dust free connections and are not faulty or just replace them they could be faulty if its a flat 40pin ide
this will be the first to fail
Make sure all leads that are attached to your drives dvd\cd and floppy (If Applicable) have secure connections and are not faulty.
or just replace them they could be faulty a computer needs power and data to travel through every working device and continue its cycle and have an end so any faulty leads will end up with a computer error
Posted on May 07, 2013
HP PAVILION ZV5000 WONT BOOT UP HAS POWER ON LIGHTS AND NOTHING PLEASE HELP!
I had this same problem with my Emachines W3609 PC, it had the power on lights and nothing else. Try making sure that the hard drive and everything is connected properly inside. If the hard drive or RAM isn't connected it won't turn on. If that doesn't solve your problem than you might just need to get a new hard drive and re-install which ever Windows OS you want. Should work than.
Oct 08, 2013 | E-Machines eMachines Desktop PC
Replace power supply, computer on, monitor no signal, help
Did you forget to connect the 4 pin power plug to the display card or motherboard??????????
May 16, 2010 | E-Machines eMachines Desktop PC
I NEED TO KNOW HOW TO CONNECT THE POWER SUPPLY FOR AN EMACHINES T1120 COMPUTER. CANNOT FIND A SCHEMATICS DIAGRAM ANYWHERE.
After reading an article about Emachines awhile back, I found out the reason you can't find the schematic- it isn't available, as some motherboards are made specifically for Emachines and therefore not distributed, as they might normally be, but again, others are, but you have to identify them and go through another source to get them- Emachines, appartantly, will not supply them. All is not lost, however...all motherboards have, basically, the same hookups and connectors for the power supplies, hard drives, etc.- they are standard. I found a web blog that explains the power switch, reset, and power led, which will help. Here it is: http://www.computing.net/answers/hardware/emachine-power-sitch-wiring/56545.html
This site will explain about the 24 pin connector from the power supply
http://www.tomshardware.com/forum/53750-7-installation-manual-rs480m-w3400-emachine-motherboard
If you google "motherboard wiring" you will find sites that have illustrations of the motherboard, and explain which connectors go to which sockets, and how to identify them.
With a little patience and determination, you should be able to hook everything up from the various blogs on the net. Hope this helps.
Apr 17, 2010 | E-Machines eMachines Desktop PC
Getting no image on emachines t6212, the computer was at my mother in-laws and all of the ribbons and power sources were unplugged. i need a diagram of where everything goes.
it's pretty simple. everything has its own plug. and the one for the monitor would most likely be a serial connection, it should have pins at the cord and holes at the computer. the mouse and keyboard have their own connections unless they're USB which wont matter which usb connection ur in. the internet if it's high speed it would look like a large phone cable. and has its own plug. everything else should be alright
Feb 20, 2010 | eMachines T6211 PC Desktop
Nothing on my Emachines computer will turn on.
I would recommend rechecking your connection to the motherboard. All wires from the power supply to board and making sure the front panel switch connection are correct. Also, make sure the power supply is compatible to the motherboare. even though a 20-Pin ps will connect to a 24-Pin board, it still does not work. Good Luck
Franklin
C2Solutions
Aug 02, 2009 | eMachines D3415 PC Desktop
I have emachine w3400 not powering . plz help
I found this right on this website, hope it works!
As for the fans, make sure your connections are tight and in the proper sockets.
Jul 09, 2009 | AMD eMachines Desktop System w/ 17'' CRT...
Emachine light, fan and harddrive come on only.
Please check the cable between monitor and computer and make sure everything is properly connected. try unpluging and reconnect it.
Thanks,
CF
Jun 25, 2009 | E-Machines eMachines Desktop PC
New power supply problem
One of the reasons that this could be is that the power supply doesn't have enough power to power everything. Trying exchanging it for another one that has more watts. If this is an exact replacement as far as the wattage goes, then your problem may lie else where, and you may want to take it to a reputable local computer repair shop for further inspection.
Aug 04, 2008 | E-Machines Bestec ATX-300-12E Rev. D 300w...
Power button wiring
A quick google determined your emachines model w2040 is equipped with FIC motherboard AM37. Download the manual from
http://www.fic.com.tw/support/motherboard/motherboard.aspx?model_id=107
You'll find the pinout info for your wiring on page 13.
Most motherboards also have the pinouts silkscreened onto the board itself.
May 10, 2008 | E-Machines eMachines Desktop PC
eMachines ER1402-05 (884483174195) PC Desktop Logo
50 people viewed this question
Top eMachines Computers & Internet Experts
Computer Links
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
