Question about Continental Electric Crock Pots & Slow Cookers
Belling 425wh mk2 oven manual
Cant make the main cooker work off the timer, i want to get it to work in manual.
Se e4 on my cooker what do i do
The problem is a Signal Switch Malfunction. It has to do with the power switch and the pressure switch from what I have been able to find out. Mine doesn't have a pressure problem it just goes to E4 once you set the time. I gave the switch a good smack and it has been working for a while. This is the second time and this worked both times now. I am sure the switch will have to be replaced at some time. From what I have seen this is a very common problem. There is one way to fix this problem, albeit not the best. I was able to bypass the E4 error by completely bypassing the electronics and wiring the heater coil to get power whenever the pressure cooker is plugged in. It was a very simple job, anyone with any electrical experience can do this. The only problem is that it is a safety concern as there is no way for the heater to turn off even if pressure is getting to be way too high. There may be a pressure relief valve in the lid but the heater coil won't shut off, so don't leave it unattended! But at least this way to you can still pressure cook. Pics of process: http://s909.photobucket.com/albums/ac295/danwat1234/fixing%20the%20pressure%20cooker/
Jul 21, 2014 | Wolfgang Puck 5-Quart Electronic Pressure...
I am missing temp knob and timer knob for a kitchen select pizza oven model TO120 and Select brands stopped making it and have no replacement parts--would anyone know where to get them??
If you can find them online using the make and model number, you might for universal knobs that many appliance outlets sell. Even Amazon.
Here's some at Ace:
http://www.acehardware.com/product/index.jsp?productId=1279536
Jun 25, 2014 | Kitchen Selectives Crock Pots & Slow...
Can a ceramic bowl from slow cooker GFSC35 go in an oven?
If your manual doesn't mention that as an option, it may not be resistant to higher heat settings. I would avoid the oven.
Jul 20, 2011 | George Foreman GV5 4-Quart
Good evening! Can the ceramic insert to my slow cooker Westbend 84386 be used in the oven?
seems rather plausible, however wouldn't it be best to visit the company website - and -- or download an owners manual for this particular unit just to be certain?
Best regards
Ck
Mar 08, 2011 | West Bend 84496 6-Quart Slow Cooker
Need a manual for my west bend slow cooker model 84323
If you need to find parts for your West Bend slow cooker, West Bend coffee maker, West Bend Blender, West Bend popcorn maker, West Bend breadmakers, West Bend rice cooker/steamer, West Bend griddles/skillets/grills, and West Bend toasters/ovens the best place to go is www.westbend.com.
Also checkout this tip as it will help you to find what you are looking for on the website.
West Bend Kitchen Appliances Parts and Manuals
heatman101
Jan 10, 2011 | West Bend 84323 Slow Cooker
I'm looking for the manual for the Corningware SC-60 slow cooker. I need to know how to set the time and temperature. Thanks!
Couldn't find a manual but here's how you can set the time and temperature: http://www.ehow.com/how_6496690_set-timer-corningware-slow-cooker.html Hope that helps.
Jul 27, 2010 | CorningWare SC60 Slow Cooker
Is there a timer I can purchase for the SC60?
A timer would probably work for a slow cooker with only a switch for low, medium or high on the front of the cooker, but this slow cooker requires that after you plug it into the wall you have to tell it how you want it to cook, it won't start cooking automatically. In other words, you have to press buttons to make it cook. Hope that's clear, I know sometimes I'm not.
Apr 10, 2010 | CorningWare SC60 Slow Cooker
Insert of a slow cooker over a gas flame
Stoneware by it's nature isn't designed for use over an open flame, as the flame can cause concentrated "hot spots" which could damage (crack) the crockery insert.
I've used mine to reheat mac & cheese I've made using the crock pot, but then again, my Hamiliton Beach crock pot stated the insert was oven safe to 475 degrees.
As far as using in an oven, most crock pot inserts can withstand oven temperatures, but refer to the owner's manual and instructions that came with your particular appliance to see what they reccomend in that regard.
Hope you find this Very Helpful and best regards!
Aug 27, 2009 | Rival 38601 Smart Pot 6-Quart
Can't use oven without instruction manual
I have one of these, it is not a fast cooker and needs a higher heat than the manual states. The helpline is 0161 934 2240.
Mar 23, 2009 | Crock Pots & Slow Cookers
Crock Pots & Slow Cookers Logo
35 people viewed this question
Top Continental Electric Crock Pots & Slow Cookers Experts
charles
Irene Tulloch
Are you a Continental Electric Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
