Question about Ricoh Aficio 450 Copier
2045 error code afficio sc547 - Ricoh Aficio 450 Copier
2 Suggested Answers
SOURCE: ricoh afficio color 6010
· Hot roller fusing
lamp brown
· Hot roller
thermofuse opened
· Defective main
control board
· Defective I/O
control board
· Defective AC drive
board
more than likely the thermofuse.
Posted on Jun 17, 2008
Problem to swevice sc547 for soultion
You really need to post the model number of the machine. Nonetheless this is a zero cross error for the fuser. It is quite serious. If it is an older machine such as a 1045 or 2045 it is not worth the parts required to repair.
Nov 15, 2014 | Ricoh Office Equipment & Supplies
Ricoh Afficio cl 7000 sc 552 code what is it?
Try the procedure below. Its a hardware error on the device
Press and hold online + escape, then power on.
Use up and down arrow keys to select SP2
Press Enter
Use up and down arror to locate SP5
Press Enter
Use up and down arrow keys to select 810
Press Enter
Confirm the selection
Power off and on.
The error code is now cleared.
Aug 18, 2008 | Ricoh Aficio CL7000 Laser Printer
Toner lock problem
Go to youtube.com and type in this question. It should solve your problem.
Oct 05, 2013 | Ricoh Compatible Premier Richo 3310d Blk...
Help with error code SC547-01
sc 547 mean fixing unit error ,you can reset by simply getting into simulation mode and then switch off an the machine ,getting into the simulation mode is simply by pressing 107 and press and hold c ,
Jun 19, 2013 | Ricoh Aficio 450 Copier
Ricoh afficio 2035/2045 showing error code 395
This is old copier in digital life.But good copier.
Jul 14, 2012 | Sharp AR-5316 Advanced Digital Imager...
I have an sc 326 error code in my ricoh aficio 2045 copier
kindly change the developer unit and clear the error.
the machine will respond
thank you and all the best
May 20, 2012 | Ricoh Aficio 2045e 2035e Copier...
Ricoh afico 811 error sc689 and sc547
sc547 is a power supply error that can mean you have a faulty power supply. The service manual does not list an sc689, and it's not in the help desk support database either... are you sure that's the code that comes on the screen?
Oct 05, 2010 | Ricoh Aficio SP C811DN-DL Printer
Eror sc547
The error sc 547 refers to a "Zero cross signal malfunction".
This means that the applied power supply AC frequency was detected at over 66Hz or below 45Hz, and the zero cross signals are not detected within a certain period within 500 ms after the main power switch has been turned on.
Possible causes are:
- Power supply board defective
- IOCSS defective
- BICU defective
Try to reset the SC code by entering SP5810 and select 1.
Then hold down the photo mode key and the # key at the same time for at least 3 second.
Then turn the machine off and on again.
If the same issue still appears, try to replace the Power Supply Unit.
Jul 04, 2010 | Ricoh Aficio MP 2000 Black and White...
Afficio 450
Goto to copytechnet.com. Someone can help you locate the error codes you are looking for. That one is supported by copier technicians.
Aug 05, 2008 | Ricoh Aficio 450 Copier
Ricoh afficio color 6010
· Hot roller fusing
lamp brown
· Hot roller
thermofuse opened
· Defective main
control board
· Defective I/O
control board
board
Jun 17, 2008 | Ricoh 6513 Copier
Ricoh Aficio 450 Copier Logo
131 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
