Consider how the switch will be used before choosing a mounting location. Check for rear clearance before drilling a 9/32-inch hole and mounting the switch.The GRAY wire in the two-pin plug may also be used as a (+) ghost switch input and can be connected to any (+) switch in the vehicle. (See Feature Descriptions section of this guide.)
This is from the installation manual for the Viper 300. To answer your question, it is probably camoflaged. They only needed to tie +12vdc to the input line. What does this mean? Well, my best guess is, they are using one of your switches on your dash to act as the Valet function. Look for where the Gray wire, from the wiring harness of the Viper goes to: that WILL BE your hidden Valet switch. Best of luck!
Viper 300 ESP Installation Manual Plug in Harnesses Super Bright Led Valet...
