Question about Garden
Flymo rl 400
How to remove starter pulley
2 Suggested Answers
  • 26 Answers
SOURCE: Where doe sthe oil go in a flymo 400 lawnchief lawn mower
the same place you check the oil the dip stick tube. you may need a funnel. after putting some oil in wait about a minute to let the oil get all the way in then check to see if you have it full.
Posted on Jul 30, 2009
Where to find my starter for a 1997 Acura RL
It is under the car at the rear. Here is the procedure to remove it.
Removal
1. Ensure you have the anti-theft codes for the radio and the navigation system, write down the frequencies for the radio's preset buttons.
NOTE:
The PCM memory setting is needed after reconnecting the battery.
2. Disconnect the battery negative terminal, disconnect the positive terminal.
3. Raise the coolant reservoir. Remove the battery and battery base.
4. Remove the alternator belt and alternator.
5. Remove the left exhaust manifold cover.
6. Remove the left damper fork.
7. Disconnect the left suspension lower arm ball joint.
8. Remove the left axle shaft.
9. Remove the transmission stop collar, and remove the exhaust pipe.
10. Remove the front mount mounting bolts.
11. Attach the chain hoist to the engine.
12. Remove the left engine mount bracket.
13. Disconnect the starter cable and BLK/WHT wire, remove the starter.
Sep 20, 2016 | 1997 Acura RL
How do I replace recoil spring on generator
Depending the manufacture of the engine the actual replacement varies. You basically need to first remove recoil starter cover assembly. In the center in most recoil rope pulleys will be screw(bolt) that need to be removed. Pay close attention the assembly order or the parts; take picture if necessary. Once you things a part and old spring is removed. Be careful even broken springs can go flying and cause injuries. Carefully put the new spring in the correct direction. Re-assemble the rope pulley unit. To put tension on the spring you wind the pulley in the same direction as it would if you was pulling the rope out. Wind until it stops then unwind up to one turn depending where the rope enters the pulley and install the starter rope. After the starter rope is installed slow let the pulley take up rope slack. Then you re-install the starter cover assembly on the engine.
Note on some engine other components needs removing just to the starter cover off. I know of some Briggs engine that this is true as the carburetors has to come off first.
Jan 12, 2015 | Electrical Supplies
Trying to remove a acura 3,5 rl stater from the car need the help
double posted. back up one.
ooops. you added were , word , is that really WHERE IS IT?
try posting simple questions.
post symptoms first. why guess? on CAUSE.
where,. try this.:
the battery Plus cable, goes directly to the starter, can you follow this cable
what does it look like, a key fact is discovery.....
first hit:
http://thumbs4.ebaystatic.com/d/l225/m/mDiB6tdy7fVpRfjwVGKSE3A.jpg
ok , i login to FSM web site (alldata.com is best) for you, so can you.
and see
qoute: Reading the manual avoids big mistakes, for sure)
Make sure you have the anti-theft codes for the radio and the navigation system, then write down the customer's radio presets. Make sure the ignition switch is OFF.
  1. Before servicing the vehicle, refer to the precautions section.
  2. Remove the battery trim.
  3. Disconnect the negative cable from the battery first, then disconnect the positive cable.
  4. Remove the intake manifold cover
  5. Remove the vacuum hose and transmission dipstick.
  6. Remove the harness clamp.
  7. Disconnect the starter cable from the B terminal, then disconnect the BLK/WHT wire from the S terminal.
  8. Remove the two bolts holding the starter, then remove the starter."
unquote
Feb 02, 2014 | 2005 Acura RL
Stater trying to take it off on my acura rl a 1996 one 3.5
Starter removal.
what is the question. are you asking for the words in the FSM
on topic?>
ill answer in the generic,
1: pull battery cable negative lug, or BOOM, eat acid go blind, etc.
2: remove all cables from Starter.
3: unbolt it , it falls out.
if wanting pictures, youtube it.
or read the FSM
or join alldata.com and read. its all there
Feb 02, 2014 | 1996 Acura RL
Starter rope is broken how do i replace it
Remove the fuel tank and starter cowl, remove snapped rope.wind the pulley to put tension on the spring approx 7-8 rotations. Put a screwdriver through gaps in pulley and through a gap in top of cowl in order to stop pulley from releasing tension. Burn end of new rope and twist end with a rag while still hot to make a point at end ( careful not to burn yourself) then feed the pointed end through rope hole on outside of cowl and through the hole in side of plastic pulley. Tie a knot in the rope once its through and on inner of pulley. Fit starter handle to other end of rope.hold rope and remove screwdriver and slowly feed rope back into starter
Jun 19, 2013 | Briggs & Stratton Garden
The pull cord hasn't snapped it just wont recoil! is this an easy fix?
Sounds like the starter spring has broken, remove the three torx screws securing the starter and remove the starter, prise off the r clip holding the pulley and pawl on ( note the orientation of the clip on the pawl ) remove the pulley, the spring is in a cassette, remove the cassette and replace with new, refit the pulley, make sure the pulley locates properly into the hook on the starter spring, re fit the pawl and r clip, enter the cord into the cut a way in the side of the pulley, now wind the pueey around to tention the spring.
Apr 17, 2013 | Stihl Concrete Cutoff Saw Rewind Recoil...
Pull cord jammed in the lawnmower
There could be several reasons for this problem, but sometimes it is in need of a simple cleaning. Remove the 3-4 nuts holding the starter assembly on the top of the engine. Normally you will use a 10mm socket and ratchet to remove them. Turn the starter over in your hand so that you are looking at the starter pulley. Inspect the starter rope and make sure it isn't jammed between the starter pulley and the housing. If it is jammed, grab the starter rope and starter pulley and rotate them both together clockwise until the rope becomes unjammed. If the rope isn't jammed, turn the starter pulley counter clockwise gently. It will probably spring back and draw in the rope. If it retracts the rope slowly, spray WD40 around the bolt in the center of the pulley and work the pulley back and forth until the pulley frees up. If it doesn't free up or this isn't the problem, get back with me and I'll try and walk you through the rest of the repair.
Sep 13, 2012 | Yard Man 12A-569Q001 21-Inch 160cc Honda...
Crankshaft pulley removal 1990 lexus ls400
Get a breaker bar and posision it against a chassis rail or something solid. Tap ignition key to start & quickly off. The starter motor will crack the bolt loose for you. Just make sure the bar wil not damage anything (such as radiator but yours front whee drive right? radiator be ok but get my drift.
Jun 15, 2012 | 1990 Lexus LS 400
How to put new pull rope on a husqvarna 44
Remove the four screws securing the starter to the saw. take a piece of starter cord 3.5mm diameter approx 86cm tie a knot in one end, Remove the single crew securing the rope pulley and remove, feed the new cord through the hole in the pulley, re fit the pulley to the cover, make sure the spring engages into the back of the pulley, feed the cord through the hole in the cover and re fit the the starter handle, now hold the cord in the cit a way in the side of the pulley and sart to wind the spring up by rotating the pulley, allow the pulley to re wind pulling the cord in,
Apr 02, 2012 | Husqvarna 44 61 268 272k 225 Chainsaw Gas...
How to Remove the starter motor on a 1997 Acura 3.5 RL
Stick it in your *** and do as followed:
1:insert in ****
2:twist and if u feel a buzz or humm you may have a faulty ecm
3:take out
4:you may have a loose ******** or faulty ecm component
Jan 17, 2012 | 1997 Acura RL
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
