Question about Maxtor OneTouch III Mini Edition (R01E100) 100 GB USB 2.0 Hard Drive
Unaccessible Drive I just got this external hard drive. When I plugged it in, everything loaded up on it's own. I needed to reimage my computer. I synced all the info i needed to the hard drive and had my computer reimaged. I plugged the hard drive back in after the reimage and it recognizes the hard drive, but won't autorun the launch.exe application on the drive. I can't view it on my computer and I haven't been able to locate a similar download on the internet to do the same job. Any suggestions?
  • Deetjen Aug 12, 2007
    I actually found a vista version herehttp://www.seagate.com/ww/v/index.jsp?lo... that worked, but your link also works for downloading the software. Thanks.
    Problem Solver:
  • 16 Answers
I have seen this before and the result was becuase the encryption was activated on the device (a password set) and then the software was lost of the PC - in your case due to the reimaging. Manual installation of the software is required. It is available from: http://support.seagate.com/rightnow/mini_software/otiii_mini.exe
Posted on Aug 12, 2007
SOURCE:
WD elements hard-drive not working, powering up fine + PC is making the noise associated with a USB port connecting to an external source, but the Hard-drive is not showing up on My Computer and is...
Try on any other computer first.
Download Hirens Boot. Place burned CD and reboot with it. Run Norton Ghost (bundled with Hirens Boot) and select USB option. Do a disk check.
Mar 06, 2011 | Western Digital Elements powered by WD 320...
Unaccessible drive it gives me 2 mesages: m1 :
The first error signals the fact that the partition data is corrupted. The second one signal an error in communication . Both put together signal the fact that your unit has died. You might have a slim chance that the actual disk inside it might have some life left in it: take it out, connect it directly to a desktop and try to access and extract all the files from it.
Feb 14, 2011 | Toshiba 1TB Canvio for Mac USB 2.0...
My desktop crashed. I lost everything on it. I thought I downloaded some informatin on my Seagate Externa harddrive, however, I am having problems connecting to other computers to see if any information is...
External hard drives are plug and play, the drivers are build into windows.
IF the hard drive was connected when your computed crashed, and the hard drive was in use, it may have damaged it.
If it does not automatically connect to other PC's looks like it has been damaged
Aug 20, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
My external hard drive is not being recognized by my computer.
Try using another USB cable or different port on your PC. It also may be that it needs external power, Check to see if its plugged in to the wall, if it is, it may be that you need a new power supply.
Jun 03, 2010 | Galaxy Metal Gear GMG 2518UAS External...
External hard drive isn't recognized!
try pluging it into a different usb port try a different cable if they all do not work then the partision table has been damaged and the drive will have to be reformatted
Dec 06, 2009 | Western Digital (WD3200JS) 320 GB Hard...
Hard drive unaccessible
There is a program called On track recovery.
This application successfully recovers data from damaged hard disks.
You will need and extra storage where to transfer the recovered data.
Don;t forget to rate this answer if it helps.
Dec 03, 2009 | SimpleTech 250GB USB2.0 7200 RPM External...
Lacie HD power light flashing yellow and orange
Hi. Sometimes, there are compatibility issues on external drives. Most recent computers will read them while others may not. Either the external casing or the cable is causing this.
Aug 27, 2009 | LaCie (300728U) 250 GB Hard Drive
Computer may or may not start up. When it does, it may or may ..
Go with a known good working hard drive, its the easiest thing to replace and instead of reimaging it, install windows from scratch and then load the drivers for whatever it doesnt find and then see how it runs, if the lockups stop happeneing then load the apps that you want and everything should be okay.
Jun 26, 2009 | HP Computers & Internet
Will not load.
my old computer had a problem like this, i think the only way to fix a problem like this would be to reformat your hard drive and reinstall your operating system, which would delete everything on your hard drive...if you do not want to lose the files on your hard drive, you can hook up the hard drive to a different computer as a secondary drive and take the files you need off of it...then put the drive back in the original computer and reformat...after that just put back the files back on the original computer with a flash drive or an external hard drive...
cant think of another way to solve this
May 25, 2008 | Acer Aspire E380-UD420A (ASE380-UD420A)...
Wd 120gb External no longer recognised by my PC
hi there
have you tried looking at the device manager?
you can also try transfering it to different usb ports.
hope this helps
Feb 04, 2008 | Western Digital Passport WDXML800UE...
Maxtor OneTouch III Mini Edition (R01E100) 100 GB USB 2.0 Hard Drive Logo
124 people viewed this question
Top Maxtor Computers & Internet Experts
Phil Whisenant
Phil Whisenant
Alun Cox
Norman Al-Anbar
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
