Question about Home
How to I remove anchors- get a toggle bolt out of drywall?
    New Friend:
  • 22 Answers
Unscrew the bolt until the toggle falls off into the wall cavity. Then just pull out the anchor and spackle over the hole.
A molly bolt is a similar type of wall anchor. It's often confused with a toggle, but a molly's "bendable" legs are part of the anchor and will remain in place when the bolt is removed. Sometimes you can straighten those legs out by unscrewing the bolt partway, then pushing it back into the wall cavity. If you're lucky, you might be able to pull the anchor out through its own hole. If not, you'll have to use a punch and hammer to pound the head just below the drywall surface, then spackle over it.
(http://www.thisoldhouse.com/toh/asktoh/question/0,,1585873,00.html)
Posted on May 07, 2013
1) We are trying to install a Breeze 36 shower stall and don't understand the instructions. We are about to attach the fiberglass walls.
What molly bolts are you talking about. A molly or molly bolt, often misspelled moly,[1] is a formerly trademarked[2] name for a specialized screw fastener used with drywall, as a hollow-wall anchor. Larger sizes permit reasonably heavy objects, such as shelving, flat screen-TV mounts or central-heating radiators to be attached to drywall in locations where there is no stud behind the drywall. For heavy objects, multiple molly bolts may be required.
. You can use adhesive to glue to walls. The unit must be level and square. The corners in your home are not 90 degrees but close.Please don't drill any holes in unit., unless directed to.Holes in-walls are hard to seal. Let me know what unit number your shower is and I will help you.
Mar 13, 2018 | Home
How do I hang an object using drywall anchors?
hi there.
Sink A Self-Drilling (Threaded) Anchor
  1. Mark your hanging point with a pencil.
  2. Tap the pointed tip of the anchor into the wall with a hammer.
  3. Once the tip is in the drywall, with a screwdriver, screw the anchor in until it's flush to the wall.
Fix-It Friday: Anchors Aweigh! How To Put Anchors Into Walls
womenyoushouldknow.net/fix-it-friday-anchors-aweigh-how-to-put-anchors-into-walls/
How to Install Drywall Anchors to Hang Heavy Stuff on Your Walls
How do hang an object using drywall anchors Google Search
Nov 28, 2017 | Drywall
How to fix 1 inch holes in drywall
many home improvement stores sell partial sheets . then you cut a plug the right size and spackle it in place .
Apr 06, 2016 | Drywall
How do you fix a Moen Towel Bar when the mounting system has come apart from the wall?
There are larger screw-type anchors available at a hardware store. If the hole is a half inch, you can possibly use an expanding wing type "molly" anchor. it's hard to assemble the screws through the bracket, then put on the butterfly, and shove the folded butterfly into the hole, but it's doable.
Jul 28, 2014 | Moen YB2218BN: Brantford 18 in. Towel Bar...
I have a wooden shelf which I want to hang above my flat screen tv, what type of screws should I be using?
Depending on weight of shelf and contents.
And if you can hit a wood stud.
http://t0.gstatic.com/images?q=tbn:ANd9GcRgImEAL3MOBqQus1-EOz1kKhcNhWnCFnVcBrQtBZaGw0KC_bdPCw
I like the plastic zip-it anchor because it is pretty strong for towel rack or shelf with a few books etc, It simply drills flush into the wall and then you can use a regular pan-head or drywall screw to connect shelf to zip it. Later the zip it can unscrew and hole is filled easily.
Wall dog is nice for 1 step into drywall. Lightweight shelf, with 2 small books and vase..
Toggle bolt for heavy shelves, But requires good sized 1/2" hole drilled first, and takes a few skill techniques.
Mar 13, 2013 | Woods Hardware & Accessories
Tighten up a loose Moen Eva towel bar wall mounted bracket
u have to really push hard up on the spring and at the same time pull towards u
Apr 18, 2010 | Moen YB2818 Eva Towel Bar Bathroom...
Installation
If you are going into drywall then a threaded drywall anchor like this
Will be best.
Yopu can buy them at any hardware store. They screw right into the drywall and then another typical screw goes through the mounting plate into this anchor.
I recoment getting metal anchors as the plastic ones break easily.
These hold MUCH better than the push in plastic anchors.
Dec 30, 2008 | American Standard 6723S 'The Standard...
No studs for microwave installation
There has to be something in the wall supporting the drywall. You need to find the supporting structure using exploritory holes if necessary and solidly fasten to it using lag bolts.
Jan 11, 2008 | Microwave Ovens
Home Logo
847 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
