How do I place the developer in the toshiba - Office Equipment & Supplies
1st...which Toshiba? There are HUNDREDS OF MODELS!
2nd: call a tech
Posted on May 07, 2013
Where does the developer go toshiba 3500
The developer goes into the developer unit. It is a supply that your tech installs. The copier you have needs both developer and toner. The developer is iron fillings that are used to hold the toner on the mag roller of the developer unit. It gets worn out over time. Good Luck
May 07, 2013 | Toshiba D3500 D-3500 Developer Starter...
Where we can buy toshiba studio 230 developer?
677864645f7a396c54674d71464b78424b4677-100x100-0-0.jpg Toshiba E-STUDIO 163 202l Developer Black
New Genuine Original D2320 TOSHIBA E-STUDIO 163 202L DEVELOPER BLACK Each $88.21ExtraMileToner
at
GenuineBrandSupplies.com
New Genuine Original D-2320 TOSHIBA E-STUDIO 163 202L DEVELOPER BLACK Each $65.33
Oct 21, 2011 | Toshiba e-Studio163 Copier
The developer box does'nt keeps toner in it, is it probably because of already 'old developer' or do i need to add some developer...how much is developer? Mine is toshiba e45. Thanks a lot.
Hi
The developer life span is about 150.000 copies, then it should be replaced.
If the developer has not done 150.000 copies then there could be another problem.
The cost of the developer is about R1000.00. {in South Africa}
Please remember that the life span of the drum and drum cleaning blade is also 150.00 copies, so the developer, drum and cleaning blade should be replaced at the same time.
Regards
Apr 12, 2011 | Toshiba e-Studio 45 Black and White Copier
Devloper installation toshiba 1560
the developer of toshiba 1560 is not the same in toshiba studio200l you cannot use it to digital copier if you use the developer of toshiba1560 to studio200l there is a big problem
Nov 19, 2010 | Toshiba Estudio 200L Copier
When we moved our copier it was laid down on its side. Now the scanner assembly is a mess. The heads moved and the cables came off the pulleys. Can this be fixed?
Yes it can be fixed. You will need to call an authorized Toshiba Service Center as the tech will need the scanner "jigs" to reposition the scanner back to factory specs. Also note this may not be the only damage to the machine. Placing this machine on it side while moving may have spilled toner and or developer inside the machine. This may require dis-assembly and cleaning as well as replacement and recalibration of the developer. If you have a Toshiba Dealer near you, I would ask them what they charge per hour for labor and if they have a technician trained on this model. I would estimate 3 to 4 hours labor time to correct these issues. If needed, add another $100 for Developer.
Good Luck and Thank You for using Fixya.
Jul 08, 2010 | Toshiba e-Studio 35 Copier
How to change developer on Toshiba 2060 copier?
Changing the developer is a procedure for service technicians to do.  You might want to ask that question on copytechnet.com.  There are Toshiba service technicians on that can help you with that.
Sep 13, 2008 | Toshiba 2060 Copier
How do I add developer to a E-Studio 350
The developer should be change by a tech. You have to dump the old and replace with new and then set the developer calibration. Waste toner is right in front, a black container that you remove, dump, then put back in place, try to do that each time you add toner so that it never fills all the way full. I do service your area if you need help. Email me at Lbcoaster@aol.com
Hope that helps...
Lbcoaster
Jul 29, 2008 | Toshiba e-Studio 350 Copier
16 people viewed this question
k24674
