Question about Home
Can someone give me a circuit diagram of a fire alarm?
  • 49 Answers
Wiring diagram for TKA6 car alarm
Dont bother just put a crooklock on the steering wheel ,all these add on alarms give problems and fail as the circuits are junk chinese things for cheapness ,
Dec 06, 2014 | Cars & Trucks
Wire together fire alarms
If you wire fire alarms together you may not have the coverage you should have. If you have a fire alarm in one part of a house and put another one hooked to it then if a fire puts the power out in that part of the house then you have no protection in the other part if it's on the same circuit. There has to be a different circuit for each alarm.
Sep 09, 2014 | Home
Why is my fire alarm faulty
Hello. It could be the battery is bad or the fire alarm is becoming bad it self. The best thing to do is change the battery first. If it is giving you problems still, then change the fire alarm it self. Good Luck.
May 16, 2014 | Home
I have prolem with fire alarm system
I need more information to answer this question, sounds like you might have a ground fault. These are headaches to troubleshoot and it would be best to get a technician on-site to resolve.
Jan 30, 2014 | Sony Home Security
Do i need a eol resistor for a fire bell on a three zone fire alarm controll pannel
Usually, No. Any sounder (or strobe) is a warning device, and not a sensor.
EOL resistors are to prevent tampering on sensor lines.
To date I've only found one system that actively monitors the sounder line to determine the presence of a load.
Usually, a printed installation diagram is included inside the control panel to indicate EOL requiremants. Failing this, Google for an installation manual for the specific model of control panel (indicated on the main printed circuit board).
Apr 23, 2011 | Hardware & Accessories
Circuit diagram
I'm afraid I cannot comply with your wishes, as there are copyright laws governing this, for one. (For existing circuitry)
Two, there is the liability issue. Take for example that I design the requested circuit, give it to you freely, and you or someone in your group is injured using my circuit.
Will state that this is a basic circuit design. I believe that if you 5 put your minds together, you can build this circuit.
Sep 14, 2009 | Powerline 200Watt DC to AC inverter...
Where to connect fire alarm to a combination starter with a hand/off/auto/switch
The fire alarm (usually an open contact, held closed during healthy operation) MUST go in series with the supply to the switch. This is normally incoming to a terminal which is linked between the hand and auto positions. If this is a full control panel, the fire alarm connection SHOULD be used to drop out the entire control circuit. Can you supply wiring diagram?
Sep 13, 2009 | Heating & Cooling
Telephone disconnected from first alert professional alarm system
The phone wires run from directly from the telephone company connection to the alarm on the red and green. They return on the other two wires. These wires are hooked to your home phones. That's the UL way to do it. The alarm is supposed to be the first device on the telephone line. You can just run a phone line to the alarm panel. There probably is a diagram inside the cabinet door or a phone jack very near the alarm.
Apr 11, 2009 | First Alert SA302 Dual System Smoke...
Electrical drain from car alarm
dis connect wires t-tapped into ign swith
Mar 08, 2009 | 1997 Toyota Camry
4 wheeler won't start
The Sunl's are notorious for the stator going out. Check with your dealer for specs on testing the stator. It could also be the CDI unit too! I hope this helps
Mar 13, 2008 | Audio Players & Recorders
Home Logo
851 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
