Question about Home
I just bought the Fire Sprinkler Head, Viking Upright, Brass, Glass Bulb 12986. What wrench do I use to install it?
    New Friend:
  • 40 Answers
Install the Fire Sprinkler Head, Viking Upright, Brass, Glass Bulb 12986 using Viking 10896W/B standard wrench or wrench 13577W/B for waxed or recessed applications.
Posted on May 07, 2013
Cannot dismantle Viking stove top range. Brass rings at the burners will not turn. Any suggestions.
Use a large pipe wrench, or in extreme situations, buy new retention rings and drill carefully through the old ones... Help Me Find My Model Number RepairClinic com
Aug 01, 2016 | Viking Kitchen Ranges
How to adjust spray and spray pattern
check the directions on the box. sometimes sprinkler head has two screws. one screw is for pattern adjustment and the other is for spray adjustment
Apr 07, 2016 | Orbit Irrigation 58308 Tripod with Brass...
What causes a sprinkler to leak after shot-off ?
It could be the shutoff valve (debris in stem tip), but most likely cause is that the sprinkler is the lowest point in that line and, after shutoff, the water in the system is draining to the lowest point.
Aug 23, 2014 | CHAMPION IRRIGATION PD Dv-050 Valve Drain...
What is an ESFR sprinkler?
ESFR sprinkler is a fire sprinkler, more specifically an early suppression response sprinkler. They use fast-response fire sprinkler technology to provide fire suppression of specific high-challenge fire hazards, like in the piping system. Before these came about in the 90s, protection systems were used.
May 07, 2013 | Home
How do I adjust sprinkler head properly
Check to see if the small slotted screw is flush with the top of the spray nozzle. If so, it has been manually lowered. Turn the screw counter clockwise until it stops, be sure to hold the nozzle to keep it from turning. If no, unscrew the nozzle and remove debris from around filter. Tell the gardener to just mow the grass and not to touch the sprinkler system he is usually why it was turned down 9 times out of 10. If he says "No touch, No touch. He is lying fire him.
Apr 13, 2013 | Orbit Sprinkler System 2-inch Soft Top...
Replace bulb in hyundai curved glass fire
Two people required for this
Remove fire from wall
Lay fire on its back
Gently slide glass panel towards top of fire and remove. Store glass safely
At the bottom of the fire there is a lamp cover fixed by 8 Philips head screws.
Remove screws and lift off the lamp cover
Slide the flexible rotisserie to one side ensuring you don't lose the rubber grommet
Remove bulb by pulling it out of the holder (force may be required)
Replace with 40 watt G9 halogen bulb. Take care not to touch the bulb with your bare hands
Push the bulb fully home
Refit the rotisserie making sure the rubber grommet is carefully pushed into the slotted hole in the axial bracket
Refit the lamp cover
Lift the fire back onto the wall and replace glass front by lifting onto the lugs either side of the fire.
Oct 22, 2011 | Hyundai Heating & Cooling
How do I get the sprinkler 'T'' HEAD off
Hold the plastic nut located just under the "T" with adjustable pliers or wrench and unscrew the "T head" with your hand.
Mar 14, 2011 | Nelson Sprinkler: Traveling Tractor
Same thing, can't figure out how to get it apart.
Viking has a "special" (ha,ha) tool that you put across those 2 notches in the center brass ring. You can find this wrench with pics at: allvikingparts.com/BT_SBW_Sealed_Burner_Wrench_s/138.htm
You probably have thrown out many similar looking 'free' wrenches(because we have better ones in our toolbox) that are packaged with kids toys etc. that should do the job.
A hand held steamer has done a pretty good job for me in cleaning the burned on gunk. I have also used my dremel with various different polishing tips when I have been really frustrated with gunk and discoloration.
Aug 26, 2009 | Viking 37 in. VGSU161 Gas Cooktop
Brass Champion Sprinkler Valve
The lowest sprinkler head usually leaks until all the water is out of the system. The valve that controls the sprinkler system has a vaccum breaker valve on it. When there is no pressure from the water main the vaccum valve opens allowing the sprinklers to leak water so the house water won't get contaminated from the grass and dirt in your yard.
Jul 27, 2008 | Electrical Supplies
Home Logo
825 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
