Question about Garden
Nilfisk patio cleaner
The patio cleaner nozzles are not spinning or spinning slowly, but the water seems to be coming out at full pressure
  • 101 Answers
SOURCE: pressure washer won't build pressure
The problem sounds like its in the handle.. trigger mechinism
Posted on Dec 15, 2008
jeff_drakesr
  • 155 Answers
SOURCE: no pressure
Check the Water supply, make sure there is plenty of pressure comming from the hose hookup. Use 3/4" dia. hose to the pressure washer. Check the Inlet Screen on unit to make sure it is not clogged. Hoses are free of kinks. I hope that the information given is helpful, please rate on its helpfulness. Good Luck and have a great day. Jeff
Posted on Apr 04, 2010
  • 623 Answers
SOURCE: Water is not coming out of my honda pressure washer
Any chance it froze during the winter? They do need to be winterized.
Posted on May 05, 2010
SOURCE: i have a 2300 psi
If you no longer have High Pressure coming out while machine is running, it's a pump issue.
Posted on Mar 19, 2011
  • 1388 Answers
SOURCE: troy bilt pressure washer 2550
There is a valve installed to release water out of the system if water temp. rises to a level that may damage the pump. Water temp will rise when motor is running and you are not spraying water. This part is called a thermal valve. It can begin to leak water if worn out or debris under seat, however may not effect a lower pressure at the wand unless it leaks more water when you are spraying than when in bypass. You can see various thermal valves by searching on ebay with the key words :
"pressure washer thermal valve". Pressure is created at the tip of the wand. If the nozzle at the wand is worn or too large for the system, pressure will be reduced. You can check if the tip is correct by using a different tip that came with your system or using new of correct gpm as noted on the specs. of your system. Good luck
Posted on May 31, 2011
Why is red light on my Nilfisk Orbit vacuum cleaner on ?
[PDF]Nilfisk GM80 and GM80i Vacuum Cleaner User Manual ...
www.sylvane.com/media/.../nilfisk-gm80-vacuum-cleaner-user-manual.p...
Troubleshooting. Loss of Power. 5. 6 ... CAUTION: This Nilfisk vacuum cleaner or any other vacuum cleaner is not to be used in explosion-hazardous areas, as ..
Sep 19, 2015 | Nilfisk Vacuums
DOES NOT SEEM TO HAVE FULL POWER AT NOZZLE. NOT CLEANING AS WELL AS LAST YEAR
Either the pump has worn or the pressure relief valve is stuck in a slightly open position reducing overall pressure.
Mar 16, 2015 | Garden
Hoover troubleshooting
Hi Nita! There are a few things that can reduce the suction of the cleaner. Please try these steps below.
1. Remove the clean water tank. Recline the handle and let the cleaner lay flat.
2. Remove the dirty water tank. Check that the grey cap is on and tightened on the tank.
3. Clean the filter screen located on the cleaner base.
4. Remove the nozzle. Clean any hair or debris from nozzle.
5. Clean the second filter screen behind the nozzle on the cleaner.
6. Assemble the nozzle back to the cleaner.
Give it a try! Your suction should be restored. Hope this was helpful!
Jul 15, 2014 | Hoover FH50220 Max Extract Pressure Pro 60...
Karcher paatio cleaner attachment cleaning in suiggly lines
Squiggly lines are sign of nozzles being partially clogged. Try using a needle to clear nozzles. You will need to remove the nozzles to do this. When re-installing the nozzles make sure they are in line with the pressure bar.
Mar 13, 2013 | Karcher KE302007A Classic Series Pressure...
Pressure washer patio cleaner wont spin
you need to make sure the nozzles are not plugged up
Aug 05, 2012 | Garden
My new petrol pressure washer i think has an air lock the lance isnt giving full pressure , sometimes really bad , have tried all sorts of things , taken the hose off and started it up , some times full...
Hi and welcome to FixYa, I am Kelly
Your lance nozzle most likely has a little bit of debris in it. Remove the nozzle and clean behind the orifice hole of the nozzle. Since you said the rotary cleaner works fine this is about the only thing that can be causing the problem unless there is a significant blockage in the lance plumbing. If this does NOT correct the problem... please respond your make and model number because there are other steps than can be performed to troubleshoot.
Thanks for choosing FixYa,
Kelly
Apr 12, 2011 | Garden
How do i use the patio & deck cleaner on the karcher k5.68MD, when i add the liquid, what do i need to do for it to be pump up into the hose.
The nozzle on the end of the wand either twists or pulls out to get you into soap mode, the liquid you have in the tank come out real slow, it does not come out with the high speed nozzle. The idea is to soak the job with detergent, then blast it off with the high pressure water. Hope this helps.
Mar 23, 2010 | Karcher Garden
GX 08 spray gun problem
drain your system of pressure. remove your air cap and nozzle from the gun. slowly increase fluid pressure till it comes out of gun. this will clean out debri from gun. reduce pressure so you don't wast anymore fluid.
clean nozzle properly / completely
clean aircap. properly / completely
inspect needle tip for abnormal wear.
if cleaned properly you will find your gun works much better.
Oct 17, 2009 | Wagner GX08 Airless Spray Gun
When vacuuming dust does not go into bag but goes all over the place.
Used an elastic band to tighten bag onto nozzel.
Sep 27, 2008 | Nilfisk Vacuums
I am looking for a nilfisk c120.2 pressure hose replacement i seem to have looked everywhere
need to be more specific,is it click an clean tube with tornado nozzel ,or 15m drain&tube cleaner.
Aug 28, 2008 | Nilfisk Vacuums
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
