Question about Kyocera Mita KM-2550 All-In-One Laser Printer
Grey print background - Kyocera Mita KM-2550 All-In-One Laser Printer
  • 4 Answers
Replace your developer tank and toner
Posted on Sep 25, 2013
Printer has light grey background after printing
Hi Mel:
Just a thought, is there a "greyscale" setting?
When I try to print I have the choice of Black & White, colour, and greyscale.
Hope this helps.
Cheers.
Jan 26, 2016 | Brother MFC-7440N Multifunction Laser...
Why is our printer copier printing so light?
The developer should have been replaced by the technician. the solution is simple...replace the drum and developer and you will have nice crisp prints and copies.
May 13, 2013 | Minolta Di3010f Printer
Whatever I print looks "dirty",
If the cartridges are not HP brand, that may be the problem.
Try to figure out exactly what color the "grey" background color is.
If it is truly grey, the black cartridge might be the problem.
You can also try a different type of paper.
Some paper may respond to the printing process differently than others.
If you find that the background is a red, the scanner will have to be removed and cleaned.
These models have a tendency to collect red (magenta) toner on the scanner assembly lenses.
Mar 30, 2011 | HP Color LaserJet 2600n Printer
My sahara Flatbed Scanner works fine except that I cannot find how to print without a "grey:" background. What should I do to print with a clear white background? Eric Schafer. Cape Town RSA.
you will find if you reduce the dpi the scanner is scanning the pictures or documents in, that you will not get a grey background , as you describe, what it is printing is actually the paper itself, if you have it set for say 1200 dpi then reduce it to 600 dpi or even 300 dpi and you will see the difference when you print it
or only select the exact area you want to scan in the document, click preview then move the scan area selection box to exactly fit the picture you want to scan
Mar 27, 2011 | Office Equipment & Supplies
Printing black on paper
Some of these machines will allow you to printe a grey scale test copy.
This will readjust the fax machine back to a nominal mode.
Not knowing how old or how long the machine has been serviced, background can be caused by dirty optics somewhere in the machine.
A remanufactured drum unit can cause this type of problem, (defective unit)
Competitive toner in the toner unit can cause poor copy quality.
Reinstall the old cartrige and see if the problem changes.
Not knowing if the machine has a seperate drum unit and developer housing, it would be hard to answer anything else.
Oct 15, 2009 | Brother IntelliFAX 4100 Laser Fax
HP 2600n grey background
Most Original cartridges are starter cartridges that hold only 1/3-3/4 ink. Drum maybe defective, and this usually causes the grey or black in your printing. Cartridges may need replacement along with the drum. Hopefully this helps
Aug 13, 2009 | HP Color LaserJet 2600n Printer
Kyocera FS-C5015N colour laser printer. -printing grey backgound
it seems very important to shake the toner before using your printer.
it is not too late
remove all toners and shake them well
you will find after a short time that the grey background goes away
Jul 09, 2009 | Kyocera Office Equipment & Supplies
Grey background over entire page.
If toner is getting onto the transfer belt, it can only get there by either being put there intentionally, or leaking.
Failure of Transfer Belt is normally degraded print quality - usually poor density, or a failure of the support behind the belt (usually puncturing the belt), and scoring a drum.
Sep 15, 2008 | HP Color LaserJet 2600n Printer
Grey background in all pictures
your printer is set to print in Gray Scale under the settings tab, take it off GrayScale, :) its a common mistake
Jun 17, 2008 | HP Photosmart C6180 All-In-One InkJet...
Kyocera Mita KM-2550 All-In-One Laser Printer Logo
32 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Henry Gertcher
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
