Question about Panasonic NI-R73NR Iron
My panasonic NI-R73NR iron went off and is not coming back on.
Well I actually put the iron off and took a break from my ironing but when I put it back on it is not working and the light is off.
  • 7 more comments
  • deyvll Jan 04, 2008
    well i have the same problem and i already open it and everything seems ok but it doesn't wanna work again. somebody mention about a fuse on the plug where is that exactly and what else can i do?
    well mine is the same but i already open it, to see what was wron with it and everything seems ok. but it doesn't whant to turned on. i heard about a fuse on the plug where is it and what else can i do?
  • Anonymous Jan 08, 2008
    My iron worked perfectly one day and the next it would not come on.
  • Anonymous Mar 31, 2008
    love this iron but it just die on me. it was working fine one minute and the next no more heat
  • c-man-2 Jul 30, 2008
    stopped working
  • Anonymous Oct 16, 2008
    same problem. My NI-R73NR simply turned off in the middle of my ironing and won't turn back on again, even though I've tried it several times over the past few days now.
  • puzzled44 Mar 01, 2009
    Iron just quit working. Will not heat up. Light will not come on.
  • Anonymous Mar 18, 2014
    how to fix panasonic ni-s650tr iron
    FUSE LOCATION IN Panasonic NI-S650TR 1200-Watt Steam Iron fell and iss not working
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 110 Answers
Check fuse in plug, check wire in plug for loose connection. Turn the thermostat a little higher to 'freeup' the contact mechanism. Check continuity with a ohm meter on the irom conacts, check lamp on iron
Posted on Sep 21, 2007
SOURCE:
How can I repair my the retractable cord on my iron?
Install a new one cuz that old one is compromised
May 02, 2014 | Panasonic NI-R73NR Iron
Iron always too hot
Problems with an iron's electronic complements should be dealt with by an authorized service center. It typically is more cost effective to replace rather than repair an iron with internal problems. if none of the dials heat works right. its a problem with the setting switch. good-day !
Jan 17, 2012 | Panasonic NI-R73NR Iron
The red light is on ,but the iron don't get hot
Here is a tip that I wrote about Electric Irons and why they do not heat....
Electric Ironnot Heating Up or not Working Right heatman101/./.
Mar 23, 2011 | Panasonic NI-R73NR Iron
Panasonic Iron NI-R73NR will not heat up
Either a bad thermostat or a bad heating element or an open connection somewhere in the power cord. My advice, toss it!
Aug 25, 2009 | Panasonic Irons
Tefal iron - security auto stop has locked me out, have switched off for some time but lock out still in place - help!
If you know how to open it, it's just a mechanical lock, check for anything that stuck or broken
Aug 18, 2009 | Panasonic NI-R73NR Iron
THE LIGHT IS ON BUT THE IRON WON'T HEAT UP.
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Jul 06, 2009 | Panasonic NI-R73NR Iron
How can I prevent my iron from leaving white residue on clothes?
white residue is caused by lime in your tap water.perfectly safe to drink,but when boiled [as in making steam] the lime is left behind. over timeit builds up in the 'tank' buy a gallon of distilled water from the grocerery-about $1 mix water with white vinegar,50/50 and 'steam it out' once or twice to remove deposits in the resevior.steam it out again w/pure distilled water.try it out on your husbands clothes before you iron your delicates again!!
Dec 22, 2008 | Panasonic NI-R73NR Iron
My iron leaves white residue on clothes when I iron.
Supposedly vinegar helps. Follow the following link:
http://www.learnhowtoclean.com/clean-an-iron.html
I'd like to use this teachable moment to give a shot out to all the Ray Luv fans out there, the Giant fans out there, and people who flush the urinals after using them.
My iron won't work
you have to check the cable you can use multi tester in ohm position to make sure the connection no problem, and turn the adjustment temperature and watch on multitester the resistance will change if nothing happen you have to change cord with new one.
May 24, 2008 | Panasonic NI-R73NR Iron
Panasonic NI-R73NR Iron Logo
648 people viewed this question
Top Panasonic Irons Experts
ray gallant
ray gallant
Bill Boyd
Are you a Panasonic Iron Expert? Answer questions, earn points and help others
