Question about Netopia 2247NWG-VGx Wireless Router (2247NWGVGX)
Default eircom password - Netopia 2247NWG-VGx Wireless Router (2247NWGVGX)
User manual wanted for eircom 9000 phone
http://siteassets.eircom.net/assets/static/pdf/cpe/eircom_9000_9000A_twin_pack.pdf
Perhaps you try this link?
In Google the first line when you use the phone name and add manual.
Sep 11, 2014 | Lands Phones
Strict NAT type on xbox live...eircom is provider, there router
Follow this link and it'll tell you exactly what to do if the router your using is an eicom netopia http://xbox360help.blogspot.com/2007/09/xbox-live-eircom-router-netopia.html
I had the same problem when i started 3 years ago. now i recently bought the new wireless adaptor and have one of the new routers from eircom and after 20 minutes during gameplay it disconnects me from xbox live.it is really startin 2 annoy me now. does anyone know what could be causing this to happen??
Jan 12, 2010 | Netopia 2247NWG-VGx Wireless Router...
Netopia 2247NWG for smarttelecom
Sorry if my writing is not clear I dont have best english.
If you move your router from eircom to smartelecom you have to change security protocol from "chap" eircom to "pap" smarttelecom.
Now Do this few steps.
Go to start menu on windows find and click run.
type: cmd and press ok
When you will see black screen that will be command prompt.
Now you have to type your defaul ip adress. To check your defaul ip adress type ipconfig in command prompt and press enter.
Default Gateway is your default ip adress. Now when you know your ip type in command prompt:
telnet yourip 23 and press enter, for example:
telnet 192.168.1.254 23
If you didnt setup any password to login to the router you will be loged automaticly and you will see "Netopia-2000/18861188>
But if you have setuped login and password to your router you have to first type your login and press enter,then password and press enter to have acces.
next is easy type:
configure and press enter
ppp and press enter
set and press enter
now you have to pressing enter about till you will see line:
option <chap-only> [ off : on : pap-only : chap-only ]:
on this line type pap-only and press enter
now start pressing enter till you see:
Netopia-2000/18861188 <ppp>>>
then type save and press enter.
When you see line:
Configuration data saved you can close command prompt window.
From this moment your router will be work with smarttelecom.
Dec 13, 2008 | Netopia 2247NWG-VGx Wireless Router...
Xbox360
these need to be primarily setup on your router...
<< PORTFORWARDING >>
and likely within your pc firewall if you have one.
What router do you have ?
What Firewall software are you running ?
Jul 21, 2008 | NetGear WGR614 Wireless Router
Unlock netopia 2247 router
If your talking about the password for the router user interface that is not working that resetting it again using a pen or a paper clip just press and hold the reset button for 30 seconds then that should bring your router to its default settings with the default username and password.
May 06, 2008 | Netopia 2247NWG-VGx Wireless Router...
How can i unlock my router?
Firstly... avoid showing your SSID (eircom-123456789) here, as the WEP key can be reverse engineered from the SSID.
To change your SSID, connect your router to your PC with an ethernet cable, go to your web browser (Intenet Explorer, Forefox, etc) and type 192.168.1.254, and press return.
This will open the control panel for the router.
Select 'EXPERT MODE' from the menu on the right, and accept the warning prompt. Then click on 'CONNECTION' and the 'WIRELESS' on the menu on the right.
In the main window you can then change the SSID for your network.
You can also change some of the other options in this window such as enabling closed mode, change security protocol, password, etc.
Feb 13, 2008 | Netopia 2247NWG-VGx Wireless Router...
How can i unlock netopia 2247NWG
Feb 10, 2008 | Netopia 2247NWG-VGx Wireless Router...
Installing wireless router
um is it compatible with vista and/or upgradable?
Jan 15, 2008 | Zyxel Prestige P-330W Wireless Router...
Netopia 2247NWG-VGx Wireless Router (2247NWGVGX) Logo
15 people viewed this question
Top Netopia Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Netopia Computer and Internet Expert? Answer questions, earn points and help others
