Question about Philips Cell Phones
Day night sensor
Brand new but does not work. \swivel top
Hoses are getting all twisted up. there is no clog and the hoses are stored in a straight line. Is the neck at the top of the vacuum not turning? if so, what causes this?
look on line for a pool hose swivel. your hose should be 1 1/2 as a norm . they don't know what a swivel is at all the pool stores I stopped at. should be able to improvise I stretched my hose out on the bricks for 2 days in the florida heat. it seems to have helped. but still look for the swivel connector,cut into hose about 3 ft. at either end you chose to mount the swivel. good luck. amf
Jul 31, 2013 | Hayward Navigator Pool Cleaner
Replace ignition coil instructions
Not sure what you are doing but removing the ignition coils is pretty simple. Unplug the coil. Use a 7mm socket to remove the bolt that holds the cil in place. Remove the coil. Some of the coils require a 7mm swivel socket. Not any swivel socket will work. I know for sure that a snap-on or Mac brand swivel socket will work. I also know a craftsman swivel socket will not. Let me know if you have any questions and I'll do my best to answer them. Thank you for using FixYa.com!
Feb 20, 2012 | 2006 Lincoln Navigator
The lights do not go off ?? Is it a bad photocell? They are on all day..and night..
Photocells go bad.
If photocell was working before and stopped working, then photocell is bad.
If photocell never worked, then check wiring.
I buy cheap 120Volt photocells at home center, and when they go bad, buy same brand again, and return bad one in new package if bad one still looks new.
Intermatic has 120V and 240V photocells.
Open following link for Intermatic resources and ez photocell wiring diagram
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#photo
Apr 21, 2011 | Intermatic K4221C Photo Cell Control 120 V...
K4221 photo cell keeps light on day and night whether the suns our or not.
The switch in the photo-eye is bad and has welded together...
you will need to replace the photo-eye...
heatman101
Dec 25, 2010 | Intermatic K4221C Photo Cell Control 120 V...
Quinny buzz front wheel just swivels.
Hi you can buy new & used very cheaply on ebay
Mar 11, 2010 | Quinny Buzz JUICE 2007 complete Brand...
Brand new Dometic rooftop ac,freezes up at night,does fine during day...??
This is common for most air conditioners and is normal due to humidity levels being higher at night causing more condensation build up and then freezing. Solution: Turn down thermostat at night to allow compressor to turn on and off.
Jul 26, 2009 | Heating & Cooling
Brand new 8320 after his first night charging its not working
when you put the phone on the charger does it show a red light on the top of the phone?
if so your battery is dead, when the battery is charged the light turn green.
you may just have a bad battery. I would take it to where you got it and get another one or a new battery. also your charger could be not working
Jun 06, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
Outside unit not registering temp and humidity to base unit
Uniden EWCI936
To get the outside temperature working again, open the outdoor sensor box carefully loosening the one screw with a screwdriver, insert 3 brand new AA batteries, check phone for outside temperature. If not showing on the phone display, try changing the 'channel' setting, just above the batteries. Be careful not to break the tiny switch. Gently use a smaller flathead screwdriver, if needed. There are 3 settings. Mine worked fine on the first setting. If it is showing on the phone set screens, then, carefully screw the lid back on to the sensor box, and re-insert into the sensor wall holder. I keep mine in a plastic bag on a shelf outside, away from sun, so I can get a true reading day or night. It is always a bit warmer in the sunlight than the true outdoor air temperature. Enjoy
Apr 24, 2009 | Lands Phones
Cell Phones Logo
15 people viewed this question
Top Philips Cell Phones Experts
Vladimir Frolov
Tom Chichester
ray gallant
Are you a Philips Cell Phone Expert? Answer questions, earn points and help others
