Question about Home
Are there different types of fire alarm systems and if so, what are they?
    New Friend:
Yes there are different types of fire alarm system like:-
A manual fire alarm system only, activated by manual call points.
An automatic fire alarm system activated by heat detectors and manual call points.
An automatic fire alarm system activated by smoke detectors and manual call points.
The best fire alarm system is Denver Fire Alarm System Monitoring provided be "Metro State Fire". This is the best system that would inform them whenever there will be a fire from the telephone of wireless radio.
The team of experts will take the time to familiarize itself with every detail of your building's fire alarm system so that we can offer you the very best solutions that fit your individual needs.
Posted on Nov 18, 2016
    New Friend:
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 48 Answers
Types of fire alarm systems:
http://www.itsfire.co.uk/alarm-types.htm
Posted on May 07, 2013
I am looking for smoke detector for my motel due to covering the old ones with plastic bags. i was wondering if i would have the same problem with a smoke detector with a pulsing led sensing chamber?
for the correct smoke alarms to use , go talk with your fire brigade officer or fire department
there are 2 types that use batteries and in some countries with an accommodation type of business the alarms have to be hard wired to a central alarm system that automatically calls the fire station
Nov 01, 2016 | Home
System is old need a replacement I can't seem to open, is there a battery replacement or a replacement alarm available
to open fire alarms twist the case to the left and it comes apart
consider this
if the alarm is old , it has been superseded with a better model that works on a different principle to smelling the air to detect smoke
Discuss the advantages of installing the new and different version with any fire prevention company or your local fire department
IN many instances a combination of both ensures protection of the people in the house
Dec 01, 2015 | Home
Why is my fire alarm faulty
Hello. It could be the battery is bad or the fire alarm is becoming bad it self. The best thing to do is change the battery first. If it is giving you problems still, then change the fire alarm it self. Good Luck.
May 16, 2014 | Home
Fire alarm keeps going off randomly and there is no fire or smoke
What type of smokes detectors are you using. Is the Zone programmed correctly. Loose connection. Missising resister
Mar 09, 2014 | Honeywell Ademco Alarm 6150rf Keypad Lk
I have prolem with fire alarm system
I need more information to answer this question, sounds like you might have a ground fault. These are headaches to troubleshoot and it would be best to get a technician on-site to resolve.
Jan 30, 2014 | Sony Home Security
What are the different types of home alarm systems?
There are many home alarm system in the market and different companies also. I like a Monitored system, Unmonitored system, Wireless alarm system and Electric current home alarm. I know everyone has confused where they can get services. I like a home security systems canada reviews site. I think it is the best site and it helps me a lot to get best home alarm provider in the market. You can also check it there. I hope it will helpful for you.
May 07, 2013 | Home Security
Fire alarm panel showing problem on 2 zones
Your smoke detectors, heat sensors or fire pull stations (depends on what is installed in your system) are located on your 4 zones. The wiring that connects these sensors to your fire control panel is supervised by an end-of-line resistor. Starting at the panel all wiring on that zone is daisy chained between each detector with the resistor being placed at the last detector. The panel looks for this resistance value at all times. If one of your detectors goes into alarm this creates a short. This is how the system recognizes an alarm state. Conversely, if there is break in the wiring the system fails to see any resistance and the panel will indicate a problem or trouble condition. The most likely cause of your 2 problems is either broken or cut wiring, ie; the system no longer sees the end-of-line resistance. If you are handy and have access to a multimeter you can measure resistance along the zone loop by disconnecting the zone wires from the panel and measuring wire resistance from each detector to the last one. Most Firelite systems use a 4.7k ohm resistor so you should see this at the zone wiring from the panel. If you don't, try removing a detector somewhere in the middle of the circuit and try again. Once you find a detector with that resistance your problem lies between that detector and the panel. It is just a matter of isolating the problem by measuring the zone resistance along different points of the zone wiring. If you are not comfortable doing this by yourself then I would suggest getting either an electrician or fire alarm tech to track down the problem. Hope this helps.
Dec 29, 2010 | FireLite 4 Zone Conventional Fire Alarm...
Where to connect fire alarm to a combination starter with a hand/off/auto/switch
The fire alarm (usually an open contact, held closed during healthy operation) MUST go in series with the supply to the switch. This is normally incoming to a terminal which is linked between the hand and auto positions. If this is a full control panel, the fire alarm connection SHOULD be used to drop out the entire control circuit. Can you supply wiring diagram?
Sep 13, 2009 | Heating & Cooling
Telephone disconnected from first alert professional alarm system
The phone wires run from directly from the telephone company connection to the alarm on the red and green. They return on the other two wires. These wires are hooked to your home phones. That's the UL way to do it. The alarm is supposed to be the first device on the telephone line. You can just run a phone line to the alarm panel. There probably is a diagram inside the cabinet door or a phone jack very near the alarm.
Apr 11, 2009 | First Alert SA302 Dual System Smoke...
Activity
its depend on the alarm there are many types of alarms
Oct 07, 2008 | ' II' DIY Car Alarm Vehicle Anti-theft...
Home Logo
682 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
