Question about Stihl Garden
Replace ignition coil - Stihl Garden
  • Plink-plonk
    Plink-plonk May 07, 2013
    Your question about replacing the ignition module, Which model are you refering to.?
  • Stihl Master
  • 1,807 Answers
Which model are you refering to.? I can send you a link to the parts manual if you can tell me the modell number.
Posted on Jul 29, 2013
How do I replace ignition coil on my 2011 Kia Rio 1.6l?
Step one: buy new ignition coil
Step two: find bad ignition coil
Step three: replace the coil.
Seriously it is this easy, once you buy the new part you know what to look for in your engine bay. disconnect the old one and reconnect the new one in the same way.
Dec 16, 2014 | 2011 Kia Rio
No spark one plug f725 john deere
Did you replace the IGNITION coil or the "PULSING coil"? There are two different types on that engine. The ignition coil makes the high-voltage spark, the pulsing coil is a sensor that tells the ignition control module when to tell the ignition coil to make that spark. The pulsing coil is pretty inexpensive on eBay.
If you change both the ignition coil and the pulsing coil and the problem still persists, you may need to replace the ignition control module.
Unfortunately, they don't make these things simple any more, or easy to troubleshoot.
Jul 30, 2014 | John Deere Seat For F710 F725 F735 Riding...
How to replace ignition coils
Its a procedure,its not that difficult to replace ignition coils.
Click here
For more help,click the link below:---
How to test and replace Ignition Coil Pack on Audi A4 Car models? http://repairhelpcenter.blogspot.com/2011/11/how-to-test-and-replace-ignition-coil_19.html
How to Replace a C.O.P. Type Ignition Coil?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-cop-type-ignition-coil.html
How to Replace an Ignition Coil
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-ignition-coil.html
How to Replace an Ignition Control Unit
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-ignition-control-unit.html
How to Replace an Ignition Wire Set
http://schematicsdiagram.blogspot.com/2011/08/how-to-replace-ignition-wire-set.html
How to Test Ignition Coil?
http://schematicsdiagram.blogspot.com/2011/12/how-to-test-ignition-coil.html
Engine not getting spark from distributor?
http://schematicsdiagram.blogspot.com/2011/12/engine-not-getting-spark-from.html
Cost to replace ignition coil?
http://technoanswers.blogspot.com/2012/01/cost-to-replace-ignition-coil.html
-------- Ignition locked up on Mercury Villager?
http://technoanswers.blogspot.in/2012/01/ignition-locked-up-on-mercury-villager.html
How to replace ignition coil for Toyota rav4?
http://technoanswers.blogspot.in/2012/02/how-to-replace-ignition-coil-for-toyota.html
These details will help.
Thanks.
Oct 16, 2012 | 1998 Lincoln Town Car
My 1198 bmw 318i compact is only sparking on 1&3 cylinder
Improve the FixYa experience for everyone by voting. I want you to let me know if the solution(s) suggested were of any value. Constructive criticism is welcomed.
I'm Ben and -- hopefully -- I can provide some meaningful assistance.
I recommend a diagnostic scan to confirm my diagnosis of a malfunctioning coil(s).
How to Test and Replace Ignition Coil on BMW 3 Series
The following procedures apply for BMW 3 series (6-cylinders engine) 1992 - 1998 model years. To Test and Replace the Ignition Coil, do the following:
  1. Remove plastic engine covers from top of engine by prying off nut covers and removing cover mounting nuts.
  2. Disconnect harness connector from coil. Connect multimeter between terminal 15 (+) in connector and ground. (use a digital multimeter for the following test). See Fig.1. below BMW 3 series coil harness
  3. Turn ignition on and check for battery voltage. If battery voltage is not present, check wire between terminal 15 and ignition switch. The wiring to terminal 15 (+) of the coil (via the ignition switch) is not fuse protected. Use care when testing this circuit.
  4. Turn ignition off.
  5. Use a multimeter to test coil primary resistance at coil terminals. (primary coil terminals: 1 (-) and 15 (+), primary coil resistance: 0.4-0 .8 ohms; secondary coil terminal and resistance: NA).
