My netgear extender is not getting connected to the router. Only the green light for power is on. I tried resetting.it is not detecting in any devices (router is detected) I even can't open mywifiext.net page. Please help
  • Anonymous Mar 13, 2014
    Will this router operate with the WN3500
  • 32,281 Answers
This WEB site show how to configure the Netgear wireless extender.
http://www.youtube.com/watch?v=oNbqqXX_2NQ
Posted on May 07, 2013
3 Suggested Answers
sandrew
  • 2961 Answers
SOURCE: cannot reset or access configuration page.
assuming your pc has previously connected to the router, why did you require a reset. Remove your RJ45 cable and try reset button for 10 secs then let go. The other problem I see is you cannot connect through both wireless and wired to one IP address, you say the wireless lan light flickers and then say it knows you have removed cable, are you trying to connect via two different computers or just one. Please reply on this post and not a new one; it's hard to follow.
Posted on Nov 29, 2006
Fedarion
  • 33 Answers
SOURCE: Laptop wont detect Router
Assuming your laptop and router are wireless, make sure you enter your security passcode for the network correctly. A mistake on the passcode will prevent you from connecting.
Also, try to reach the router's configuration from a wired connection. Once you do so, make sure you don't have the router set to deny access to unknown computers (that is, make sure any kind of "access list" is turned off).
Posted on Dec 10, 2007
How to set up netgear ex6100 wifi range extender
Overview:
This article describes how to set up a NETGEAR EX6100 in Extender Mode
The extender connects wirelessly to your existing WiFi network, and then it creates a new WiFi extended network and links the two WiFi networks.
Symptoms:
Cannot connect to extender
Extender broadcasting EX6100_NETGEAR_2GEXT
Extender broadcasting EX6100_NETGEAR_5GEXT
Extender cannot access Internet or network
Process:
1. Place your extender in the same room as your WiFi router.
2. Plug the extender into an electric outlet and wait one minute.The PowerLED lights green.
If the Power LED does not light, press the Power button on the side.
3. Make sure that the mode switch on the extender is set to Extender.
4. Use a WiFi network utility on a computer or mobile device to find and connect to the EX6100_NETGEAR_2GEXT or EX6100_NETGEAR_5GEXT (SSID) WiFi network.
Note: EX6100_NETGEAR_2GEXT and EX6100_NETGEAR_5GEXT are the default name of your extender's wireless networks, and by default it is unsecured. If you changed the wireless name or security in the past, connect to the new name or enter the passphrase when prompted. EX6100_NETGEAR_5GEXT is only visible if your wireless adapter is 5 GHz capable.
After the wireless connection with the computer or mobile device is established, the Client Link LED lights solid green.
5. Open a web browser window from the same computer or mobile device.The browser takes you directly to NETGEAR genie Smart Setup.
Note: If you are not automatically directed to NETGEAR genie, launch an Internet browser and type www.mywifiext.net in the address field of the browser. Enter admin for the user name and password for the password.
6. Select a 2.4GHz WiFi network to extend and click the Continue button.
7. Type the network passphrase (also called password or security key) in the Passphrase field and click the Continue button.
8. Repeat steps 6 and 7 to select a 5GHz WiFi network.
Note: If your router does not support the 5GHz band, click the Skip button.
9. Select Private Network(home network) or Public Network radio button, and click Continue.
Note: Selecting Public Network will enable NAT and DHCP on the EX6100. For more info on NAT refer to: What is NAT (Network Address Translation)?
10. Type the name (SSID) for your WiFi extended network in the 2.4GHz and 5GHz Network Name (SSID) field and click the Continue button.
Note: You can use the same security settings as your existing network by selecting the Use the same security mode check box.
The WiFi extended network settings are applied.
11. Use a WiFi network manager on a mobile device or computer to connect to the extenders newly created WiFi network.
12. Click on the check box and click on Continue to finalize the installation.
13. Unplug the extender and move it to a new location closer to the area with a poor WiFi signal.
Note: The location you choose must be within the range of your existing WiFi router network.
14. Plug the extender into an electrical outlet and wait one minute. The Power LED lights green. Connect to the extender network and enjoy the extended Wifi network.
May 02, 2014 | Computers & Internet
Gigabyte b49g wont link with wireless extender
first, Keep in mind that you bring the device into the same room as your wireless router.Use NETGEAR, Linksys Router.
second, Green LED on the extender is showing green to be able to get the optimum performance on your devices.
third, if not get it than just reset to factory defaults
then manually changed the security settings for your router .
Apr 14, 2014 | Gigabyte GN-B49G Router
Not able to connect the extender to my apple time capsule? no wps button. can i use this extender?
Hi, yes you will be able to use the Netgear range extender with the Apple Time Capsule, provided you configure the Time Capsule's wireless settings based from the wireless security you have setup on the Netgear router or extender. No need for WPS button. Just treat the time capsule just like another wireless laptop.
For instructions in setting up wireless settings of Time Capsule click on this link -->> http://www.apple.com/timecapsule/wireless.html
Hope this helps. Glad to be of service.
Nov 10, 2011 | NetGear WNR2000 Wireless Router
I have a netgear range max, it has been working fine. Just last night nothing wireless in my house works. Cable modem works. Power light on netgear box is green. "i" icon is flashing green,...
