Question about Home
What do clothes valet look like? - Home
    Problem Solver:
  • 52 Answers
A clothes valet is a piece of furniture that is free standing and made out of wood.
Posted on May 07, 2013
What is a Valet?
A man's personal male attendant, responsible for his clothes and appearance.
Jan 17, 2013 | Home
How do you put Prestige APS-200 in valet mode?
Turn on the ignition key than press and hold the valet button until the LED illuminated steady. You are now in valet mode. To turn off valet mode, just press and release the valet button with the ignition on.
Jan 15, 2013 | Vehicle Parts & Accessories
Valet switch location
The valet switch is usually located around the drivers side. Each installation is different, as are most alarms. The valet switch could be part of the flashing LED or, it could be incorporated into the on glass antenna. If not, it should be located below the driver side dash. If you can see the alarm, locate the blue two pin plug and trace the wire to the push button valet. If the unit is manufactured by Directed (Viper, Python, Avital, Clifford, Valet, Automate, Hornet, etc.) turn ignition on then off, press and release valet within 10 seconds, LED will illuminate solid to show system is in valet. If the unit is manufactured by Audiovox (Prestige, Pursuit, Code (new)) turn ignition on, press and hold valet switch for approx. five seconds, release, LED will illuminated solid to show system is in valet.
If you are attemting to manually override the system, turn ignition on, press and release valet switch to disarm.
Aug 21, 2012 | 1995-1997 Chevy Tahoe Ignition Starter...
Sunbeam steam valet instructions
How to fill your Sunbeam Steam Valet
Here is how you fill your Steam Valet. Press the small button on the back of the handle and pull bottom of handle apart from the top half of steam valet. Then take off the white cap on the inside of the handle and fill with water to top. Place cap back onto the opening and slide handle back and click in place. Plug in and you're ready to steam within a few minutes. If it spits out water let heat up a little longer if that doesn't stop it then tie a thin cloth over the top part where steam comes out to keep the water from spitting out onto your fabric. Hope these instructions are clear enough. More questions about this iron go to www.manualslib.com.
Feb 29, 2012 | Sunbeam Irons
Where did they put the valet/program buttom on my 2004 Rendezvous?
This is somebody else's so;ution, but it might give you an idea on where to start. I always thought the valet switch was just a key that you gave to the valet. But inn this case out of my legue, my old dodge pickup doesn't hAVE AND MOST LIKELY NEVER WILL HAVE A VALET SWITCH. So check this so;ution oout and see if it gets you going in the right direction.
There should be a key specifically for a valet.
1) Open one of your vehicle's doors and turn the ignition, using the car key, to the "Run" position. Check to see that the dome light comes on. Make sure that you have the dome light set to the position where it powers the light when the door is opened, as there are usually three settings: one for "On," one for "Off" and one for when a door is opened.
2) Press the valet remote push-button to access the channel that you want to program: once for "Arm/disarm," twice for "Trunk Release" and three times for "Remote Start." The valet push-button is usually located under the driver's side panel, and it must be pressed within 15 seconds of opening the door. The push-button may also be installed underneath the kick panel.
3) Press the valet push button once again and wait to hear a chirping or a honking sound. If you do not hear either of these sounds, your vehicle might have a jumper installed that has turned the valet programming feature off. Refer to your vehicle's instructional manual to learn how to set the valet programming feature to the "On" position. Keep holding the valet button pressed as you continue onto the next step.
4) Push the button on the remote that you wish to assign to a particular valet channel. Press the button on the hand-held valet remote that you wish to assign to a particular valet channel. If you wish to program multiple remotes, repeat this step for each of them. If you program four or more remotes, the old programming will be erased.
5) Let go of the valet push-button and exit your vehicle. Your handheld remote is now ready to use.
Tips & Warnings- Some valet remote channels require different programming individually, so refer to the owner's manual or to the link provided in the "Resources" section of this article, for specific instructions.
- Valet remote programming methods may vary, depending on the vehicle's make and model.
  • By avatar11.jpgBraunson Y309 days ago
    Braunson Y Level 2
    • 467 Solutions
    • 282 Score
Dec 19, 2011 | Viper Security and Remote Start System...
Where is the valet switch on a 2004 chevy malibu LS?
Tips & Warnings - Some valet remote channels require different programming individually, so refer to the owner's manual or to the link provided in the "Resources" section of this article, for specific instructions.
Feb 17, 2011 | Keyless Entry Remote Fob Clicker for 2004 ...
I reeplaced the fuel pump, fuel filter, and fuel pressure regulator. thinking that was the problem! But was told that the alarm might be the problem so i pressed the alarm twic and the truck started but...
You must put the alarm on a valet mode to see if the alarm is causing this problem
To enter or exit Valet Mode
1. Turn the ignition on
2. Turn the ignition off
3. Press and release the valet switch within 10 seconds
The status Led will light solidly if you are entering valet mode, and it will go out if you are exiting valet mode.
To enter or exit Valet Mode using the transmitter:
1. Open any vehicle door.
2. Press and realese lock and unlock buttons at the same time
3. Press and realese Aux button
4. Press and realese the lock and unlock button at the same time again
The status led will light solidly if you are entering Valet Mode and it will go out if you are exiting Valet Mode
Now when in Valet Mode try to start the engine, if the problem persist the alarm has nothing to do with it
Jan 11, 2011 | 350 HV ESP Security System 350HV ESP
My glove box valet lock is on, how do I override
Your black ended driver key should open the glove box. The valet key is not made to open it, thats the safty feature in it. There is no overide for the Valet settings, you have to unlock the glove box with Driver (master or black) key and turn the Valet switch off. Also the Valet switch does not engage the glove box lock so over riding the Valet security wouldnt open it even if you could over ride. If the Valet key would unlock it or was easy to overide then it wouldnt be a very good safety feature. Best of luck, hope you can get it opened.
Jul 28, 2010 | 2001 Oldsmobile Aurora
Jaguar XK8 Valet key not working correctly
I have seen this before, each time i have seen it i have to reprogram the valet key. This needs to be dont at the dealership, make sure you bring the master key otherwise they cant program the valet key.
Mar 20, 2009 | 2006 Jaguar XK8
Home Logo
386 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
