Question about Gateway JUNIPER FIREWALL VPN SSG350M (SSG-350M-SH)
How to configure a gre tunnel PPTP through our Juniper SSG 350M to our Microsoft server internally?
Pass up a gre tunnel PPTP through our Juniper SSG 350M to our Microsoft server internally?
What is vpn server
Point-To-Point Tunneling Protocol (PPTP) is another tunneling protocol used to connect a remote client to a private server over the Internet. PPTP is one of the most widely used VPN protocols because of it's straightforward configuration and maintenance and also because it is included with the Windows operating system.
http://electronicshelponline.blogspot.com/ A VPN or Virtual Private Network is a method used to add security and privacy to private and public networks, like WiFi Hotspots and the Internet. VPNs are most often used by corporations to protect sensitive data.
Oct 25, 2016 | Computers & Internet
How can i filter URL's
if you are using juniper netscreeen 5gt then please follow the below link :
http://kb.juniper.net/InfoCenter/index?page=content&id=KB4320
Sep 16, 2013 | Juniper Networks SSG 140 (SSG-140-SB)...
Https://www.facebook.com blocking in the juniper firewall (ssg350m)
MOSTLY its cause the bocking is not proper or its weak to handle the network properties...
Jun 25, 2012 | Gateway JUNIPER FIREWALL VPN SSG350M...
VPN tunnel establish using FQDN for remote end point address
Yes you can do as you expect.
ScreenOS Concepts & Examples ScreenOS Reference Guide, Volume 5: Virtual Private Networks Chapter 4 -- Site-to-Site Virtual Private Networks
"Route-Based Site-to-Site VPN, AutoKey IKE" Example
"Route-Based Site-to-Site VPN, Dynamic Peer" Example
"Route-Based Site-to-Site VPN, Manual Key" Example
"Setting AutoKey IKE Peer with FQDN" Example
"VPN Sites with Overlapping Addresses" Example ScreenOS 5.4: http://www.juniper.net/techpubs/software/screenos/screenos5.4.0/CE_v5.pdf
ScreenOS 6.0: http://www.juniper.net/techpubs/software/screenos/screenos6.0.0/CE_v5.pdf
May 03, 2009 | Juniper Networks (SSG-20-SH-WW)...
VPN Access does not work
Use should add arp proxy setting as the following:
Go to Interfaces and then click on PPTP/L2TP server from the PPTP/L2TP Page go to the Add ROute Tab.
Allowed Networks should be : All Nets
under Proxy Arp you have 2 Boxes:
One is: Available and the other is Selected.
Under Available click on LAN and move it to Selected.
now save and activate and it should work.
Dec 18, 2008 | D-Link Netdefend DFL-210 (DFL210)...
VPN Using XP Servers and D-Link WBR-2310
I had exactly the same problem. The solution is to set up pptp as a virtual server pointing to the lan ip of the server. Port forwarding only forwards the port but not the GRE protocol (pptp passthrough)
Jul 26, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
Policy-based VPN over vrrp
Hi krisva2,
If any of the articles show just the Juniper logo and menu bar you will need to shutoff your ad blocker.
Is Virtual Router Redundancy Protocol (VRRP) supported on Juniper firewalls? (KB ID: KB10892)
http://kb.juniper.net/kb/documents/public/resolution_path/J_FW_VPN_Config_or_Trblsh.htm
This is probably what is going on with your setup but without more information I could not be 100% sure.
Established sessions need to re-establish when the VPN Redundant Gateway fail-over occurs (KB ID: KB6372)
Enjoy!
Aug 16, 2007 | Juniper Networks (SSG-5-SH-BT) Firewall
Linksys Routers and Microsoft PPTP
Microsoft uses IP Protocol 47 [GRE] for this secure tunnel. Provided that the PPTP Pass Through is set to Enable on the Router's Filters page and port 1723 is forwarded to the VPN Server, the Router will allow authentication and remote access into your network. The router will also allow you access remote PPtP networks from behind the router providing the PPtP Passthrough is enabled on the router.
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
BEFSX41 and Microsoft PPTP
Feb 16, 2006 | Linksys BEFSX41 Router (DHBEFSX41)
Gateway JUNIPER FIREWALL VPN  SSG350M (SSG-350M-SH) Logo
120 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