  6. Remove coil and inspect coil housing for hairline cracks or leaking casting material . A leaky ignition coil may indicate a faulty engine control module (ECM). Check ECM before installing a new coil.
  7. When replacing ignition coils, ensure that the replacement coil(s) are from the same manufacturer containing the same part code numbers. If individual coils with the correct specifications are not available, all coils should be replaced.
May 30, 2012 | BMW 318 Cars & Trucks
Where are the coil packs located on an 04 Lincoln LS v8? I have traced the wires from the spark plugs, but cannot see where they lead...
This is for the 3.0L engine:
3.0L Engine
  1. Remove the engine appearance cover.
  2. To access the right bank ignition coils, remove the upper intake manifold..
  3. Disconnect the electrical connector from the ignition coils.
  4. Remove the bolts.
  5. Remove the ignition coils.
To install:
  1. Replace the ignition coils.
  2. Connect the electrical connector to the ignition coils.
  3. Remove the upper intake manifold for the right bank ignition coils.
  4. Replace the engine appearance cover.
May 12, 2011 | Lincoln LS Cars & Trucks
Codes p0351 miss and is goverened at 2800 rpms.
P0351 is Ignition Coil A Primary/Secondary Circuit Malfunction.
Possible causes: - Open or short in the ignition coil circuit - Ignition coil circuit shorted to ground - Ignition coil connector - Damaged ignition coil - Damaged PCM or
Possible solution - If damage, repair ignition coil circuit - Replaced ignition coil - Replaced PCM or ECM When is the code detected? The test fails when the Powertrain Control Module (PCM) or Electronic Control Module(ECM) does not receive a valid pulse signal from the ignition coil.
P0351 Description: The ignition signal from the Powertrain Control Module (PCM) or Electronic Control Module(ECM) is sent to and amplified by the power transistor. The power transistor turns ON and OFF the ignition coil primary circuit. This ON/OFF operation induces the proper high voltage in the coil secondary circuit.
Hope this helps :)
Mar 07, 2011 | 2002 Dodge Intrepid
I have no spark in cylinders 2,4,6 on my 2002 Ford escape and three codes 354,355,356 Which means the same . After checkin those Three coils I found out , there is no negative Any advise?
P0354 - Ignition Coil D Primary/Secondary Circuit Malfunction.
Description of DTC:
Symptoms:
- Lack/Loss of Power
- The engine may be harder to start
- Engine hesitation
- Check Engine Light On
- No spark
Possible Causes:
- Damaged PCM or ECM
Possible Solutions:
- Replace ignition coil
- Replace PCM or ECM
P0355 - Ignition Coil E Primary/Secondary Circuit Malfunction.
P0356 - Ignition Coil F Primary/Secondary Circuit Malfunction.
Jan 18, 2011 | 2002 Ford Escape
Miss fires and stots off when I give it gas as codes 1391 ,0351, 0352, 0353,
P1391 - Not a valid obd code.
B1391 - Oil Level Switch Circuit Failure
C1391 - Not a valid obd code.
U1391 - Not a valid obd code.
Its possible you may have misread this code. If it is B1391 that would be the only code with 1391 for your vehicle.
P0351 - Ignition Coil A Primary / Secondary Circuit Malfunction. The ignition signal from the Powertrain Control Module or Electronic Control Module is sent to and amplified by the power transistor. The power transistor turns ON and OFF the ignition coil primary circuit. This ON/OFF operation induces the proper high voltage in the coil secondary circuit.
Possible Causes:
- Damaged PCM
P0352 - Ignition Coil B Primary / Secondary Circuit Malfunction.
Same repair info as P0351.
P0353 - Ignition Coil C Primary / Secondary Circuit Malfunction.
Solutions:
- Replaced
PCM or ECM
Jan 16, 2011 | Jeep Grand Cherokee Cars & Trucks
P0352 code came up what might be the problem
P0352 - Ignition Coil B Primary/Secondary Circuit Malfunction
Symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Engine hesitation
Possible causes
- Damaged PCM or
Possible solution
Hope helps with this (remember to rate this answer).
Jan 14, 2011 | Mazda RX-8 Cars & Trucks
Garden Logo
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
