Question about Home
How many ounces do highball glasses hold? - Home
    New Friend:
  • 49 Answers
Highball glasses hold 8 ounces of liquid.
Posted on May 07, 2013
0.29 of an ounce in fractions?
Make Sure Funds Are Available Free education at UK Essays, If you have a credit card, you should contact the credit card company to inform them of the spring break destination. This ensures that the credit card company does not put the account on hold for suspicious activity. It is a good idea to limit the amount of cash kept on hand.
https://www.speedyessay.co.uk/essay-writing-service.php
Jan 20, 2018 | Homework
Victory highball running on 1 cylinder
Did you boost your bike from a car or using a charger/booster pack if so fried your ECM.
If not check fire to both plugs, not sure on highball but most victory's have two coils one for each cylinder.
Jan 20, 2014 | 2014 Victory High-Ball Base
What kind of oil should I use in my Hobart 800 floor mixer? jdnwilk@juno.com
Hello Jdnwilk,
In a Hobart L800 you use 140 weight gear oil in the head and 90 weight gear oil in the planetary. You should start with about 160 ounces and check the sight glass and fill until in the middle of the site glass after oil settles.
Thank you for choosing FixYa.com
Mar 06, 2011 | Hobart Food Mixers
How do i check the oil level on my suzuki 2000 savage ?
Greetings,
To check the oil level there is a 1 inch sight glass on the foot brake side of the bike, it is down low just above the exhaust pipe, you will need a flash light and get down on your knees and hold the bike level [not a neet trick while on your knees and holding a flash light]. In the sight glass there are two marks on the front and rear the proper oil level is to be between the marks, not the level is only about 2 ounces of oil from full and add so if it needs oil don't over fill it. [Be sure to not let the bike fall on you, that could really make for a bad day.]
Good luck, Les
Feb 21, 2011 | 2000 Suzuki LS 650 Savage
Need to know how many quarts of oil I need and anything special about changing the oil?
Nothing special, just drain the oil, change the filter, add three quarts of oil. You do know where the oil drain is on the frame just below the transmission behind the exhaust pipes. The primary holds 36-44 ounces, and the transmission holds 20-24 ounces of oil.
Good Luck
Steve
Aug 10, 2010 | 2004 Harley Davidson FLSTF - FLSTFI Fat...
Excessive water poured through shot
its possible someone held the buttons down to long enabling program mode.
Go to your local market and purchase a 3 ounce measuring glass. Place it where you place your coffee cup and hold down the small button, it should enable program mode. Stop it once it reaches 1 ounce or your desired amount.
Do the same for the large.
Sep 03, 2009 | Saeco Royal Professional Espresso Machine
Microwave is scratched
You will need the following:
Polishing compound, jeweler's rouge or whitening toothpaste
Electric buffer
Lamb's wool buffing pad
2 ounces of ammonia
2 quarts of water
Rubber gloves
Safety goggles
Lint-free paper towels or cloth
Step 1:
Apply polishing or jeweler's rouge to a lambs wool buffing pad. You can either buff the scratch by hand using a circular motion or with an electric buffer on medium speed.
Step 2:
Wash the polishing compound, jeweler's rouge or whitening toothpaste off from time to time in order to check on the progress of the scratch removal.
Step 3:
Mix two ounces of ammonia with two quarts of water. You may want to be sure to hold your nose closed during this process! Also, always wear rubber gloves and safety goggles when working with ammonia.
Step 4:
Clean the glass surface with the ammonia water with a clean soft sponge.
Step 5:
Dry the glass with a lint free towel. If the scratches are not completely gone, they should at least be less apparent. If there is no significant difference, consider contacting a glass company to replace or rebuff the glass.
Jul 27, 2009 | Frigidaire FMV156DC Microwave Oven
32 in hdtv with a 9in scratch across it how can i fix it cheep
If the front of the screen is glass, then follow these steps:
  • Step 1 Apply polishing or jeweler's rouge to a lambs wool buffing pad. You can either buff the scratch by hand using a circular motion or with an electric buffer on medium speed.
  • Step 2 Wash the polishing compound, jeweler's rouge or whitening toothpaste off from time to time in order to check on the progress of the scratch removal.
  • Step 3 Mix two ounces of ammonia with two quarts of water. You may want to be sure to hold your nose closed during this process! Also, always wear rubber gloves and safety goggles when working with ammonia.
  • Step 4 Clean the glass surface with the ammonia water with a clean soft sponge.
  • Step 5 Dry the glass with a lint free towel. If the scratches are not completely gone, they should at least be less apparent. If there is no significant difference, consider contacting a glass company to rebuff the glass.
May 09, 2009 | Sylvania 6842PE 42 in. HD-Ready Plasma...
How many ounces does a 2008 FLHR Harley Davidson Road King hold?
Well i blow about 20 ounces of fluid and u ?
I guess you are talking about fork oil? it's measured!!!
Mar 24, 2009 | 2008 Harley Davidson FLHR Road king
48 ounce reservoir part
i think you can not buy spare parts from Keurig. but depending how your reservoir is broken you can fix it whit epoxie glue or fiber glass.
Nov 22, 2007 | Keurig B50 Coffee Maker
Home Logo
930 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
