Question about Dishwashers
Westpoint wqp12 9240
Hi, I'm looking for help with a Westpoint Dishwasher model number: wqp12-9240 first of all I would like to know where I can download its user manual for free, if at all possible? For in the event that I cannot download the manual, I will describe my problem best I can... It seems that the machine gets stuck on its third (the rinsing) cycle where all four lights on the unit light up for a while, then the lights go off and after a while it wakes up again to start draining, but never does so... Any ideas/suggestions are welcome! Thank you
SOURCE: Miele G638 dishwasher.
Hi John I have the same problem, the manual says that it is because the water level is to low, this is checked by opening the door after the machine has stopped filling and before it starts to wash, the level should be 4mm above the main plastic filter ring, the level has two settings, these can be adjusted by pressing the start button and the On/Off button at the same time, release the start button and turn the control to economy 45,if the start light does not come on the level is set to normal, to increase level press the start button again and the light should come on, this will give you an increased filling time. it did no help me but it may help you. good luck
Posted on Sep 25, 2007
  • 90 Answers
SOURCE: help with dishwasher
What Brand is it?
Posted on Jan 05, 2008
SOURCE: aeg 76669 oko lavamat machine not
I have had the same problem. If you switch the machine to off and then to cotton/linen 95, then press at the same time prewash, soaking, qick wash and stain buttons for 10 seconds switch it off. When I switched it on it worked.
Posted on Jun 24, 2008
  • 116 Answers
SOURCE: siemens hydrosensor dishwasher SE25A091GB/22
Paul
If you are still trying to sort out this issue try the following.
From what you say then it is most likely the aqua sensor on the side of the dishwasher. The gurgling sounds that you hear are likely the drain pump running and the un-drainable water sloshing in the sump.
Verify that there is actually water going to the dishwasher( Basic step but often overlooked)
Next the inlet valve will have to be checked. This is the part where the water line from the house connects to the dishwasher, under the toe/kick panel. Remove power from the dishwasher. Disconnect the dishwasher electrical connections (2 wires) to the inlet valve and connect it (carefully to 110 V power) using a jumper wire. With 110V power the valve should open and water will flow into the dishwasher, if not then the fault is in the inlet valve.
If this checks fine then the fault is likely in the aqua sensor...
On the outer left side (viewed from front) there is a panel, Behind this panel there is a small clear(of light blue) plastic mechanism with hoses and wires attached( There is usually a yellow disk at the top about 6cm in diameter) this is a float and sensor assembly there is tells the control the water level and works as an emergency drain if there is an issue. There will be a red stick protruding downward to the base and a Styrofoam float on which the stick rests. This is a pan overflow sensor if the stick is too high the unit will go into drain and cut off the fill valve power. The yellow disk is a diaphragm which senses water height. This unit can become stuck with wear and hard water.
Posted on Jul 28, 2008
SOURCE: A WESTPOINT WQP12-9011E DISHWASHER, USER MANUAL
i returned same to hi fi corp 2 years ago same problem
replace timer and all will be solved
Posted on Aug 20, 2009
Manual for washing machine westpoint WMC 61013 Er
Try Googling (westpoint)(WMC 61013 Er)(manual) without parens.
Aug 06, 2017 | Washing Machines
Operating manual for a wqp12-9011 westpoint dishwasher
Try Googling (westpoint)(wqp12-9011)(manual) without parens.
Jun 06, 2016 | Dishwashers
I want the manual of WESTPOINT WMB-50T
I have big problem my washig machine is a top loading Westpoint brand, model : wtw-700 its drain well but can't spin at all please help .
Sep 30, 2010 | Washing Machines
Try:
https://www.2instructions.com/results_mm.php?marque=WESTPOINT&materiel=Dishwasher
Jan 12, 2009 | Westpoint TV-201 Microwave Oven
Westoint Dishwasher
Hi jannewbery,
I'm Harvey the Master Plumber.
Your problem is: You have looked in the manual under troubleshooting tips, but didn't find anything on the problem. The dishwasher goes into cycle,but during the wash cycle it stops,makes alarm and the wash and rinse ligts come on. And now you can't even find the product on this site.Westpoint Dishwasher WQP12-9240.
Thankyou Your dishwasher is stopping at stage 2 of the programme after beeping once. Quite often the detergent flap doesn't open. Am at your wits end and threatening to leave home!!!! The machine is less than a year old. PLEASE HELP!!!! Thank you.
Don't leave just yet. It sounds like a control problem. The d/w should still be under warranty if it is less than one year old. Use it before it runs out. I don't recomend this type of repair for the average homeowner.
Feel free contact me again!
Please give me a rating here at fixya before you sign off
Thank you,
Harvey your Master Plumber
Sep 21, 2008 | Dishwashers
I put the mahcine on as normal but it does not go past the first cycle of the red flashing light?
Sep 08, 2008 | Dishwashers
Dishwashers Logo
26 people viewed this question
Top Dishwashers Experts
