Diplomat manuals 2 days In , the blower fan stopped working
5 Suggested Answers
samson-1
  • 153 Answers
SOURCE: heater not working
The problem is probably the blower motor resistor. I'm not sure where yours is located exactly. They can be on the firewall under the hood or some are near the blower motor under the dash.
Posted on Dec 23, 2008
r_mcalhoun
  • 166 Answers
SOURCE: Blower fan resistor module replaced, worked for 2 days quit again
hi you probely have a draging blower motor. if it pulling more than 25 amps replace it and check akk wirring connectors for burn or hot spots. good luck
Posted on Jul 17, 2009
  • 202 Answers
SOURCE: heater control for fan blower not working
check the blower motor relay, located under the hood fuse/relay box. turn the system on and tap the blower motor see it works. The blower motor located under the glove box.
Posted on Apr 19, 2010
  • 224 Answers
SOURCE: front blower fan for 2004 dodge caravan stopped
I would venture to say that it sure sounds like you are loosing the blower motor. Brushes wear and it makes it draw more amperage, this is why changing the resistor worked short term only. Not exactly what you want to hear but thats what does happen to them.
Posted on Dec 20, 2010
Reset lamptimer on kds-r50xbr1
The problem is not with the lamp. This TV (I have one) has 3 blowers internally that keep everything cool. What happens over time, regardless of how clean you keep your house, they get clogged and stop. What you are seeing is that the system cannot see one or more of the fans spinning. Yes, they detect whether the fans is spinning.
You'll need the Service Manual or Repair Manual to take the TV apart. This is non-trivial. It took me 2 days to take it apart and a day to put it back together. I used another day to clean and the blowers and air ducts within the TV. I had one stopped blower, the other two were pretty dirty. I was able to fix it without buying anything. The stopped blower has to be disassembled, cleaned, lubricated and seems to be holding (knock on wood).
I seem to recall I had to pay for the service manual. Here's one link you can try. You can also do some other searches to see if you can find one for free http://www.nodevice.com/manual/sonymans/manual3410pdf/get4927.html
Jun 18, 2012 | Sony Televison & Video
Heater control for fan blower not working. stopped working for about a day then started working again for a day then stopped altogether dead since.
Apr 19, 2010 | 1992 Honda Civic
HIGH RESISTANCE IN THE BLOWER MOTOR CAN CAUSE YOUR PROBLEM, OR A BAD RESISTOR.
THERE IS NO REAL GOOD WAY TO CHECK THE RESISTANCE OF THE BLOWER MOTOR.
Jul 16, 2009 | 2005 Chevrolet Malibu
Fan won't blow on levels 1, 2, and 3 but will on 4 and 5
you need a blower motor relay under the pass side of dash
Mar 09, 2009 | 2002 Chevrolet Malibu
The inner glass panel on my diplomat oven has shattered. What can I do?
My Diplomat Oven Heating element (ELEHY6075) stopped working with the FAN ON combination. I replaced it with a new one and it still does not work with the FAN option. All other combinations do work. What can I do?
Mar 07, 2009 | Ovens
Heater not working
Dec 23, 2008 | 2006 GMC Sierra 1500 2WD
Fan assisted oven not working
If the fan is still working then it is the element that has gone. This is easily replaced as you only need to remove the back panel and swap the the element.
Nov 02, 2006 | Rangemaster Classic 110 (Dual Fuel) Dual...
Heating & Cooling Logo
42 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
