Question about Haier Heating & Cooling
Buy replacement exhaust hose
I have an 8000 btu unit and i need a longer exhaust tube. can you add onto the existing hose by simply buying another or do you need some other part? or is this simply not a good idea??
  • 2,385 Answers
You can connect the longer one on same place
Posted on May 07, 2013
  • nicole choudhary May 07, 2013
    but do they sell longer or do you buy an additional and add it to the original hose??
4 Suggested Answers
louislevel_2
  • 374 Answers
SOURCE: exhaust hose replacement parts for Fujitronic Model FA-1300
hello! there,try to website particular service parts mostly on your location where you live,try on google.com and try to type your brand and model then press enter they will give several service center to select that is more conveinient to your place and quality service.and exact price unit feel free to ask any want to purchase.have a good day.and thanks
Posted on Mar 31, 2009
SOURCE: replace exhaust hose
http://www.delonghi-accessories.com/item.asp?modelnumber=9824000005
Or CALL Delonghi at 1-800-865-6330 and order it over the phone. I just did, $65 including shipping for ONE exhaust host.
Posted on Apr 03, 2009
2rns4u
  • 22 Answers
SOURCE: Have an 8000 btu unit missing the vent hose
Home Depot carries alot of A/C parts that may work for you. Hope this helps 2rns4u <*{{{>(
Posted on Jul 22, 2009
Sanyo PTAC model STB0823H1 elec. heating element
Try 1st link for Support Request, 2nd link enter zip code
http://shop.panasonic.com/hvac/how-to-buy/distributor-locator.dot
Dec 12, 2013 | GE Zoneline Deluxe Series Cooling &...
Refrigerant leaking from a puncture in the copper tubing.
Put in a new piece of tubeing.First cut out hole, swag !a new piece of tubeing on both ends to fit over existing tube after claning and fluxing both ends of all four connecting pieces. Then silver solder all. Refill unit with the correct freon. Ifyournot familuarwith HVAC unitsI would suggest gtting profesonial helpl .
Sep 30, 2012 | Soleus SG-WAC-08ESE-C 8000 BTU Window Air...
Water fill area
Compressor is working and it goes on and off. There is a air coming out, but not cold for this 11,000 btu. I also need a longer exhaust hose. Please advise. Unit works great when functioning.
Aug 04, 2012 | Amcor A12000E Nanomax Portable Air...
We have 2 Danby air conditioners. One is a Danby Designer, Model DPAC 10060 and the other is a Danby Silhouette Model DPAC 12006. The venting hoses have broken to pieces and we need to buy new ones that...
You can purchase similar hoses at most home improvement center. Take a section of the old hose with you to get the right diameter and use the existing fittings to attach them to the unint and the window exhaust. What you may find is a better quality hose/duct, than what came with the unit. You may have to buy more than you need in length, but then you'll have some left over, if you ever have to replace it again.
Hope this helped. Good luck.
Jul 18, 2011 | Danby Heating & Cooling
I need to replace a hose on a Danby portable airconditioner model # DPAC120068
The first place to start is with the manufacturer, Danby 800-496-6049. Or take a section of the hose with you and go to your nearest home center and purchase a similar hose (same diameter) and use all the existing fittings that you have, to remount it with the new hose. There are several types available that will work well for this type of application and probably last longer than the original hose did.
Hope this helped you. Please let me know. Thanks.
Jun 08, 2011 | Danby 7,000 BTU Portable Air Conditioner -...
Where can I buy this model???
THis one is an 8000 btu unit the one in the link is a 10000 btu unit which will do a better job. http://www.a14electronics.com/product-p/FRRZQ10C10.htm
May 02, 2011 | Friedrich ZStar ZQ08A10A Air Conditioner
Have a Dayton 600,000 BTU and it has a delayed ignition. It fills up with fuel before it lights. When it does light there is a big cloud of smoke. Any suggestions on why it does this.
For that big of unit I would add at least two more pilot lights. Try to position them so they are equal distance from existing pilot.You can buy pilot light assemblies,pilot light tubing,andfitting at most H.V.A.C. supply centers. Hope this helps you. Thanks
Nov 20, 2010 | Heating & Cooling
Jul 22, 2009 | Danby DPAC8020 Air Conditioner
The built in power lead in my vacuum hose has a short in it. I need to fix it
Hello peter639,
Since you failed to include brand and/or model number.. I suggest you simply add -on another cord to your existing flex hose. If your existing hose has molded connectors on them that you cannot easily find to match, then you may be better off just buying another hose from the manufacturer.. Your call..
Oct 02, 2008 | Vacuums
Electrolux Epic 8000
YES,JUST TAKE OFF THE HEPA FILTER.
IF I MAY SUGGEST,IF YOU WANT TO BUY AN AREUS/ELECTROLUX YOU MAY WANT TO LOOK AT THEIR "BOTTOM OF THE LINE" MACHINE, THE "CLASSIC" IT'S HALF THE PRICE AND A MUCH BETTER DESIGN THEN THE NEW "FLAGSHIP" MODEL, WHICH IS COMPLETELY DIFFERENT THAN ANY PAST ELECTROLUX. IT'S BULKY,AWKWARD TO USE. EVEN IF YOUR BUYING FROM ANOTHER SOURCE, GO INTO AN AERUS DEALER AND GIVE THEM A TEST DRIVE.
I CLEAN APARTMENTS FOR A LIVING AND AM VERY FAMILIAR WITH ALL ELECTROLUX MODELS.
GOOD LUCK!
Apr 01, 2008 | Electrolux Epic 6500 Vacuum
Heating & Cooling Logo
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Michelle Balcom
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
