Canon 5075 E000102-0001 - Office Equipment & Supplies
E000004-0010 error on my canon ir 5075
That means induction heater is faulty (insufficient current) and needs to be replaced.
Dont forget to clear error log after the replacement.
(copier>fnction>err>clear)
Nov 03, 2015 | Canon ImageRunner 5075 Copier : IR 5075
No text only blank page on canon ir 5075
Laser shutter stuck, it covers the line of sight from the laser unit to the drum unit when drum is taken out. sometimes things get out or place and it does not open you can see it with the drum cartridge out and move it but if the lever is not broken which it usually is not but only slid off the side of the actuator that pushes it back overcoming spring tension or gravity. Let me know, I didn't look up the model but know that the ir6030 s and other models did this a lot
Jul 24, 2015 | Canon ImageRunner 5075 Copier : IR 5075
MY CANON 5075 TONNER SUPPLY MOTOR PROBLEM REGURALY I HAVE CHANGED MOTOR MANY TIMES BUT STILL IT GETTING PROBLEM WHAT IS THE PROBLEM
try to find the right toner for 5075 and replace it< if the problem still alive,so it's about your toner sensor
Oct 28, 2014 | Canon ImageRunner 5075 Copier : IR 5075
Error code E0014 in ir5075
its happen when the fuser motor not rotate, check the fixing roller ball bearing may be stuck
Dec 12, 2013 | Canon ImageRunner 5075 Copier : IR 5075
Error 001 004
reset the code first copier>function>clear>err>ok
then if problem is still there replace the thermistors and also verify if there is no paper in the rear connections of the fuser and the main frame
Oct 23, 2013 | Canon ImageRunner 5075 Copier : IR 5075
Error 100-001 mesin ir 5075
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured or click start type in event viewer press ENTER you might be able work your way through the problem
Hope it helps.
Dec 18, 2012 | Canon ImageRunner 5075 Copier : IR 5075
E000808 in canon ir 5075
something wrong in power supply or fixing drive.
the power can not hitting well.
solution is checking both or call technician because they hard enough.
May 24, 2011 | Canon iR 5075 AllInOne Printer
Which one is better to buy IR 5075 or IR 5065
The all above models are same with minor change for speed
You need model as your daily output requirement
All models are heavy duty.
you can select any one for upto 10,000 print or copy per day or for 20,000 & up print/copy select ir 5075
Jun 15, 2009 | Canon imageRUNNER 5000 Copier
k24674
jasbo
jasbo
