Question about ComfortStar CHH012CD-13B Wall Mounted Mini Split Heat Pump - 12,000 BTU
No display on unit comfort star
Comfort star 13 seer has no display on unite
How to install condensation line on residential AC
Just get PVC 3/4 MIP fitting and enough pipe and elbows to run to drain. Glue together with PVC primer and PVC Glue.
Aug 04, 2014 | Carrier Comfort 3.0 Ton 13 Seer Ac Only...
13 seer 2 ton reheem ucentral air very noisey what is a more quiet make
Unfortunately the quieter ones are more expensive. I have a variable speed Trane '19 seer' which is extremely quiet. But, with the higher 'seer' I save money on electric.
Jul 10, 2014 | Rheem 13AJN24A01 2.0 Ton 13 SEER Air...
24ABA342A30010 NEED TO KNOWHOW MANY B T U'S THIS UNIT HAS
The only important part is before the last A. It gets broken into two parts, xxABA, and *** (where x is any number)
24ABA:
24A = A/C (24H would be heat pump)
B= Base series, C would be Comfort, P would be Performance and N would be Infinity. (B, C, P, N in that order gives you more bells and whistles)
3rd letter = A (puron) or B (R22).
342:
First number = SEER 3 = 13, 6 = 16, 1 = 21.
42 = btu in thousands (18-60)
This means that your unit is a 13 SEER, 42,000 BTU base-model Air Conditioner which uses Puron (R410 refrigerant).
Aug 22, 2011 | Carrier Heating & Cooling
NO PROBLEM YET, JUST HAD A GOODMAN AIR CONDITIONER INSTALLED MODEL CKL36-IL AND WAS TOLD IT HAD EXCELLENT EFFICIENCY TO FIND OUT THAT ITS A 10 SEER EFFICIENCY RATING WHICH I UNDERSTAND IS THE LEAST...
10 seer was the most efficient for the older generation units and in 1992, it was required that any unit has to have 10 seer or greater. The least efficient seer rating you will find on any new unit will be 13 seer which is a lot better than 10 seer and will save you almost 30% in energy cost. As of lately, they have made units available that are up to 20 seer or more, but they are pricey. I know you said you just had the unit installed, but from the model number, I'm assuming it is an older unit? If new, then it would have at least a 13 seer rating. Hope this answers your questions!
Aug 18, 2010 | Heating & Cooling
I HAVE A GOODMAN MODEL CKL36-1D I'M TRYING TO FIND OUT THE SEER RATING ON THIS MODEL.CAN ANYONE HELP?
Your going to need to know the age of the unit. If its less than 5 years old, its most likely a 13 SEER. If its anything more than 5 years old, its most likely a 10 SEER. If its anything over 10 years old, its most likely an 8 or 6 SEER.
Remember, that a unit will loose an average of 1-2 SEER for every full year of operation. This is just due to age, wear and tear, and usage.
So, if its a 10 SEER unit that is 7 years old, you could say that it is about as efficient as something in the 4-6 SEER range.
Jul 12, 2010 | Goodman CKL36AR36 Air Conditioner
Just had the haier 4 ton 13 seer outside unit installed. my inside unit is a payne and still in good condition.had a 4 ton 10 seer outside unit previously. my problem is the unit froze up the first night...
Your problem is that your 13 seer outdoor unit is not compatible with your 10 seer indoor unit, even though the tonnage is the same. The metering device on 13 seer indoor units is different. Most 10 seer indoor units do not have an expansion valve. When you change from a 10 seer outdoor unit to a 13 seer outdoor unit, you must, at the very least, change the from a fixed-orfice metering device to an expansion valve.
Jul 31, 2009 | Haier HC48C1VAR Central Air Conditioner
What is the cooling btu on my BDP company division of carrier
is this unit real old ? it does not come up in my book . the btu is 30000 that is the same as 2.5 ton it may be 6,7 or 8 seer i dont think its a 10 seer because the 10 seer units are listed and yours is not . if this sounds wrong please look up the mod # again and post the ser # too ......... Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
Mar 15, 2009 | Amana Comfort Zone 12M32PBEH Air...
Air conditioners
No kits, you will have to upgrade.
Mar 17, 2008 | Heating & Cooling
ComfortStar CHH012CD-13B Wall Mounted Mini Split Heat Pump - 12,000 BTU Logo
Top ComfortStar Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a ComfortStar Heating and Cooling Expert? Answer questions, earn points and help others
