JVC AV-27D303 27" TV Logo
Posted on Mar 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Picture mostly green
Hello, I have a JVC AV-27D303. I bought it second hand and the picture has suddenly gone to a greenish hue, with some other colors present. There does not seem to be any red.
  • jim_gaceta Mar 16, 2009
    The video inputs...yes I am.
  • Anonymous May 11, 2010
    Are you (hopefully) using the component (RGB) inputs?
Anonymous
Level 2:
  • Expert 121 Answers
  • Posted on Mar 16, 2009
Anonymous
Expert
Level 2:
Answers
121
Questions
0
Helped
47978
Points
324
In that case does this color problem occur on all inputs? If not then please make sure that the connections, especially the red connector, are clean and tight
Replaced T.V. with a new lamp and picture has a greenish hue
Take a good look at screen with color off---if screen is mostly green or all green you may likely have a defective optical light engine.
Sony Bravia 46'' picture has a slight green tint and adjusting the Hue does nothing.
hello!
that could be the t-con to main board cable's problem. first, try to tighten grounding screws.those, which connecting grounding latches of the cable.
You need to open your set. This cable is a thick shielded one with two 30 or so pins plugs. They are NOT interchangeable. In case you try to swap cable's ends. Try to move latches by hand without unplugging connectors, while TV is running. Very gently! If those moving a bit, you may see "greenge" vanishing. Tighten those screws with "phillipls" screwdriver by hand. if there is no difference, you may need to replace that cable. I'm talking about "greenish" ghosts on the picture, intermittent. If I'm wrong, it might be the main board's issue, but always start with small. Main boards are not interchangeable, factory replacement only! Cables-are.
Good luck,
Alex.
Jvc hd 52g787 my position adjustment in my menu will not highlight so i can adjust picture over to the left. help please
Hello
Just make the picture status button on the remote control and get the display setting to its factory mode.
The VIDEO STATUS button gives you a choice of three TV picture display settings, including a
display of your own preferences.
Standard - Resets the picture display to the factory settings.
Dynamic - Heightens contrast.
Theater - Gives a rich, film-like look to video. (AV-27D303, AV-27D203 and AV-20D303 only)
Sports - When you watch a sports program. (AV-27330, AV-27320 and AV-27S33 only)
Press the VIDEO STATUS button repetedly to get these choices.
1helpful
Jvc Genessa hd 1920x1080 How do you solve a hue problem? Where are the adjustment knobs?
press the menu button then press the picture setting, press the hue select then set hue to 0 setting
Color is too green, no remote
your picture tune card is burning out im sorry its time to replace the tv
sorry
merry christmas
Purple and Green Streaks
If lcd set the issue may be with the T con board which is responsible for video and any aberrations that you see on screen.
1helpful
1helpful
How do I decrease the amount of green in the picture?
Unfortunately this model has a bad CRT. If is 3-4 years old and the greenish picture is in all inputs, for sure the picture tube is gone. If the picture is green only in component input check the connections for the blue and red cables.
Green picture
Hi
Is the screen permanately green or intermitent ?
If you have taken the back off the set who is the CRT (tube) made by there will be a large lable on the CRT.
Jvc tv
Before confirm the picture faulty go and the select the blueback option ON in menu option. Disconnect the cable signal and check the tv displays bluescreen. If it is there picture tube will ok, fault in C board. May be dry contact in blue output section the picture tube conducts heavily the respective color.
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
