Question about Kohler K-3386-0 Rialto one-piece round-front toilet with seat and left-hand
Fill valve repair - Kohler K-3386-0 Rialto one-piece round-front toilet with seat and left-hand
    Top Expert:
  • Kohler Master
  • 35,672 Answers
Fill valve problems usually are solved by replacement rather than repair.
Posted on May 07, 2013
Wshing machine keeps filling with water
You probably have a stuck fill valve. This is the part where the hot and cold water hoses connect. Just to be sure unplug the machine and if it still fills Remove and replace the fill valve assembly. Don't forget to unplug the machine and turn off both the hot and cold water supply valves. This is a rather simple repair.
Aug 07, 2014 | Russell Hobbs RH1042 Frontload Washing...
DIM1524W water box is not filling all the way
follow this steps and fix it. God bless you
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve
Read more: http://www.appliancepartspros.com/repair-help/dishwasher-repair-help.html#4#ixzz2a20kdgob
Jul 25, 2013 | Dishwashers
Water is filling the tub when not in use
The machine's fill valve needs to be replaced, it is no longer closing (shutting off) completely.
This is a fairly simple repair, you won't need to remove any panels from the machine other than the small one to which the valve is attached.
In the meantime, you'll have to manually turn the wall valves on and off whenever you need to wash clothes. Don't forget to turn the valves on BEFORE starting a cycle, or you may toast the fill valve completely.
In my experience, I've had the replace this valve about every four years, but it is a simple repair. While you're at it, you might consider replacing the water hoses as well, especially if they are the plain rubber variety. Stainless-braided, long-life hoses are now available.
Jan 03, 2013 | Maytag Neptune MAH5500B Front Load Washer
Won't fill with water
Hello & Welcome to FixYa
Dishwasher not filling problem is caused by clogged inlet valve, first try to clean the inlet valve and the water line coming to the inlet valve. If the issue returns replacing the water inlet valve is recommended repair. Please get back to me if you have any other questions.
Kevin
Dec 20, 2011 | Baumatic 18 in. BFD46 Free-standing...
Ice-maker not functioning
Ice maker stopped making ice. For this problem you have check few things. First thing, is the water filling in the ice maker chamber and then ice maker not making ice? Or, the water is not filling in the ice maker chamber so it's not making ice. If the water is not filling in the ice maker chamber then it's clear that ice is not getting made due to no water in the chamber. For no water filling, the problem is either water supply valve turned off so water is not filling. Turn on the water supply and it will fill. But if the water supply is turned on then the other possibility is ice blockage in the water fill tube. There is a tube from which the water runs and enters the ice maker chamber. If this tube is blocked then water will not enter the chamber. The tube needs to be defrosted, by using hair dryer. This procedure melts the ice collected in the tube and water starts running again. But if water fill tube is completely clear and no ice blockage or any other blockage. Then other possibility is water valve at the back of ice maker unit. This water valve is for letting the water in the ice maker. The water valve open only for 7 seconds and in this time the water fills in the ice maker chamber and then water valve closes and the same procedure runs again in the next water filling cycle.------- For your information I will mention that there are two valves. One is the main valve the back of the fridge section. This main valve lets the water enter the refrigerator and other valve is at the back of ice-maker section. This other valve lets the water to enter the ice maker. In most of the cases the fault is water valve at the back of ice maker section. ------------- The other above possibilities which I gave you is water not filling in ice-maker chamber so it's not making ice. But now consider that water is filling in ice maker chamber but it's still not making ice. Then the problem is ice maker unit itself. This unit is controlled by main board. But in most cases if water is filling the ice maker but it's not making ice then its faulty ice maker unit. So see if the problem is water not entering the ice maker then the water fill tube is frosted by ice or the water valve at the back of ice maker is faulty. Replace the valve. ------------
You can get required parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
May 29, 2011 | KitchenAid Refrigerator
My dishwasher does not fill with water. It sounds normal but does not fill. It even heats up.
Kevin
Dec 09, 2010 | Whirlpool Dishwashers
Water continues to fill up tub
If it fills until it actually over flows, there are a couple or reasons. Your fill valve is faulty and should be replaced. Not as likely, the tube that runs to the fill valve is plugged. Unplug the machine to do any repairs.
Nov 28, 2010 | Kenmore Washing Machines
Intuitive Eco 701 ... error code 50. I'm sure it's to do with the fill solenoids. It is filling very slowly.
Yes. Whichever is filling slow. Hot or cold. It is a code for the fill valve. Just replaced the cold fill valve on my unit which seems to be the one that most commonly goes out. Easy repair. 2 screws and 1 Plug...If you unscrew the top by taking out two phillips screws in the back, you will find some paperwork about trouble codes, repairs etc...Right next to the fill valves.
Jan 24, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Water doesn't fill after 50-60 secs of valve
Float valve is not used in normal cycle, it is a failsafe method. Energy conservation issues dictated less water during washing.
Oct 31, 2009 | GE 24 in. GSD5500G - Multiple Color...
Fill value won't shut off even though flapper
some of these can be solved simply by adjusting the fill valve,check float as well. If these do not solve your problem then you need a replacement.
Sep 28, 2009 | Toto MS854114S - Ultramax One Piece...
Kohler K-3386-0 Rialto one-piece round-front toilet with seat and left-hand Logo
137 people viewed this question
Top Kohler Home Experts
Donni Steen
john h
Tim Whalen
Are you a Kohler Home Expert? Answer questions, earn points and help others