You need to reset and reconfigure router
please follow the steps to reconfigure router
RESET THE ROUTER:
1. Make sure router is connected to power supply and is on while you perform the task below. At the rear panel of the router, near the antenna, there is a very small round pinhole that contains the reset button.
2. Using a pen/pencil/paper clip, hold the reset button for 60 sec. so that the test light starts flashing.
3. After few seconds when the test light stops flashing. Turn off the router and turn it back on after a couple of minutes.
RECONFIGURE THE ROUTER:
1. Please remove all the connections from the router. Connect power to the router and then connect a cable from the computer into any of the 4 lan ports on the router. Make sure the modem should not be connected to the router or to the computer.
2. Open up the Internet Browser (Safari, Internet Explorer, Mozilla Firefox, Opera, etc.).
3. Put http://www.routerlogin.com/basicsetting.htm in address bar.
4. On the basic setting page scroll to the bottom and click on Apply.
5. When prompted for Username and Password, please enter 'admin' for the Username and 'password' for Password.
6. Click on lan ip setup under advanced.
7. Change the lan ip to 192.168.10.1 and under use router as a dhcp server change the starting ip as 192.168.10.2 and ending ip as 192.168.10.51, click apply and click ok for any popup message that arise.
8. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, Connect the dsl modem on the wan port of the router and restart the computer.
9. Power off the dsl modem and the router after making the connections.
10. Power on the dsl modem and wait till the dsl light comes on, then power on the router.
11. Open a web browser like Internet Explorer, Mozilla Firefox or Safari.
12. Access the router (http://192.168.10.1).
13. Login to the router (Username = admin Password = Password).
14. Click on Setup Wizard and then select "Yes" and Click "Next" on the detection window.
15. It should give you a "Dynamic IP Detected" or "pppoe detected"(type the Username & Password of your dsl account in case of pppoe detection) and then click next.
16. Click Apply.
17. Logout of the router.
18. Open up another browser window and try to access internet.
Regards,
Prakash
Apr 08, 2011 | NetGear WGT624 Wireless Router
Netgear router - wont connect
In Netgear routers if the tick light is on that mean there are some issues in the router. Normal by resetting the router to factory default can be solve these issues. Please follow the steps below to reset the router.
1. Locate the reset hole at the back of the router.
2. Press the reset button with the help of pen or a pointed object for 15 seconds.
3. Take out the power cable without releasing the reset button.
4. Plug the power back cable without releasing the reset button.
5. Hold the button for 15 more seconds and then release it.
6. Take out the power and plug it back and check the status.
Regards,
Rashsih Sharma
Mar 25, 2010 | NetGear WGT624 Wireless Router
I cann't connect to some specific web when using the NetGear router. I never have this problem before. I have try bypass it by connect my internet directly to the modem then the web get in is ok, by when I...
a lot of times its the sequence of the reboot for each device. what happens is, the modem connects to a particular device (computer, router, etc.) and then establishes that connection as a relationship. if you try to plug the ethernet cable into a different device without rebooting the modem, it will never connect. that being said........make all of your connections modem ethernet to router input, then router output to computer ethernet input. then, reboot the modem (with no power plugged into the netgear...its next, just no power yet). once the ready or cable light goes solid and the modem is up, plug the power supply into the router and let it do its thing, then you should see the "i" with a swoosh under it light up, it will be orange for a bit until it connects to the modem, finally turning green. from the router to the computer ethernet.......click your start button on your desktop, click the "run" near the control panel button....a little window pops up down by the start button....type the letters cmd (short for command) and then hit ok button...........black screen for dos pops up with a blinking curser.......type ipconfig then hit enter. the first stages of numbers for the default gateways etc should read close to this 192.168.0.1 (this is the ip of the router). if you see these numbers, you should be able to surf the web. you must do the reboots in the sequence as stated above.. give each interval a minute to do its thing. some newer operating systems need you to physically acknowledge the "new network detected" and select home away office...... so once the reboots and the ipconfig stuff is done but you still cant surf, restart the computer, hopefully when it comes back on it will detect the new network.
i am a senior tech for charter cable and have installed over 5000 internet connections.
you can also email me thru my website
yostamplifier.com for further questions.
Jan 21, 2010 | NetGear RP614 Router
Power and internet lights flash slowly green & if i press reset button then power light flashes green to red. No other lights illuminate.
Try a hardware reset by holding in the reset button on the back panel (need a pin) for 20 seconds as you turn it on. If it does not work or you will not get connection from your router to cmputer it means the router has gone bad and need a replacement Let me know if this will help
Nov 27, 2009 | NetGear DG834G Router
Can't Connect to Netgear Range Extender Kit
-- you can connect the Xe102 to he wall plug where ur router is placed
-- And then reset it from the reset hole on the back of the Xe102
-- and after that connect the WGX102 to the other wall plug where u wanna get wireless access ..
-- And then reset it from the reset hole on the back of the WGX102 as well
-- And once u do that it will not ask for a security key .
-- It will show netgear unsecured
-- try to connect with it and u will be connected
Feb 14, 2009 | NetGear WGX102 54 Mbps Wall-Plugged...
Computers & Internet Logo
1,111 people viewed this question
David Payne
David Payne
