Question about Exercise & Fitness
Electric wiring for trojan cardio 450
We recently moved and the movers had to take apart my treadmill to get it trough the door. one of them even removed the back panel for the computer console part and so surprise when he dropped it accidently. Nothing seems to be broken but some of the little white pluggies dislodged during the fall. We have no idee which ones go where. Is there some type of manual on how to plug them all in again? Regards and thank you Jessica
ilragatzzo78
  • 241 Answers
SOURCE: removing rear door panel
Remove the door window regulator handle and then remove clip using a piece of cloth (Manual type only)
Remove the rear door inside handle housing.
Remove the mounting screws (3EA) from the trim fasteners and the door trim panel to pry off. Disconnect the connector.
Insert a trim panel remover between the trim fasteners and the door trim panel to pry off. Disconnect the connector.
Remove the door pull handle mounting bracket and door inside handle.
Posted on May 29, 2008
SOURCE: How accurate are the calorie counters on treadmills and cardio equipment?
Here's what the Sole exercise equipment makers say about calorie counters on exercise equipment. it's from their E-95 users manual: "Calorie readings on every piece of exercise equipment, whether it is in a gym or at home, are not accurate and tend to vary widely. They are meant only as a guide to monitor your progress from workout to workout. The only way to measure your calorie burn accurately is in a clinical setting connected to a host of machines. This is because every person is different and burns calories at a different rate. Some good news is that you will continue to burn calories at an accelerated rate for at least an hour after you have finished exercising!"
Posted on Mar 19, 2009
  • 64 Answers
SOURCE: Faulty Repco sports treadmill
Not really familar with this brand but if it has a safety key, check to make sure it properly inserted and making proper connection.
Posted on Jun 08, 2009
messstat
  • 365 Answers
SOURCE: how do i remove the inside panel of a nissan titan door
Get a 18V drill with phillips screw extention and start buzzing the screws in the armrest and under out...the glass could be anywhere so wear gloves.
Good Luck
Posted on Jun 22, 2009
  • 1986 Answers
SOURCE: remove rear door panel on x type jaguar
You'll need to remove screws that are by the door handle, arm rest, under door and side of door and then gently pull back on the panel as there will also be retaining clips attached and you don't want to break them. If needed, you can pull back the weather seal (can't reuse it, but it's not that important) and you will be able to access everything inside the door
Posted on Aug 14, 2009
I own cardio tech x5 treadmill.Loose green earth wire coming out of the motor cover and is long enough to go up the support leg and into the program board. Does anyone know where this wire should be
It's probably what you say, a grounding conductor. Is there a loose ***** nearby that once connected it to the metal frame?
Grounding should be taken seriously. You don't want a missing ground connection to allow the treadmill to get connected to the electric power. Consider using a test meter to be sure the green wire makes it to the third pin, the U-shaped longer one, on the wall socket connector.
Apr 17, 2016 | Exercise & Fitness
How do I clear the E 7 message on a Trojan cardio 450 treadmill?
If you wish to get some details; check the site http://electro-medical.blogspot.com/. Pull up older posts. Surf the site with patience.
Mar 05, 2016 | Exercise & Fitness
Trojan treadmill cardio 450
This is a tricky job. You may have to take off the console to re attatch .
Dec 08, 2013 | Exercise & Fitness
I have a horizon limited t805..I recently moved..the movers put the treadmill in my basement but didnot unfold it. I cant find my manual..can you please tell me how to unfold it..is there a knob or...
you are looking for the manual which is the same as the 6 model even though you have the 8.
http://www.pdflibrary.info/download/ebook/LIMITED%20SERIES%20T605%20T805/aHR0cDovL3d3dy5ob3Jpem9uZml0bmVzcy5jb20vdXBsb2FkZWRGaWxlcy9Eb2N1bWVudHMvTWFudWFscy9BcmNoaXZlZC9UcmVhZG1pbGxzLzIwMDUvVDYwNS9UNjA1LnBkZg
you can download the pdf and on Page 10 is how to unfold your model
Jun 13, 2011 | Health & Beauty
How do I move my Proform Treadmill to another room without taking it apart completely. It will not fit thru the doorway and too heavy to lift alone.
I have moved this treadmill several times since we bough it. Up and down stairs and from one room to another. I also used to be a mover so I hope this helps. I am not sure what model you have but i have the 525x. To move it I make sure the incline is set to zero, list the track/running section and lock it into place with the locking pin located on one of the handles. The Proform i have has attached wheels so i lean it back and get it close to the door standing straight up. Once there I turn the treadmill slightly and get one side through the doorway then I pull it halfway through the doorway. If its a tile, wood or linoleum floor make sure to put a rug under the treadmill to protect the floor. It will also helo it slide through the doorway easier. Then tuun the treadmill slightly the other way and get the other half through the door. Once there i tilt it back on its wheels and move it where i want it.
Jun 18, 2010 | Proform Crosswalk 500 Treadmill
My brother moved and the movers removed the side by side doors
The dispenser assembly comes apart from the front. It should give you access to the waterline as it comes up from the bottom.
Eric
Jan 19, 2010 | Amana SXD524VW Side by Side Refrigerator
I am moving and my treadmill won't fit thru the door
Follow the steps from the user/assembly manual in reverse. Find the manual here:
http://us.home.lifefitness.com/resources/content/8/2/0/documents/T3%20Manual.pdf
Installation begins around page 9
Aug 29, 2009 | Life Fitness T3 Treadmill with Advanced...
Treadmill belt stopped
Double check all your connection. Check to see if you may have pinched any wires. Also check to see if you have accidently unplugged or pulled a wire loose. If that's not the case it sounds like a lower board issue.
Jul 25, 2009 | Exercise & Fitness
I have the proform 7.0 personal fitness trainer
Try to calibrate the incline threough the calibration mode.
Apr 13, 2009 | Exercise & Fitness
Won't fit through door - taking it apart
remove the 3 screws in the arm trim cover and the harness unplugs there and the other wires are screwed to the frame right there. Philips head screws.
Mar 20, 2009 | Bowflex Treadmill Series 7
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
