Question about Hayward Ec 30 De Pool Filter with Pump
How tio replace a regeneration handle in a hayward EC30
The handle broke,I got a new one but I'm having difficult in removing the top too replace the handle.
  • Helio Kimura May 08, 2013
    IT WAS SIMPLE THAN I EXPECTED, JUST REMOVE THE TOP COVER WITH A FLAT SCREWDRICER, REMOVE THE BOLT AND REPLACE WITH A NEW ONE.
  • 5,245 Answers
Copy following link for hayward product manuals, and contact-us link:
http://www.hayward-pool.com/pdf/manuals/PowerFloLXandPowerFloII.pdf
Posted on May 08, 2013
Water from waste pipe when pump on filtration
Damaged or worn spoke gasket. Very common problem with this filter. You will find a number on the top of valve (i.e. SP710, SP711 or SP714x32). You will need this number to know which gasket you need. It may be helpful to know what size plumbing goes into valve as well, 1.5" and 2.0" is standard. If valve is earlier model (710, 711) you remove 6 screws on top and extract old gasket. Be sure to get all the little pieces. Dry inside of all groves with a rag. Now install new gasket, I use gel superglue. If you have a newer 714 valve it is much harder. I suggest removing the screws at the top and taking the whole key handle assembly into your local pool store for help. The gasket is molded into the key diverter so handle pin needs removed and whole key replaced. Re-assembly is difficult without proper tools given the tension of large spring.
Jul 27, 2014 | Hayward SAND FILTER, PRO SERIES
What electrical is needed for ec40ac perplex system pump
see what is on the side of the pump motor it will tell what voltages are to be used if able to use 240 volts you will save money on your electric bill if it has a 120 volt plug on it you have to run at 120 volts
May 04, 2014 | Hayward Pool Products Hayward Perflex...
The valve that you turn to change fil prositions the white ring under handle bnoke
Find the position where the pin that runs through the handle lines up with the slots in the valve top. Drive the pin through the handle with a punch and remove the handle then just drop a new ring in placeand replace the handle.
Aug 15, 2011 | Hayward SAND FILTER, PRO SERIES
The handle on my sp714 filter top will not turn freely? any idea what is causing this
Either the 'bearing' under the handle is broke (white PVC ring under the handle) and/or the stem seal is gummed up. Note the orientation of the handle to the diffuser once you remove the top of the valve and then drift out the pin holding all this together. Once apart drive out the stem and inspect all the pieces. You can buy a go-kit for the valve with has all the seals and the ring. If the spring or the stainless steel washers are broke those are available separtely. If the whole works is a mess you can also buy a replacement lid/handle/key assembly.
Your go kit is #10
We sell them for $23.49 + tax and UPS or mail if required. No tax outside of Michigan.
A whole new valve is #SP0714T, but only the top portion would be needed; part #SPX0714BA for $76.90 + tax and UPS or mail.
John
Jun 21, 2011 | Hayward SAND FILTER, PRO SERIES
Handle and pin broke the valve stem. Have a replacement.
Hammer and punch...drift out the pin. Be careful to note the orientation of the handle to the key assemble, assembling it backwards realigns the settings on the valve backwards...not a good thing.
Dec 21, 2009 | Hayward SAND FILTER, PRO SERIES
Low presure and sand on bottom of pool
your filter is not set in to filter mode handle on top has a sprocket wheel under it, this is is not seated right try moving handle to different positions and see if this helps otherwise you have to remove handle to get to sprocket wheel and check if its damaged there are teeth on it see if any are broke hope it helps
Jul 14, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward vari flo valve
If the spider gasket in the vari-flo valve is no good, you will usually notice one of two problems.
1. Water leaking out backwash port while filter is operating.
2. Valve positions are really difficult to change.
The way to check this is if you are able to move one or two of the "spokes" in the gasket freely(out of the track it sits in) once the top of the valve is removed.
If so you need to replace. The gasket is usually held in with a silicone sealant. Once you remove the old gasket. You will need to scrape any remaining rubber from the track it sits in. I've found that a brass brush from a pluming supply store or home depot along with a flat head screwdriver is usually enough to do the removal.
I always used Permatex Blue RTV sealant on all valve jobs. It can be found at any auto parts store or sometimes Walmart. Follow the instructions for curing. Once cured the gasket is good as new.
Need instructions on replacing filter head on a haywad de filter ec75a
Remove the nuts and bolts around the head of the filter. The top then seperates from the bottom. if the top of the tank is broke you need to remove the black cover and continue disassembly.
Remove the grip from the handle. Usually a squeeze clip to slide grip off. Slide black cover over handle.
Remove bolt holding handle on to bump shaft, might be addtional drift pin that needs to be removed. Tap out with a drift punch.
Once these are removed the bump shaft will be attached to the top and bottom plates with the main gasket still attached. The filter Head is now free to be replaced.
Apr 24, 2009 | Hayward EC75 HAYWARD PERFLEX FILTER SYSTEM...
I have a GE Profile Microwave and the handle is broken....
I have the same issue. The Handle broke off my GE Microwave Oven (Model JVM1190SY 001). GE does not sell the handle seperately from what I can tell. I just ordered a new door. It's rediculously expensive. I tried to replace the handle with a nice drawer pull but couldn't find a size pull to match and I broke the plastic cover trying to get access to the screws for the handle, which is why I decided to buy the new door. Hopefully installation is not that difficult. This oven was manufactured in 2001, seems the handles have a 7 year life span.
May 28, 2008 | GE JVM1190SY/WY/AY/BY Microwave Oven
Hayward Ec 30 De Pool Filter  with Pump Logo
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
