Error SC305 on
Error occurred sc305
  • 7,733 Answers
An error has occurred in printing.
  1. Make a note of the error message (for reference later).
  2. If the error re-appears, please contact your local authorized sales/service representative or original point of purchase.
For the time being, try restarting the device:
  1. Press the Clear button to clear any pending jobs from the Printer.
  2. Switch off the device at the Red Power Switch, wait for 5 seconds then switch on again.
Posted on May 07, 2013
4 Suggested Answers
  • 24 Answers
SOURCE: richo aficio error sc305
Hi All,
Charge AC Bias Error
Check connector for Magenta PCU
Replace the Magenta PCU
Posted on Oct 05, 2008
  • 53 Answers
SOURCE: We are getting Error Code
Looks like toner buildup on the corona wire. Turn it off. Wait for 10 seconds and turn it back on, that should cause the device to clean the wire. If that doesn't work, another tech gave this advise:
This SC code relates to the charge corona cleaner not working or not working properly. the charge corona is located towards the bottom left of the machine after opening the front cover. It will have a screw you can undo by hand and a cable with an end like a telephone cable plug. toner may have fallen in to the unit or the motor that drives the cleaner along the wires has decided to jam up. remove the charge corona and blow it out with compressed air. You can also remove the end of the unit and check that the motor is not gummed up. Be very careful you do not break the hair thin corona wires! Hope this helps.
Dave T (username: munybuny)
Hope you don't need to call in an on-site tech.
Thanks,
Steve G.
Posted on Nov 02, 2010
  • 2187 Answers
SOURCE: I have a nashuatec Dsc232
The error is for your 'charge corona cleaner'. It may be bad or is not working properly. You should gain access to it by opening the cover. You should see a screw and a small cable similar to the ones used in telephone cord. Check for dirt or debris that may be present. It could also be a problem with the mechanical parts. See if they are meshing properly. It could also be a problem the motor. You may remove the parts, just take note of the order on how they are removed for further inspection and cleaning.
To clean it out, you may use compressed air to get the dirt out. Be careful with the wires.
Posted on Apr 19, 2011
What causes sc305 focus problem
Just a guess but it sounds like something is not aligned properly. Was the FLIR dropped or bumped hard? Try removing the lens, cleaning the contact areas and re-assembling.
Jun 16, 2014 | FLIR 1196960 Wide Angle Lens 45, f=10mm...
Sc 305 1075 afico
SC305. Occurs after replacing charge corona unit.
trnsp.gifAnswer [Cause]
PCU-side quenching lamp has come loose from bracket.
[Action]
Return quenching lamp to correct position.
Aug 20, 2011 | Ricoh Aficio 1035 Copier
Sc305 1075 aficio
[Action]
Aug 20, 2011 | Office Equipment & Supplies
We are getting Error Code SC305 when we try to print.
Thanks,
Steve G.
Nov 02, 2010 | Office Equipment & Supplies
What is SC305 Error Message - Ricoh 1232C On
I worked on this same code just the other day for a customer. This SC305 code means the charge corona cleaner is not working properly. The charge corona is located behind the large front door, towards the bottom and just left of center. It has a small thumb screw and a white cord with an end on it like a telephone cord. You can try removing the assembly and blow it out carefully with canned air. Be careful about the very thin hairlike wire in the shell. You can also remove the end of the unit and check that the motor is not gummed up. If it is just put a little light oil on it. Just cycle the power off then on again to reset and try.
Usually once they get repositioned properly they will work fine. Sometimes I have replaced the unit with one from a parts machine.
Good Luck and Thank You for using Fixya.
WheatlandServices
Sep 27, 2010 | Ricoh Aficio 1232C Color Copier
Please show me how can I unlock the error code SC305 for Photocopier Ricoh Aficio 1224c
This is a Corona cleaning unit error. You either need to get the issue with the corona cleaning unit fixed or have a service technician turn off the automatic cleaning function. SP Mode 2 801 3 (technican will know what this code means) I can not tell you how to do this as you can total mess up the machine if the service mode is not used properly.
Turning off the cleaning will solve the error code. Technician can clean the coronas himself on service calls so automatic cleaning is not required.
Good Luck
Dec 07, 2009 | Ricoh Aficio 2015 Copier
Richo aficio error sc305
Hi All,
Oct 04, 2008 | Ricoh Office Equipment & Supplies
Error code SC305 for Photocopier Ricoh Aficio 1224c
Its a charge corona cleaning error. Try turning the power off, wait 10 seconds and turn it back on.
If that doesn't reset it, it could be the pcu, toner collected on the mechanism.
If turning it off and back on isn't fixing it, you should get a technician to look at it to see what the trouble is.
Jun 18, 2008 | Ricoh Aficio 2015 Copier
Error code SC305 for copier ricoh aficio 1224c
Dave T
Jun 18, 2008 | Office Equipment & Supplies
60 people viewed this question
jasbo
jasbo
