Question about Olympus SP600UZ Digital Camera
Usb cable - Olympus SP600UZ Digital Camera
Why doesn't Iphone recognize usb cable
Hi There,
Its not only happen in you IPhone cable other USB equipment also get this error, This error will come when the USB cable have a fault, so change the USB cable and try again.
Thanks
Oct 20, 2011 | Apple iPhone 4 Black Smartphone
Tip
Problem Detecting a USB Hard drive or a USB Device If your computer or laptop...
If your computer or laptop has a problem detecting a USB hard drive or a USB device, and another computer can detect it, then the problem could be a RF interference problem.
Then this may help.
Try using an USB cable that is a shielded USB cable (ie. An USB cable that has a clear plastic covering and you can see a metallic weave which covers the wires) OR a USB cable that has a Ferrite core attached to the USB cable (the ferrite core is a cylindrical object approximately 30mm long X 15mm diameter and it is attached to the USB cable near the connector).
on May 19, 2011 | Televison & Video
Trying to connect HP Laserjet 2100 (works fine with XP) to Pavilion dv7 with Win7 64 bit Professional. I downloaded the PCL5 driver from HP but it will not print. I am using a Manhattan parallel to USB...
Did you download the Win 7 64 bit drivers for this printer. If not i suggest try downloading the drivers from the following link
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=14914&pr...
Check the USB connection
The icon on the USB cable (c01424575.gif ) faces up when the cable connects to the product correctly. Check the back of your product and the back of your computer to make sure the USB cable connects correctly and securely.
After you make sure the USB cable connects correctly and securely, review the following guidelines to check other potential USB-related problems:
  • USB ports on the keyboard. USB ports on the keyboard and in the front of some computers might not be powerful enough to support the product. If the USB cable connects to the USB port on the keyboard, try connecting it to another available USB port on the computer.
  • USB cable length. HP supports USB cables less than 5 m (16 feet, 5 inches) long. However, a USB cable that is 5 m (16 feet 5 inches) long must be of high quality. Otherwise, HP recommends using a USB cable that is less than 2 m (3 feet, 3 inches). Do not use patch cables to increase the length of an existing cable. Use a powered USB hub if you need more length.
  • Alternate USB ports. Connect the USB cable to another port on the computer to make sure that the USB port on the computer is not the cause of the problem.
  • Defective USB cable. Replace the USB cable to make sure that the existing cable is not defective.
  • Conflicting USB ports. Disconnect any other USB printers, USB scanners, USB cameras, and any other USB connected peripherals. Start reconnecting these devices one at a time to determine if one of the devices is using too much power. Consider purchasing and installing a powered USB hub if necessary. NOTE: A USB-powered hub is a device that increases the number of available USB ports on a computer and facilitates communication between the USB devices and the computer. A powered USB hub can resolve communication failures between some, but not all, USB chipsets and HP products.
Jun 23, 2011 | HP LaserJet 2100 Printer
Error code = 6A00 whats the problem
ou should disconnect and reconnect the USB cable at both ends to ensure there is a secure connection on the device side as well as the computer side. (Refer to the illustration below to confirm the USB cable is in the proper orientation.) It may also be necessary to try a different USB port on the computer. Additionally, you may need to disconnect other USB devices, temporarily, in order to determine if a conflict exists. Note: Some printers have a type-A USB receptacle on the front to connect directly to a digital camera. The type-B receptacle, on the printer, will connect to the type-A receptacle on the computer with an A to B USB cable.
  1. Disconnect one end of the cable and then reseat it ensuring the cable is firmly seated into the USB port. If the USB cable is plugged into a hub instead of directly into the computer, connect the USB cable directly into the computer.
  2. Repeat step one to reseat the cable on the other end.
    There shouldn't be any resistance when connecting the USB cable to the device. If the cable does not easily slide into the device's port, look at the end of the connector. The shape of the connector should match the port on the device.
    Note: All USB cables will have a USB icon on one side. The side of the cable where the icon is situated is different than the other three sides.
Icon on USB Cable
Shape of the USB Connector
  1. If there is still no communication, then it may be necessary to try a different USB cable or a different port on the computer.
  2. Make sure the correct USB cable type is being used.
Incorrect (A to A) USB Cable
Correct (A to B) USB Cable
Jan 04, 2011 | Canon PIXMA iX7000 Inkjet Business Photo...
Usb cable not detected
Icon on USB Cable
Nov 02, 2010 | Canon PIXMA MP170 All-In-One InkJet...
Usb 2.0 portable drive has (5pin mini) will only work with usb cable that came with canon camera. other brand new usb 2.0 cable won't work. Tried this with 2 different drives and also with mac and PC
Suggestions:
(best to worst)
1. Use a "Y" USB cable with that drive.
2. Use a shorter USB cable.
3. Use the new cables with the canon
4. Use a 2.0 hub
The drive should have come with a "split" USB cable (USB "Y" cable). The drive requires a "data" and a "power" connection to your computer.
Get one at Radio Shack, Best Buy, Office Depot/Max... ($10)... or Dollar store ($1.09)
Oct 02, 2009 | Toshiba 200GB USB 2.0 Portable External...
Error 0701- usb over current on hc/port
This is not a big problem if the tablet works. There are three simple possible solutions to this problem:
1) Sometimes you can plug USB devices into a wall socket so you don't rely entirely on the USB power. See if the tablet can be attached to another power source - if so use the appropriate power adaptor to plug it into a wall socket.
2) Very few USB cables are designed to carry much current. This design keeps the USB cables thin and flexible. Try purchasing a USB cable that looks like it can carry the extra current. Unfortunately USB cable manufacturers do not display how much electrical current their cables can deliver efficiently, so you will need to guess. Generally the thicker cables can carry more current - these cables are *not* necessarily the expensive gold-plated ones. You can usually find a thick cheap one that will do the trick - but it will take a little experimentation. Try different thick USB cables to see if one makes the problem go away.
3) get a special USB cable that takes the power from 2 USB ports and delivers it to one device. These are strange looking USB cables that have an extra male adaptor cord hanging from a USB cable - the cable has 2 male adaptors and 1 female adaptor. Of course this will take up two USB slots on your USB hub.
Hope these help!
Aug 03, 2009 | Lenovo 3000 C200 Notebook
Usb cable
Players use standard USB, Mini USB, or Micro USB. I believe the one in title uses Mini USB cable.
To get a replacement cable go to any computer shop or camera shop and buy a Mini USB cable, take the player with you and show it to the shop assistant to ensure you are buying the right cable.
Regards.
Jul 05, 2009 | Supersonic SC920FM MP3 Player
USB Device Not Recognized Error?
1.connect the USB cable to Mother Board Back side port, not for extension or frontside port.
2. Check Your USB Cable...make sure usb cables are correct
Jun 30, 2009 | Cell Phones
Olympus SP600UZ Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
