Question about Pool & Spa
How to install new pool heater - Pool & Spa
    New Friend:
  • 53 Answers
The pump equipment and tools.
Installation and Repair. Factors to Consider When Buying Heat Pump
Posted on Jun 19, 2015
    New Friend:
  • 12 Answers
Shut the pump down. Open the lid on the pump to allow into the system. This will drain the plumbing lines at the equipment. Drain water from heater by removing drain plugs(usually 3) Shut the gas valve off to the heater and undo the union that is usually after the valve(recommend gas fitter doing this and he should reattach any piping or rethread new cut pipe. Cut or disconnect water lines from and to the heater. Remove old heater Install new heater in location and reconnect water lines to appropriate side of the headers(water inlet and outlets for heater). Gasline reconnect via gas fitter. Light pilotand restart pump after filling with water and repriming
Posted on Jul 18, 2013
Hayward pool heater smoke
Is it smoke? Could it be steam?
If so, condensation "Rain in the inside of your new heater". This is a real problem & needs to be checked out by a Certified Heater Technical service man. Preferrably, not the one who installed.
Nov 22, 2013 | Pool & Spa
HI WE INSTALL H250FDN POOL HEATER . AFTER A DAY THE HEATER WAS INSTALLED CUSTOMER CALLED MANITOBA HYDRO BECAUSE IT WAS A STRANGE SMELL WHEN THE HEATER BURNING. GAS COMPANY CAME AND SHUT OF THE GAS FROM A...
The heater literally stinks for some time after it is installed as the fire tile burns in. Every heater we install makes my eyes burn if I get a good whiff of the fumes...Are you certain the utility actually tested the discharge air? My guess would be someone walked up and gave it a sniff and over-reacted to what is a normal odor from a new heater. You can of course double check your flames from below the burner tray. If they are nice bright blue standing 2 - 4 inches tall your heater is operating normally and the smell should subside shortly after it gets some steady use.
John
May 26, 2011 | Hayward H-series Electronic Gas Pool...
We have a less then 1year old heater that is burnt out becuse we put clorine tablets in the skimmers lxi gas pool heater
You owners manual will tell you that putting chorine tabs innto your skimmer will damage your heater and void the warranty. I am sure you already know this now. It is bad procedure to do this. I assume you have a leaking heat exchanger. This is very costly, and you will probably need to call a professional to install it. If the heater was much older, i would probably say to just buy a new heater. The exchanger usually run about half the price of a new heater.
May 18, 2010 | Hayward 250kbtu Ng Pool Heater - Inground
Pilot is lit but when i turn the thermostat up the heater will come on. installed new thermostat but still will not heat pool?
do you change the sensor that come with the termostat? do you have a automatic control may be a temp sensor is bad ? last the pool take one degree per hour to heat are u give enough time?
Jun 16, 2009 | Jandy Laars Lt 400,000 Btu Heater
Jandy Lite2 flashing LCD display with number 113
Error showing 113 - Had pro check it out, all systems normal (voltages, gas, etc.). Spent $310 and ordered new control assembly from Amazon (pool store wanted $425) installed myself in under 2mins and heater works perfectly again. Zodiac R0366200 Heater Control Assembly Replacement for Zodiac Jandy Lite2LJ Pool and Spa Heater
Jun 11, 2009 | Zodiac JANDY LITE 125K BTU NATURAL GAS...
Smoke or vapor coming from new h400fdn hayward pool heater.
Not at all uncommon. New heaters have to glaze over the file tile in the burner chamber and will often smoke and smell during the first week or so of operation.
Using a mirror, check to see that your flames are about 4" proud of the burner tubes when running. As long as they are and the color is a nice blue with little to no yellow/orange color, the heater is fine.
May 28, 2009 | Hayward H Series Pool & Spa Heater 400k...
Pool & Spa Logo
159 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
