Question about LG LP1200DXR Portable Air Conditioner
Here is water pan - LG LP1200DXR Portable Air Conditioner
Leaking water on floor
remove the floor grille and check drip pan if full carefully remove and drain water if pan is dry [pan is drip tray from auto defrost water goes to pan than usually dissipates ] if dry look to back at water line for damaged or leaking line or valve
Aug 11, 2015 | Kenmore Refrigerators
Why is it leaking water on the floor?
Remove the floor grille and check drip pan if full carefully remove and drain water if pan is dry [pan is drip tray from auto defrost water goes to pan than usually dissipates ] if dry look to back at water line for damaged or leaking line or valve
Aug 11, 2015 | Refrigerators
What is the loaf size for a Williams-Sonoma WS1094 bread machine
Bread pan Capacities
Here is how you determine the size of loaf you can bake in your machine. You need to determine the capacity of your pan. Fill your pan with water and measure the cups added so you know how many cups of water are in the pan when it is full to the very top. Here are the conversions:
1)If your pan holds less than 10 cups of water you can make: a 1 pound loaf
2)If your pan holds 10 cups of water you can make: a 1 pound loaf and a 1.5 pound loaf
3)If your pan holds 12 cups you can make: a 1 pound, 1.5 pound, and a 2.0 pound loaf
____________________________________________________________________
This is rare, but if you pan holds 14 cups or more you can make all the above plus a 2.5 pound loaf
Jul 20, 2011 | Williams-Sonoma Brushed Stainless Steel...
I'm not sure what capacity my bread machine is, so i don't know how much water to add. It's model 5834.
Jan 12, 2011 | Oster 5834 ExpressBake Bread Maker
I have a Toastmaster bread and butter machine, model 1195. Need to know what size the bread pan is.... 1, 11/2 or 2 pounds, its not written anywhere on the appliance. Also, I need to replace the bread...
FROM ANOTHER SITE:
To find your bread machine pan size:
Fill the bread pan with water and measure it out in cups
Less than 10 cups of water = 1 pound
11-13 cups of water = 1 1/2 pounds
More than 13 cups of water = 2 pounds
You don't need the bread pan cover unless you are making butter. If you are making bread you should always leave it off or it could melt from the heat of the baking cycle. The butter cycle doesn't use heat. Please rate this answer with testimonial/vote/rating etc Thanks!
Dec 28, 2010 | Toastmaster Kitchen Appliances - Others
Hinari homebaker model hb152 bread capacity what is bread capacity for model
FROM ANOTHER SITE:
Dec 26, 2010 | Kitchen Appliances - Others
Lost manual need to know if the trilium TR 500 breadman is a 1 lb or 1 1/2 lb machine and directions. lost the manual
FROM ANOTHER SITE:
Dec 17, 2010 | Breadman TR500 Bread Maker
What size bread will 41066 make
FROM ANOTHER SITE:
Dec 14, 2010 | West Bend 41077 Just For Dinner¿...
Water leaking from bottom of refrigerator
THE WATER IN THE PAN IS FOR THE FAN WHICH COOL THE COMPRESSOR. MAKE SURE THE FAN IS WORKING. IT USES THE MOISTURE FROM THAT WATER TO COOL YOUR COMPRESSOR.
BOYNISMO@YAHOO.COM
Aug 10, 2009 | Kenmore 57029 Side by Side Refrigerator
Water in box waqter keeps accumulating on shelves iveg bins andunder bins
When the freezer goes through the defrost cycle, the water collects in the defrost drain pan and drains into a pan underneath the unit where it evaporates over time. If the defrost drain pan is clogged, the water will fill the pan where it will freeze. Once the pan is full of ice, the water from the defrost cycle will run over the pan and down into the fresh food section. This will require that the drain pan be clean of the ice and the drain tube cleared of ice and debris.
Hope this helps.
Aug 07, 2009 | Whirlpool Refrigerators
LG LP1200DXR Portable Air Conditioner Logo
13 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
