The red lights come on but no sound on Fisher RA-128-2 Stereo
Who performs repair service for a Fisher Sound system purchased in 1996 for Fisher model TAD-5160 system?
You could try and go to local stereo shop and see what they suggest. It is kind of outdated.
Dec 01, 2015 | Fisher Audio Players & Recorders
My f&p gw611 Fills up but then wont wash.the 2nd
Most possibly be Error code 56,
Is common in 11 series machines & early series 12.
Is your machine beeping & showing a weird pattern of lights on the wash cycle, It is displaying an error code,
To read this error code you start at the red spin light & work to the left only add up the lights that are on. Red spin light = 1 2nd rinse light =2 1st rinse light =4 last wash light=8 4th wash light=16 3rd wash light=32 2nd wash light=64 1st wash light=128
j8paojvh5jrgaaaaabjru5erkjggg==
Let me know your error code tour getting
Oct 20, 2013 | Fisher and Paykel GWL11 Top Load Washer
Model Gw709AU
When you start your machine is the water just go stop go stop,
Just wait for the machine to display an error code on the wash progress lights and beeps constantly.
It could be the Rotor Position Sensor, out of balance switch or lid magnetic reed switch.
Your error code will determine this.
Feb 20, 2013 | Fisher and Paykel Washing Machines
Fisher and Paykel MW 512 AU is not running. The first and the last lights(long wash and spin leds) on the displays stays ON in red and keeps on beeping. I appreciate any help in resolving this issue
This(130) is the only code that comes close to that,
There is no code for 129.
130. (10000010) Single Rotor Position Sensor Error
The Motor Control Module has found an error in the pattern received from the Rotor
Position Sensor. Likely causes of this fault are a bad connection on the harness between
the Rotor Position Sensor and the Motor Control Module, or a faulty Rotor Position Sensor.
Primary Source: Wiring.
Action: Check for corrosion on the RAST connector of the Rotor Position
Sensor and the Motor Control Module connector.
Secondary Source: Rotor Position Sensor.
Action: Check the Rotor Position Sensor with an R.P.S. tester. Replace if
faulty.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
Quaternary Source: Rotor
Action: Ensure the correct rotor for this phase of machine has been fitted
May 26, 2012 | Fisher and Paykel Washing Machines
My amp stopped workin, when i turn the stereo on, the green light is on, then when the music starts to play it turns red and stops working,
The red light on amplifier relates to power supply while the green light is indication of sound functionality. An amplifier that allows sound to generate should display both red and green lights. Howeever, some amplifiers would display only green as long as the sound is functioning.
Solving the problem
First, a red light still on means the power connections to the amplifier is fucntional least requirng repairs.
Second, the green ligh should turn on once the stereo were tuned up to produce sound. If the stereo is still on only least produce sound on the amplifier, check on the connection wires between stereo to amplifier that may have disconnected due to woofing or dubbing sound generals with unfirm wiring.
Third,
Jan 28, 2011 | JVC KS-AR7501D Car Amp
Unit does not turn on or display time
do you mean a power surge, if so the surge may have overloaded the elctronics,=cooked ,so afraid is u/s
Jul 07, 2010 | Fisher SLIM-3010 Shelf System
Hi my fisher and paykel model MW15 wont agitate or do anything really, and the starting from the left hand side, the cycle lights 1st and 7th come on. what does this mean?
This is fault code (130).the lights that are on are added together,il explain how below
0 0 0 0 0 0 0 0
128 64 32 16 8 4 2 1 This is The Rotor Position Sensor located in the motor underneath the machine.from underneath undo the pig plastic nut & take off the big round cover with the magnets in it.undo 4 bolts in centre of motor.The rotor Position Sensor has the plug with about 5 wires on it.
May 31, 2010 | Fisher and Paykel Fisher & Paykel Washer
What is cost
Nokia N95  -387$
Nokia N958GB  -467$
Just before buying refer e bay too you might get a better price but not always.
These are the features
2G Network GSM 850 / 900 / 1800 / 1900
3G Network HSDPA 2100
HSDPA 850 / 1900 - American version
Size
Dimensions 99 x 53 x 21 mm, 90 cc
Weight 120 g
Display Type TFT, 16M colors
Size 240 x 320 pixels, 2.6 inches, 40 x 53 mm
Sound Alert types Vibration; Downloadable polyphonic, monophonic MP3 ringtones
Speakerphone Yes, with stereo speakers
- 3.5 mm audio jack
Memory Phonebook Practically unlimited entries and fields, Photocall
Call records Detailed, max 30 days
Internal 160 MB storage, 64 MB RAM
Card slot microSD, up to 8GB, hot swap, 128 MB card included, buy memory
Data GPRS Class 10 (4+1/3+2 slots), 32 - 48 kbps
EDGE Class 32, 296 kbps; DTM Class 11, 177 kbps
3G HSDPA
WLAN Wi-Fi 802.11 b/g, UPnP technology
Bluetooth Yes, v2.0 with A2DP
Infrared port Yes
USB Yes, v2.0 miniUSB
Camera Primary 5 MP, 2592 x 1944 pixels, Carl Zeiss optics, autofocus, LED flash
Video Yes, VGA@30fps
Secondary QVGA videocall camera
Features OS Symbian OS 9.2, S60 rel. 3.1
CPU Dual ARM 11 332 MHz processor; 3D Graphics HW Accelerator
Messaging SMS, MMS, Email, Instant Messaging
Browser WAP 2.0/xHTML, HTML
Radio Stereo FM radio; Visual radio
Games Yes, N-gage + downloadable
Colors Silver, Plum, Black, Pink, Red
GPS Yes, with A-GPS support; Nokia Maps
Java Yes, MIDP 2.0
- Dual slide design
- WMV/RV/MP4/3GP video player
- MP3/WMA/WAV/RA/AAC/M4A music player
- TV-out
- Organizer
- Document viewer (Word, Excel, PowerPoint, PDF)
- T9
- Push to talk
- Voice dial/memo
Battery Standard battery, Li-Ion 950 mAh (BL-5F)
Stand-by Up to 220 h (2G) / 192 h (3G)
Talk time Up to 6 h 30 min (2G) / 2 h 42 min (3G)
May 30, 2010 | Nokia N95 Cellular Phone
How do I hook up a fisher stereo to my tv so I can here the sound from my tv on my stereo speakers?
You have to have audio outputs on either your TV or VCR/DVD to input into your stereo. Look for the red and white RCA connectors. Most TV's have RCA inputs for audio and video but not always outputs. VCR/DVD players all have audio out so if you have one of these units connect a RCA cable to a input of your Fisher amp. I hope this helps
Dec 01, 2008 | Fisher Audio Players & Recorders
29 people viewed this question
 Grubhead
Grubhead
