Question about HP Computers & Internet
Hp laptop it working and turn off
  • HP Master
  • 32,281 Answers
When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Posted on May 07, 2013
Turn signal
Front and rear, right turn doesn't work? The left turn works? I'd check turn signal switch and wiring circuit.
What is year--make--model?
Mar 16, 2016 | Cars & Trucks
Left turn signal will not work
either wrong signal bulb or short in left turn signal wiring if both left signal lamps not working.if only one of left turn signal dont work could have corroded bulb socket spray a little electronic cleaner in bulb sockets see if left signal work.
Nov 27, 2011 | Cars & Trucks
Turn Signals quit working
Sounds like the turn signal flasher is going bad. The easy way to find wher the flasher is hidden is turn the turn signal on and find the clicking, that is the flasher. The emergency flashers work fine because they use a different flasher.
May 05, 2010 | 2000 Audi TT
My blinkers wont work and when you turn on hazards they work
Please clarify for me if both turn signals work correctly when the 4 ways are turned on or do they work together. If they work together than you need a new turn signal flasher. There are two, one for the for ways and another for the turn.
Feb 03, 2010 | 1993 Jeep Cherokee Country
95' Buick regal, 3rd brake light works, tail lights work, turn signals work, stoplight switch seems to work ie 3rd brake light working, fuse is ok, changed bulbs, but no rear brake lights.
If the third brake light works and the regular ones don't, it is most likely a bad turn signal (multifunction) switch. The switch is able to kill the brakes lights to run the turn signals, and in rare circumstances does this. I've seen it several times. It could also be wiring, especially near the turn signal switch, but it is usually the switch.
Nov 25, 2009 | 1995 Buick Regal
1997 Chevy Tahoe both turn signals stopped working
Sounds like the flasher unit to me. Normally the emergency flasher and turn signal are separate.
Jul 21, 2009 | 2001 Chevrolet Tahoe
Turn signal problems on 98 Grand Voyager
Replace the turn signal relay. (daylight running lights and turn signal in one unit) It costs about 50 dollars.
Jun 21, 2009 | 1998 Plymouth Grand Voyager
Turn signal lights stop working. Neither the right or left turn signal work. Heard a noise before it stop working. The flashing started slowing down and stop blinking. Now it doesn't work at all. What
most likely its the turn signal relay. which is under the hood. in the fuse box. also make sure ur running lights are working if they are connected to the turn signal.
May 08, 2009 | 1993 Nissan Pathfinder
Turn signal
Now replace the flasher unit! Frankster016
Oct 25, 2008 | 2002 Nissan Xterra
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
